TA T/A ? (quick dumb question)
/ TA T/A ? (quick dumb question) #1
BCJohn
IH Hydro 86, MF35, MF135
I've searched a lot about my Hydro 86 and can't figure out what the TA or T/A is. Is it the speed setting control and if so, what does TA stand for?
Thanks very much for any help
/ TA T/A ? (quick dumb question) #2
T/A = Torque Amplifier. Shift on the fly Hi/Lo. Works good when working. Money pit when not.
/ TA T/A ? (quick dumb question) #3
Torque Amplifier. It was IH's term for a two range shifter that you don't use the clutch for. I doubt if it was available on their Hydro tractors, just gear drives. Started out on the Farmall M (MTA) and stopped maybe in the 86 series or later gear drive tractors.
/ TA T/A ? (quick dumb question) #4
Torque amplifier, it has gear reduction on the shaft in the transmission that lowers the speed and increases torque most T/As will not hold you back in a hill in low. and you don't have to use the clutch to shift it.
/ TA T/A ? (quick dumb question) #5
I guess the IH T/A is equivalent to Massey Ferguson's Multipower shift on the fly setup. Both features showed up in the 1960s, IIRC.
/ TA T/A ? (quick dumb question) #6
I know but the IH is cheaper to fix it's a self contained unit that comes out in one piece I think Formsprag made them for IHC
/ TA T/A ? (quick dumb question) #7
T/A's built after 1963 do not freewheel, at least the ones installed on 70 HP and up tractors, and those installed on Doncaster-built utility tractors. The original mechanical T/A will allow freewheeling in T/A mode, but except for a very few models, this type disappeared from new tractors in 1963.
And certainly no hydrostatic drive IH's ever had a T/A.
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
CROP CARE PLASTIC PLOW / LIFTER (A63291)
CROP CARE PLASTIC...
