Question on plasma cutter
/ Question on plasma cutter #21
I picked up a Powermax 600 at an auction, local trailer manufacture going out of business. Just under $600 out the door which I thought was a pretty good deal considering what these sell for new.
I don't have a good moisture trap system so I put one of these HF dessicant cartriges on the back http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=94733
Rated at 90psi max, (the inlet on the plasma says 120 psi max) so I ran at 90 psi. Cutting some 1/4 it seemed like it wasn't clearing the cut out. Could be technique, this is my first plasma. I noticed the pressure gauge on the unit drops to about about 40 when the trigger is pulled. Am I just not getting enough air across the desiccant or is that pretty normal based on how much air these units consume? I have an 80 gallon 175psi compressor so air supply really isn't an issue.
I work onplasma cnc machines and have found refirgerated dryers work best, wet air will cost you a lot of comsumables, not enough flow will cause poor cuts and can ruin the nozzle if you nick it.
/ Question on plasma cutter #22
OK, but how much do they cost, and how long do they last, and can they be reused.
/ Question on plasma cutter #23
Welcome to TBN:D
For CNC machines that see daily use that is definitely the way to go, but we are talking about weekend warriors here-the machine might get a couple of hours a month.
/ Question on plasma cutter #24
J J
What is the name brand of your CNC machine? Do they have a web site?
/ Question on plasma cutter #25
J J
The company disbanded and the guys went their separate ways. They probably started their own company's with another name.
In reality a CNC machine is a combination of parts put together to work as a unit. The all work about the same way. The little ones cut as good as the large ones. Motors are the same style, maybe heavier. The frame is either aluminum or steel. Software, there is a lot of cutting software out there. and some good nesting programs out there which allow you to save and conserve metal stock. Some even include drawing programs, like BobCad. or Corel Draw.
50 x 50 travel CNC plasma machine.
Torchmate CNC plasma cutters, CNC cutting tables. Automated computer numerical controlled plasma cutting machines cut complex metal shapes.
PlasmaCAM Cutting Systems
Some of these systems, you can purchase complete, and some you purchase a kit which lets you purchase the metal to build the frame. You still have to add your plasma cutter, and a computer.
/ Question on plasma cutter #27
/ Question on plasma cutter #28
I've seen a few plasma cutters pop up on CL from $400-$1,400. What should a person look at to figure out which ones to buy and which ones to leave alone?
/ Question on plasma cutter #29
First thing would be : What capacity do you need?
There are different capacity measurement standards (rated, quality and sever for miller).
"Sever" is the roughest cut measurement. Ugly cuts.
"quality" is its typical max cut, at "slower than normal" speed
"rated" is the typical cut depth at typical speed.
http://www.millerwelds.com/pdf/PCBG.pdf
Remember, alot of companies over rate their plasma cutting capacity.
Second: Brand availability locally. look for something sold local so you can get the consumable tips easily.
Third: Power requirements for the plasma (3phase? Voltage? Amps?)
Fourth: Do research on the specific model your interested in, and see what
others say about the quality of cut and durability.
Go to the welding specific boards like weldingweb, hobart and millerwelds. Youll get your BEST advise there from guys in the know.
/ Question on plasma cutter #30
I met a guy last week who was milling some aluminum brackets in a piece about the size of a postcard about 3/8 inch thick. There were three larger holes to cut down on the weight and then a couple of holes for screws for it to attach to a larger assembly made out of polycarbonate. One of the sides had a radius in it. I forget, but it seemed like it took the CNC machine about 1.5 hours to make this part.
JJ's post in this thread got me wondering if the same part could be made (maybe not the screw holes) with a computerized controlled plasma cutter more cost effectively? One of the things the guy complained about was having to buy German cutters that used to cost $370 last year that is now up to $550 or something. I'm sorry for the vague description --metal working is not something I know much about. I only understand small bits and pieces of it.
/ Question on plasma cutter #31
CNC plasma could work. I have no idea about how well plasma would work on aluminum (how clean are the cuts?) as ive only used plasma on steel.
There is going to be a quite a cost to set up a CNC system, especially if its going to be a commercial one, so that might rule it out.
Then theres the level of precision thats going to be required for these holes?
These are great questions for the guys on the welding forums. Alot of those guys are in the industry and could give more definitive answers.
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
NEW Wolverine 72" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 72"...
Skid steer Backing Plate (A62679)
Skid steer Backing...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
