Boosting Horsepower
/ Boosting Horsepower #1
gav64
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
I have a mahindra 2810hst with a daedong engine, when mowing and going up hill the engine starts to bog out, any ideas on squeezing out a few more hp out of this particular engine. It has been a good dependable tractor and is 6 years old and out of warranty. The only beef is that it is under powered, wish I had the extra money back then to go with the 35hp model.
/ Boosting Horsepower #2
Gav64,
Maybe let it breath better with a bigger air filter. Air filters are always a good cheap place to go for more power. Is the airfilter clean? Check out Welcome to Agricredit for some good used auction tractors in 30 and 35 hp.
hugs, Brandi
/ Boosting Horsepower #3
More power and dependability do not mix:eek:
We can put a 35 injector pump and injectors in it at the tune of I'm guessing around $1,500
I would have to dig much deeper if this is something you would want to do.
/ Boosting Horsepower #4
Slow down. We have TYM 330 HST alias Mahindra 3510 with 33 HP Kubota engine with the same issue. Initially when it was new I always instinctively pushed on the pedal when it started to bog down. I quickly learned that with HST you should do the opposite.
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
SHOPBUILT 3PT CULITVATOR FRAME (A64278)
SHOPBUILT 3PT...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
