How much incline is too much?
/ How much incline is too much? #1
slate mike
Member
I have a JD 3120 with loaded R4 tires and FEL. With a Frontier 6' finish mower on the 3 pt hitch, what kind of incline mow across (keeping the fel low?) Thanks for the help. Been doing the 3 acres all Summer with a Cub lawn tractor(46"and would realli like to cut down the time and give the 6' a chance but haven't yet due to the side hills.
/ How much incline is too much? #2
15 is the rule of thumb MAX. Life on the edge is not good though. Mow up and down if you are at all worried. Speed will make up for inefficiency
/ How much incline is too much? #3
I mow a 25* cross slope using a NH TC24DA unloaded turfs and 60"MMM but NO WAY would I leave the FEL on!! up/down no problem...but cross slope:eek: Just my opinion:D
However...you mention a 3 pt mower. Years ago a buddy of mine had a JD??/something and used a 3 pt mower on a 20* slope. His only complaint was 3 pt mower felt like it was dragging the back end of the tractor downhill and he always had to compensate using the brakes and steering
/ How much incline is too much? #4
Indeed bucket low.
Old timer told me once.."If your high rear tire spins more than couple time mowing side ways your to steep"..but that was for 2WD.
/ How much incline is too much? #5
I asked this question to John Deere via email years ago and they referred me to the dealer. Could not get a straight answer from the dealer either but I can see why since there are so many variables involved. I've resorted to loading the tires on all my tractors. On steeper hills, I mow up/down and not across.
/ How much incline is too much? #6
I mow a 20 degree cross slope with a JD2520 with a 6 foot rear finish mower. As mentioned in one of the other posts, it drags the rear end of the tractor down hill, however, it does not feel "tippy" and I've gotten used to it.
I do have to keep it in 4WD and drive the machine with a "crab angle" like flying a plane in a cross wind. I also keep the 200CX loader frame on, minus the bucket.
Not sure how this experience relates to a 3120 since that is a taller machine, but with loaded tires, I would think it would be OK. Just have to try it...slowly... and see how it feels I guess. ROPS up and seat belt on....
Best of luck.
/ How much incline is too much? #7
I was able to take a 15 - 19 deg slope horizontally in my 4310 OS, but with my 3520 Cab - it was too scary:eek:. So i just mow vertically on anything over or approaching 15 deg - Yes I am chicken big time about the potential to suddenly fall over or tumble down a hill. Play it safe and trust your inner scare-O-meter, I believe the medical term is the "Sphincter":eek:
good luck and be safe!
/ How much incline is too much? #8
As suggested I would mow up/down if you can at all. I am box blading a hill at my place that is probably easily 45 degrees (3520 so same size), and if going up/down it is simple as pie. However, 20 degrees horizontal is out of the question. I have some smaller "banks" on my place that are about 20-30 degrees and I won't even touch them with the tractor. I leave those to the dozer when I have access to it. I love my tractor but I have scared myself way too many times on it and the thing is I am pretty darn careful. It is just VERY tippy.
/ How much incline is too much? #9
Think you will find you can handle more slope going down hill than up hill. Not many roll over forward but with FEL may be about same going uphill. I really believe a tractor handles more of a slope than the operator does. Watch the angle we use a tractor and blade on a hill of dirt.
/ How much incline is too much? #10
When running near your max comfort angle you also need to consider if the upper wheel goes over a bump or the lower wheel drops into a hole or soft ground. Either one increases the tilt angle and the faster you are going the greater that increase.
2003 Freightiner FLD120 (A61307)
2003 Freightiner...
2011 Deere 50D (A60462)
2011 Deere 50D...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
iDrive TDS-2010H...
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
