snow plow hydraulics from Backhoe
/ snow plow hydraulics from Backhoe #1
rims421
Eastern CT
new holland tc- 35
I have a New Holland TC 35 with FEL and woods backhoe.
I want to mount a Meyers 6.5' snowplow to the FEL.
I have already figured out the mount for the plow to the bucket.
The question I have is if it would make any sense to tap into the hydraulics used for the backhoe.
When using the snowplow I would simply pin the backhoe in the upright position and strap the stabilizers together so they will not creep down.
The other posts I have seen all seem to use a diverter valve tied into the bucket curl funtion. (pricey)
I already have a 2 spool control in stock from an old tractor that I thought i could use to control the side to side movement of the plow.
Just thinking I might be able to use somthing I already own and try to save a few pennies.
Does this sound like it would work?
/ snow plow hydraulics from Backhoe #2
why not rig up a solid link to lock the bucket (curl) in place and just use that function off the current FEL control to control left/right.
think about it on a regular truck. you have up/down (lift bucket up down) and left/right)
That sounds interesting.
I thought it might be useful to be able to curl the bucket a little to change the angle of the blade (for scraping packed snow or back blading)
Also I was not sure what position to fix the curl of the bucket till i used it on some snow.
/ snow plow hydraulics from Backhoe #4
You could use the boom to apply down pressure.
You would want to set the curl angle at whatever makes the A frame on the plow level.
Hooking into my FEL curl function sounds like it would be the most resonable way to power the plow. What would be the easiest way to plumb it in to the curl circuit?
/ snow plow hydraulics from Backhoe #6
I think I would just put QD's on the hoses where they meet the cylinder on one side and connect your plow hoses there.
Jeez that just seems to easy and inexpensive to be true.
So you mean I could leave the plumbing intact on the other cylinder and just add a few QD's and some flexable hydraulic lines and be done with it.
/ snow plow hydraulics from Backhoe #8
Pretty much.
/ snow plow hydraulics from Backhoe #9
Here is my take:
Having had a FEL mounted plow in the past, I can assure you that having the curl function of the blade is very important. Very often you need to change the angle of attack of the blade as surface condition vary.
That said, here is the best way to add a valve:
You backhoe is fed by two hoses, You need to identify which hose is the supply, and which is the return-then you can plumb a new valve is series with those lines. Then you just run 2 long hoses (1/4" is all you need) to the FEL to connect to the plow cylinders.
I can get more detailed if you choose this route.
Thanks a bunch for the ideas. It would not be much trouble at all to remove the plow setup when I want to switch to spring mode.
By leaving the other piston still plumbed in I am assuming it will just bypass and the flow will be the the plow pistons. I do not have a lot of hydraulic experience so please bear with me. Am I risking causing any harm to the hydraulics with this method?
/ snow plow hydraulics from Backhoe #11
/ snow plow hydraulics from Backhoe #12
Leaving what pistons "still hooked up"?
/ snow plow hydraulics from Backhoe #13
Hello Rims,
I'm in Massachusetts and am doing something similar with my 6.5' Meyer plow. I've had help from KennyD and 3RRL to set up the hydraulics. The Prince valves arrived yesterday, the loader arm-to-plow bracket are here, and all that's left to do is to weld up a suitable frame over the Meyer A-Frame. The A-frame is the triangular frame that connects the plow trip frame to the vehicle.
I'm tapping into the loader hydraulics to create two front QD remotes for supplying the plow angle cylinders. I also added a cross relief valve to be mounted on the A-frame.
I'd be glad to help you out online, offline, or on the phone.
/ snow plow hydraulics from Backhoe #15
He meant if he only stiff linked one curl cylinder and left the other in.
OK...Bad idea I think. The cylinder make give a little causing the frame to get tweaked.
/ snow plow hydraulics from Backhoe #16
It would depend on wether or not He was going to run down pressure or not.
/ snow plow hydraulics from Backhoe #17
The way i would rig it up is to weld on a set of gussets on the back of the bucket (or QA plate) and a second set on the cross bar right behind that.
then use a 3pt adj toplink to set the distance (also makes it adjustable)
Run a long set of hoses up (from the L/R plow) to the QA points on the FEL control block for the curl function. let the 2 hoses for the curl cylinders just hang or cable tie them to the FEL arm.
That sounds like an exellent idea.
I am only plowing my own property with it.
It is a long paved drive ( approx 500' ) and the rear road out to the shop (crushed stone approx. 350')
The whole thing is pretty much flat.
Using the top link to adjust the curl if needed would be no problem.
/ snow plow hydraulics from Backhoe #19
My plan is to preserve all loader functions, mount my Meyer plow to loader arms directly, add two remotes, add cross over relief, etc. The result is full loader lift, curl, and float functions while angling is handled separately by new remotes. Plow angling is handled by new Prince valve, etc. With big late winter snowbanks, and the need to remove snowbanks, I can just remove the plow, put the bucket back on, and go to work. I will also use the new remotes to run logsplitter, backhoe thumb, etc.
/ snow plow hydraulics from Backhoe #20
Why 2 additional remotes?
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
2019 Toyota Camry Hybrid Sedan (A64557)
2019 Toyota Camry...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
