Oil & Fuel oil pressure jm 224
/ oil pressure jm 224 #1
jaroban
TX
Kioti dk40se
I installed a new mecanical oil pressure gage last week. I was using a 5 ft finish mower this morning. At start up oil pressure was 60. After mowing for about thirty min. the preasure was around 35 psi at 2000 rpm. Is this normal? My old factory gage never moved very much. Thanks for the input, Robby
/ oil pressure jm 224 #2
Depends upon how cold it gets where you operate the tractor. If I saw 60 psi on one of my tractors when starting on a September morning, that would give me pause as to how high it might be on a January morning. But if you're in the sunbelt somewhere, those numbers seem perfectly safe.
//greg//
/ oil pressure jm 224 #3
Yea, I think you are safe. The rule is about 10 psi min per 1000 rpm. The oil is going to thin as you work the tractor and the oil heats up so its only natural the pressure will drop. If it was below say 20 psi at 2000 rpm then you have a problem.
Chris
/ oil pressure jm 224 #4
Chris
I have a problem with a brocken oil pressure sending unit that bolts on lower left side of engine on my Jima 204 .Can anyone help with a cross reference no. It is round and has two wires on it.I think the gage on dash is a New Holland part.Gage shows highest reading when key turned to on and engine not runing or when running.Thanks.Meaford man. ken.galliford@ rogers .com I am in Meaford Ontario Canada
/ oil pressure jm 224 #5
Why does it have a NH gauge? Probably at this point the best thing you could do is go to the auto parts store and buy a $15 mechanical gauge or if you want he oem Jinma gauge contact one of the dealers on here and order both the gauge and sending unit.
Chris
/ oil pressure jm 224 #6
/ oil pressure jm 224 #7
Tommy, Yes that is the sending unit that I need but I'm in Ontario Canada and was hopeing for a cross reference number so I could get it at a local auto supply store.Do you know the number for that one? It fits a Jima 204 3 cylinder 380yd11 Yang dong engine, Thanks for help.
/ oil pressure jm 224 #8
Sorry,I don't have a cross reference number,did you take yours to the auto parts to try and cross it?
Tommy
Affordable Tractor Sales
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
WATER TRAILER (A58214)
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Peterbilt (A60352)
2001 Peterbilt...
