Oil & Fuel oil sending unit jm224
/ oil sending unit jm224 #1
jaroban
TX
Kioti dk40se
Has anyone bought an after market oil sending unit at there local auto parts store ? correct me if I am wrong. I assume that as long as you get close to the right ohms reading it will work. Thanks Robby
/ oil sending unit jm224 #2
If you have the single gauges and its a single wire unit I did so at AutoZone.
Chris
Chris
I do have the single wire unit . I will try to get one . If I cant I will give Tommy a call. Thanks Robby
/ oil sending unit jm224 #5
For Tommys price I would get the OEM one. I was in a pinch with a actual broken sending unit that was spaying oil everywhere.
Chris
/ oil sending unit jm224 #6
I have the single gauges, I changed to a pressure gauge with the oil line running to it. It reads in lbs. now instead of bar. Real simple to change and I think cost was $10 or around that.
/ oil sending unit jm224 #7
I have the 284 jinma with the new gauge cluster, with the single wire off oil pressure unit, and I have a gauge tester that operates the gauge in OHM and my reading was 235 ohms giving me 10 mpa.
this should help you to find a unit..
I also have the single gauges. I did just as you suggested. I changed to a pressure gauge with the oil line running to it. less than $15.00 and the gauge is lighted. Thanks for the input, Robby
2020 DRAGON ESP...
Electric Golf Cart (A56859)
Electric Golf Cart...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2016 Ford F-250 Service Truck (A61568)
2016 Ford F-250...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
TANK MANIFOLD (A58214)
