Thinking about 6V to 12V conversion
/ Thinking about 6V to 12V conversion #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
I'm getting around to the point in the restoration effort on my 1951 Minneapolis Moline BF tractor
http://www.tractorbynet.com/forums/...eapolis-moline-bf-restoration-continuing.html
where I need to get serious about the electrical system. Been wondering if I should convert from 6V generator-style to 12V alternator type. It's an easy conversion.
However, my concern is with the starter-- it's a 6 volt Delco Remy 1109609. I understand that you can run a 6V starter on 12V provided you limit the time you crank the thing. The concern is with the Bendix operating at 12V. From what I read, the Bendix will move faster at 12V than at 6V and might slap the ring gear on the flywheel hard enough to damage it.
Am I worried about nothing? Or is it a potential problem?
/ Thinking about 6V to 12V conversion #2
yes it's a potential problem, and yes.. many do it.
there are alotta 12v fords out there with 6v starters, solenoids and oem bendix.. ya pays yer money and takes yer chances. If it busts.. get a new one.. it might have busted anyway.
soundguy
/ Thinking about 6V to 12V conversion #3
Not sure if it is practical here, but back in the day when they put 12V Corvair engines into 6V Bugs, they used two 6 volt batteries in series, with a center tap between them, so you could run some circuits (the starter in your case) at 6V and other circuits (lights, etc) at 12 volts.
The trick is to have room for two batteries.
/ Thinking about 6V to 12V conversion #4
I have my father's 1950 Avery R converted to a MM BF. I have used it to mow about 5 acres for about 15 years. I use a 12-volt battery and have converted the coil to 12-volts. I haven't changed the generator to 12-volts. The old 6-volt generator is still in place and I disconnected the 6-volt cut-out. After using the tractor, I re-charge the battery with a battery charger. So far I haven't had any problems continuing to use the 6-volt solenoid on the starter or the 6-volt starter. I don't stay on the starter very long when cranking the tractor.
Bill
Thanks for the heads up.
Cool idea. Space for two batteries is no problem on the BF. I should be able to mount them in-line end-to-end. Just have to weld up a new battery tray.
Bill
That's encouraging news. Thanks for the input.
/ Thinking about 6V to 12V conversion #7
you can get commercial 12v start/6v run kits as well.. and I remember you used to be able to get 12v batteries with a center electrodes for 6v taps.. not sure if they still make them..
soundguy
/ Thinking about 6V to 12V conversion #8
forgot to mention.. you can usually get a 6v gen reworked as 12v as well... then just need a new regulator and lamps.. etc. and battery.
soudnguy
/ Thinking about 6V to 12V conversion #9
soudnguy
Yep, that's what I plan to do on my Avery R/MM-BF. It's always cranked very slowly on 6-volts. My father had the starter overhauled, but finally installed an 8-volt battery and used them on the tractor for years before they became impossible to find. After he passed away and I got the tractor, I started using the 12-volt battery to start the tractor.
The only thing I haven't figured out is how to work the cut out and the resistor on the light switch that controls the generator charge rate. I'll probalby install a voltage regulator in place of the cut out and disconnect the resistor. Some of the MM-BFs and the later model MM-BG had a voltage regulator mounted on the 12-volt generator since there isn't much room under the hood at the cut out location next to the ignition coil. I want to keep everything looking original as much as possible.
Bill
/ Thinking about 6V to 12V conversion #10
If you rebuild the gen as 12v vs 6v.. the I would for sure go with a regulator.. as the resistor/tickle setup with the lamp switch won't be calibrated to provide the correct field curent for the new gen.. ( would likely make it overcharge.. )
soundguy
/ Thinking about 6V to 12V conversion #11
One nice thing about converting the 6v generator to 12v is most of the wire harness stays the same as it was. I have a IH Super H that had a voltage regulator not a cut out so it was easy. Unless you hear how easy it starts :) or look in the battery box you would not know it has been converted to 12v.
/ Thinking about 6V to 12V conversion #12
When you folk change these from 6v to 12v, are you just changing that, or are you also converting the current wiring from positive ground to negitive ground?
/ Thinking about 6V to 12V conversion #13
considering most people are converting to 12v via an alternator.. ( usually a delco 10 or 12 SI model ).. then you are pretty much tied to negative ground.
Yes.. you can have a specialty alternator shop build you a 6v or 12v positive ground alternator.. or an isolated ground alternator.. but it's extra work and money.
If you simply use a generator to convert to 12v, then if the regulator is mechaincal.. you can usually retian positive ground.. or change to negative... that's one of the advantages of a dcgen.. you can swap polarities if it has a mechanical regulator.
soundguy
/ Thinking about 6V to 12V conversion #14
Bill
Just in case someone doesn't know it, heavy duty 8 volt batteries are sold everywhere now because they are used in many golf carts.
/ Thinking about 6V to 12V conversion #15
Many of the 8v golf cart batteries I see ( walmart sells them here ) do not comply with group 1 specs..
soundguy
/ Thinking about 6V to 12V conversion #16
Yep, that's why I'm going with the 12-volt generator and a voltage regulator. After these years with a 12-volt battery starting the tractor so well, there is no way I'll consider an 8-volt battery which was still marginal.
Bill
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSENECK TRAILER (A59909)
2022 BIG TEX...
2015 John Deere 825i S4 Gator (A61166)
2015 John Deere...
2023 RIPPA R360 EXCAVATOR (A62129)
2023 RIPPA R360...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
