Bedlam
- Joined
- Feb 28, 2005
- Messages
- 1,883
I wonder that 'oil filter' wrench, looks like it might also double to remove the water filter case also?
I get a kick out of the way they try to fool us into thinmking we're buying quality American made tools...
Is there a Pittsburgh in China???
Last week I picked up their 'Oil Filter Wrench' (pliers, actually) on sale.![]()
The quality looks excellent.
Today I found it is ideal for unscrewing the ring securing my Yanmar's fuel filter bowl. If I never use it for anything else (and I will) it is worth having in the tool cabinet for this purpose alone.
$3.99 at the moment, if you are subscribed to receive their email coupons.
I'd never use a tool like that on an oil filter...
Folks tighten 'em too much, leave 'em on too long and use cheap filters with thin steel.. I've crushed too many using the proper tools ..
That POS might be good for cracking large nuts, but looks like a recipe for disaster in removing an oil filter..
You don't use a wrench to tighten an oil filter. That should be done by hand only. You use the wrench to remove it and who cares if it dents the casing.
I agree completely!
But I've often had to remove filters that were probably tightened with a wrench, and it can be interesting. And once the can is dented, it can be a bear to remove an overtightened filter.
You guys all know that the whole problem with removal of oil filters is the design engineer. If they would just put the danged thing where you could get too it with both hands or any kind of tool, most of these problems would go away.
(SNIP)
I use one hand tightening and dont put out on it much at that. Just check it after it is hot for leaks. I also oil the rubber gasket good before installing. I can usually then spin it off by hand when oil change time comes, that is if I can get my hand into the location. It doesnt take much torque to seal one.
Take it easy on the engineers. They have to listen to the fashion designers who in turn listen to the penny counters.![]()
Gary Fowler said:I seems to me that most engines have the oil filter crammed into the most inacessible spot that they can possibly find. It seems that most of my equipment, you need an octopus to change the filter because you cant get any type of wrench on it, even the old oil filter strap is hard to slip over the end and then you cant get a straight pull on it and I end up bending handles, scraping knuckles etc. especially on the first filter removal.
I love Harbor Freight.I actually not only used them but, for this use, thought they had a good feel to them!Here's the socket set I liked - Harbor Freight Tools - Quality Tools at the Lowest Prices The little plastic holders for the sockets are breaking off, so I need to get a better holder for the sockets, but they seemed to work fine and the little ratchet has a good feel to it.
...The only downside is that the larger wall thickness can make them harder to get into places.
