JD2305 MMM problem
/ JD2305 MMM problem #1
Vin Kelly
My 60 inch midmount mower deck drops 2 inches after the control knob has been set to the highest cutting position. ANY IDEAS AS TO WHAT IS CAUSING THIS?
/ JD2305 MMM problem #2
Vin:
Drops 2" from what? The highest lift from the 3pt Rockshaft control? The hydraulic lift? If it's two inches lower than that that's probably about right.
If you mean once you set the deck height then lower it it drops again then something is wrong.
/ JD2305 MMM problem #3
My guess is that one or more teeth on your height adjustment knob/cog is broken. My mind is drawing a blank as to the exact name for the cog but I have attached a photo for reference. If you remove the mower deck, raise the 3pt, and play with the height adjustment knob while looking on the underside you will immediately see what I'm talking about. One of the teeth on mine is broken and the the deck drops lower than it should. Adjusting the height knob either one step higher or lower is ok. I haven't got around to replacing mine yet as I still need to spend a bit of time assessing how to disassemble to replace most efficiently.
If you adjust the knob one or two steps away does it behavior properly?
If your machine is new, your height knob may not be aligned properly. E.g. the max height is really setting it to the install position instead of max height/install. It may be as simple as a misaligned decal. This doesn't sound like what you are describing, and if this is a developed problem, then obviously this wouldn't apply.
Good luck
/ JD2305 MMM problem #5
I wish Deere would not sell MMM for the 2305. Judging by the complaints it MUST be a poor design.
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
PORTA POTTY (A68842)
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
2014 International 4300 DuraStar Crew Cab Knapheide Utility Flatbed Truck (A68183)
2014 International...
2018 Manitou MLT634 7,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
