Welding + Brake Cleaner = DEADLY
/ Welding + Brake Cleaner = DEADLY #1
RWEST
Gold Member
Windber, PA
ALL J-D's: 955, X595, 6x4 Diesel Gator, CX Compact Gator, 310D Loader/Backhoe (4x4, turbo, extend-a-hoe)
Got this at another forum - a guy was welding some parts that had been cleaned with brake cleaner, it produced phosgene gas!!! :eek:
/ Welding + Brake Cleaner = DEADLY #4
Yep. Chlorinated solvents plus high heat is bad.
/ Welding + Brake Cleaner = DEADLY #5
Thanks for the warning.
/ Welding + Brake Cleaner = DEADLY #6
To say the least, if you are exposed, don't play macho-man. Get medical help. Symptoms may take up to 48 hours to show up. And be very careful of clothing, it can absorb the gas and contaminate others, like taking it home with you to the kids.
Other chlorinated compounds are bad news too. Carbon tetrachloride is a slow, slow death. A family friend working for the navy in WWII was exposed for years maintaining ship compasses. The Navy turned their backs on him. His lawyers made them pay up for his care.
/ Welding + Brake Cleaner = DEADLY #7
Ive worked with a guy who spent his day handling perc in heated dip tanks for electric motors. Aweful what those solvents can do. Most of those guys had some form of cancer.
Even brakeclean or carbclean should be handled with latex or nitrile gloves. Just look at what happens to the nitrile after a few mins contact. Now imagine its your liver. Green Solvex gloves are what i usualy wear when handling carb or brake clean if theres any chance ill come in contact.
Or try spraying some brake clean at a flying insect....
/ Welding + Brake Cleaner = DEADLY #8
Thanks for the warning, good to keep in mind there are many things we take for granted or have become complacent too.
Scarey stuff.
Joel
/ Welding + Brake Cleaner = DEADLY #9
Thanks for the warning!
/ Welding + Brake Cleaner = DEADLY #10
There are a lot of hazards in welding though I mostly think of the vaporized heavy metals and explosive gases. I have wondered why welders generally don't have remote air supplies particularly if they are welding dirty mystery metal.... a little old cadmium plating could ruin the future although not nearly as fast as phosgene.
Just handling volatile fluids can be problematic, when trying acetone on Versatex (a PVC construction material) the acetone did an excellent job of penetrating the thin nitrile gloves I was using. The nitrile works great with greases and oil (as in oil changes) though... perhaps Solvex at 22mil, although quite expensive, would work better with acetone. [the acetone wasn't effective with Versatex in my opinion. The purpose was to seal the surface so that crud would not soak into the pores and stain the surface over time. Heat might work if I could adequately control the temperature]
A lot of the skin absorption numbers are based on the palms of the hands, and volatile compounds will be absorbed faster through other skin areas. I remember one guy would clean off grease using the conveniently available solvent ... gasoline:eek:... and leaded gas at that! (tetraethyl lead is a good way to get lead poisoning). I told he was daft to use gasoline as a solvent for him and his kids:eek:.
/ Welding + Brake Cleaner = DEADLY #11
Solvex are cheap. I get them under $2 a pair. Plus they can be reused many times. (think heavy dishwashing gloves)
/ Welding + Brake Cleaner = DEADLY #15
Thank you for the warning, I didnt know that!
/ Welding + Brake Cleaner = DEADLY #17
Years ago I had been doing brake jobs in my garage and had a bad cold as it was in the winter. My friend came over and we changed the ring an pinon gears in his blazer. He started to coughing and then could not hardly breathe as his lungs were filling with fluid. At the same time, we realized what was happening. The brake cleaner we had used to clean the axle housings with was reacting with the flame on my propane heater. My cold was not a cold after all. My friend just reacted worse than I had. I prefer to use chlorinated cleaners but now never around open flames and will not when welding now.
/ Welding + Brake Cleaner = DEADLY #18
Wow... That sounds really scary. Now that I read the entire story (thanks for the link), I think I have had some of those symptoms before.
I need to run now, to get the exhaust fans hooked up in my garage!
/ Welding + Brake Cleaner = DEADLY #20
While we are at it, lets look at what goes wrong when a compressed gas cylinder goes BOOM!
YouTube - MythBusters: Air Cylinder Rocket
YouTube - O2 CYLINDER EXPLOSION
I used to work for a telephone company years ago. To make some extra money I had an occasional job helping a guy installing the batteries for the telephone switches. When the cells were assembled they were connected by led bridges welded with Hydrogen/Oxygen torch.
One time we were assembling two batteries at some plant and needed to move our stuff from one building to another. My boss and I carried the O2 bottle and local maintenance guys were carrying the H2 bottle. My boss told them to put the valve cover on it but it was ignored saying it is easier to carry without it on. While walking across a railroad track one of the guys tripped, they dropped the bottle and the valve hit the rail and broke off. The bottle flew into a maintenance building made round about a foot big hole in the brick wall then hit a work bench inside of the building and pushed it out on the other side making about garage door size hole there.
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
APPROX. 40'X40' COMMERCIAL GRADE BUILDING (A62131)
APPROX. 40'X40'...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
John Deere 4240 w/ Buhler 695 Front End Loader (A64047)
John Deere 4240 w/...
ROLL OF 5' CHAINLINK FENCE (A62131)
ROLL OF 5'...
(APPROX. 500), GALLON FUEL TANK (A62131)
(APPROX. 500)...
