What tools on your tractor?
/ What tools on your tractor? #41
The pic was one my daughter took while backing the wife's deanil down the block long driveway that has a few twists and turns in it.
As for stabbin the ball under the trailer, if thats what your talking about, I have no problem handling that one, no dents in the bumper or tag either.
No camera needed here for trailer hookin up, Its actaull a pretty easy process, that I have done a few thousand times in my life it seams.
If avitars were in realtion to our tractor experiences then your would make you a tractor voyeur?
anyone know of a handy mounting braket for a fire supression device? perfer to have it on the rops
Doesnt anyone read my posts? :rolleyes:;) Check post 36 above to mount your fire extinguisher. :)
/ What tools on your tractor? #42
Where ya got it was my question?
hose clamp idea i read in another post long ago, its a good one. i actully carry one in the truck and one on the trailer but dont have one tractor mounted.
/ What tools on your tractor? #44
On second thought, I suppose all you need is a metal bracket for the top nozzle to sit in, then just use a zip tie. That way, when you need it in a hurry, a quick tug and the zip tie would break.
/ What tools on your tractor? #45
Yep, I have a bracket (came with my Kidde extinguisher) that holds it just like the one shown at the very top of the page (and listed down below). But, in the brush, or with enough vibration (?) you may accidentally open it up....therefore I put a bungee cord around it to hold it in place. Never had a problem as such....and the bungee cord also holds my loppers.
I believe most fire extinguishers are available with a wall type bracket and with "vehicle-type mounts".
/ What tools on your tractor? #46
OK....a pic is worth a thousand words. ;) This is an old photo before discarding the HF quick (?) hitch.
/ What tools on your tractor? #47
A lot of you have mentioned fire extinguishers mounted to your tractors and some of you (thank you foggy1111) even posted a pic ! It does make sense. I was at the PX today and they sell the little ones for $14. It only makes sense to secure one to the ROPS.
MissouriThunder
/ What tools on your tractor? #48
Workin sorry I was making a joke. I was meaning you look stuck in that position from how we all have to twist on the tractor, to operate things on the 3 pt hitch.
/ What tools on your tractor? #49
Fire Ext. bracket: 3" or 4" PVC pipe (size to fit your ext.). If you glue a cap on the bottom of the pipe, drill some holes in the cap to let dirt and water fall out. Stuff a piece of foam rubber in between the fire ext. and the pipe to keep the ext. from bouncing and vibrating. You don't have to use a pipe cap on the bottom, a cross bolt or flat strap will do. One advantage to the pipe "bracket" is the ext. is easy to just lift up out of the pipe when you are in panic mode fighting a fire, no need to release a strap or unhook a bungee. Use just enough foam rubber, or piece of sponge, whatever, to hold the ext. just tight enough that it doesn't bounce around, but loose enough so it will slide right out. Most small extinguishers are aluminum, and if you put it in the pipe with no cushioning, and it bounces and vibrates, it will wear a hole in the ext.
jp
/ What tools on your tractor? #51
If you ever find yourself by Ft Riley or Ft Leavenworth, let me know - I live about halfway between them.
I was stationed at Ft. Riley for a couple of months before my unit shipped out to Vietnam back in the day. I wish that I had gotten a chance to see more of that country.
My toolbox looks like most others here, though I've read some suggestions that sound good. A few retaining pins, and a punch will fit, and the fire extinguisher is a definite addition. I'm still using just the tiny box that came on the tractor, and I need a larger one.
/ What tools on your tractor? #52
Just curious; did your ROPS come with a place for the toolbox or did you add it?
Wm
My tractor did not have a tool box of any kind....and very few places (if any) to mount one.........so I made a bracket that fits between the ROPS to hold the box. It's bolted on, and sandwiches the ROPS without drilling any holes. I have a post on it under another topic. (there is also another post - where I got the idea)
/ What tools on your tractor? #53
Oh ya one key thing in my box i forgot to mention, BUG SPRAY!!!, freakin squitoes were horrible this weekend
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2004 INTERNATIONAL 9400 T/A DAY CAB ROAD TRACTOR (A63291)
2004 INTERNATIONAL...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2014 STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
2014 STARCRAFT...
