Questions on buying used tractors.
   / Questions on buying used tractors. #1
msjwebb
Virginia Beach, VA
How many hours of use before you start seeing major problems (typically)? 1k? 7k?:confused:
I know this is all relative to how well the owner takes care of it so lets say they did not do the proper maintenance required.
Do tractors have titles? If not how do you prove "ownership" is free and clear? :eek:
   / Questions on buying used tractors. #2
Major problems can start in 1 hour depending on if the owner knows what he's doing or not.. or.. the tractor might go 3000 hours with no oil change and be more or less, operable. I buy antique tractors all the time that I'm quite sure have had the same oil in them for decades. Back in about 2003 I had a friend call me up asking me to mow his pasture.. I remember seeing a small ford compact in his barn.. looked a lil beat.. but not bad.. I asked him why he didn't mow it.. he said tractor didn't run.. I went over there.. put battery on charge.. aired up a tire.. fixed a leak in the rear that was a loose bolt, asked him when he changed the oil last.. -never- it was new in 84.. we went and got filters and oil and changed them... machine cranked up and was mowing an hour later...
Look at the overall condition of the machine to determine usage. A well maintained machine that is older with more hours may be better than a newer rental that has been abused.
on a compact diesel.. I'd start looking for some things around 4khrs.. on larger diesels.. double that maybee tripple for a good lifespoan before something expensive goes.
always gonna have wear items like hoses and belts go at any time old or new..
soundguy
Thanks soundguy.
Do tractors come with a title or just a bill of sale? I have not gone to the local dealers yet and done any test drives yet. Still trying to figure out what the best one for us will be. Not sure if we are going new or used. I know you are probably going typical woman does not know what she wants.....so yes I do not know what I want as I am still unsure what I need. =P Thanks for all of the help guys. I think I am going to be clearing the property lines this weekend, I hope I do not see any bears..... Have a good weekend all.
   / Questions on buying used tractors. #4
They normally don't have a title, just a bill of sale.
Thanks dodge man. I did not want to end up buying a used one only to later find out later I should have gotten a title with it. This is all new to me. I used tractors that were on the family farm but never had to buy one. My dad would always get ones that were dead and rebuild them.
   / Questions on buying used tractors. #6
Larger machines typically do not have titles, but have "certificates of origin".
Hours are a real slippery slope. I bought a New Holland backhoe with 5,800 hours on it that is in beautiful condition. I had a Case backhoe that was handled pretty rough for its' first 1,000 hours.
If you are worried about the hours being high, try to get as much records on maintenance as you can. Fortunately, the NH backhoe I bought was serviced by a dealership that vouched for the owner as being overly preventative on maintenance and faxed me records. The owner also made labels with a label maker and stuck them to the lower windows in the cab indicating last time oil, trans oil, hydraulic fluid, etc. were changed.
   / Questions on buying used tractors. #7
I buy used tractors periodically. I have the seller sign a bill of sale stating that he is the owner of the tractor and is legally entitled to sell it. Be sure to ask for picture ID. Driver's licence is OK. Write seller's license number on the bill of sale under the his signature.
You run into snags trying to figure out tractor engine hours--hour meter isn't working so what's indicated has no relation to actual hours--engine has been rebuilt X hours ago according to the seller but he doesn't have any documentation with date and engine hours at the time of the rebuild. You get the idea.
If the hour meter isn't working then you're sorta flying blind. If you're looking at an old gas engine tractor, I suppose you could do a quick compression check to estimate if the engine is putting out anywhere near it's design horsepower.
   / Questions on buying used tractors. #8
Soundguy pretty much nailed it. I've seen rental tractors with 10 hours that weren't worth the fuel it took to start it. I've seen tractors with 10,000 hours that were almost like new. Certain models have histories of long life. Certain ones are clunkers after a year. No set rule, only that an abusive operator can shorten the lifespan of the best of 'em.
On average, most "farm tractors" will see 5000 to 7000 hours with little problems. A little extra maintenance, and it's not uncommon to see them reach 10,000hrs without the valve cover or oil pan being unbolted. Smaller tractors, which seem to be using more high rpm motors now than in the past, might not see 4000 before they start tailing off in power and performance.
Thanks guys! Those were the only two things I was worried about with buying a used tractor. DH is quite the handy man and is good with engines. I know I will be looking for a newer used one. I might even spring for a new one if I can swing a deal. I want a Kubota and he wants a JD. Only time will tell. Thanks again guys!
   / Questions on buying used tractors. #10
Used tractors are always a gamble, and with time you will learn when to hold them and when to fold them. The last one I sold was a 1970'ish Ford 2000 deisel. It had around 7000 hours and was beginning to develop an ether addiction. The guy I sold it to (for a couple hundred more than I paid for it 10 years earlier with 3000 less hours) seemed very happy with his deal. The tractor didn't owe me a dime, but I got rid of it before it became a money pit. The best deal I ever got on a used tractor was a 1951 Ford 8n, with most of the original paint and only 1200 hours that an elderly neighbor had purchased new, always kept in his barn, and only used to work a small garden each year. That tractor was basically just broken in when I bought it 20 some years ago for $1200 bucks and after replacing the original valves (they cant handle unleaded gas) it has not given me a bit of trouble. No one makes a tractor as durable today as those n's, but it is tough to find one in that kind of condition since it has been so long since they have been made. When buying an old tractor that came 6 volt from the factory, be very leary of 12 volt conversions as they usually are a cover-up for poor starting due to weak compression. I would also be cautious of any used tractor that you dont know the history. Why is it being sold? With my 8n, the owner passed away and I bought it from his widow (that is a good excuse).
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Deere 35G (A53317)
Deere 35G (A53317)
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
