Best 12V tap-off where ?
/ Best 12V tap-off where ? #1
bcarwell
Gold Member
Austin, Texas
Kabota 7500DT
I have a Kubota 7500. I can see the need for attaching various 12v thingies-spotlight, sprayer, cocktail mixer, radio, etc. I don't want to hardwire them all in (maybe just the lights, radio), but want to have a 12v access point to plug some of these things in as needed.
Where is the best place to access 12v on my Kubota and what kind of panel/terminal bar/connectors would you recommend. I've seen some appends (recently about adding floodlights with magnetic mounts) where they accessed under the seat and used a weatherproof sealed cigarette lighter socket (not a Kubota I don't think). But that seems to be a pain having to have a cigarette lighter plug for every accessory. I've also seen from auto parts stores some things that attach to the battery terminals to provide auxiliary wires, though that seems to have a downside of not being routed through the tractor's fuses and on/off switch.
Any ideas ?
Bob
/ Best 12V tap-off where ? #2
The electronic stuff you add typically has an inline fuse..and an on/off switch.. so attaching to the battery + terminal can be a fused connection. I don't have the same tractor you do, but used this technique to locate existing 12V connections:
Get a voltmeter... HF has them for about $4 on sale if you don't have one.
Hunt for wires that are not connected to anything.... under hood, under seat, behind the instrument panel.... there will be some somewhere.
check with key on to see if 12 V is available at that connection.
If so, remove various fuses until you discover which fuse it is....and the fuse size...
Determine if enough amps are available thru this wire for your equipment.
If you can't find a fused wire with sufficient amperage, you will have to run one from the battery.
As for connectors, etc... an auto supply is likely the best...just watch and make sure you are matching components with amps drawn. Lights draw lots of amps.
/ Best 12V tap-off where ? #3
Go right to the battery terms and FUSE your new equipment with the right amperage fuse. You can get yourself in trouble tapping into existing harnesses. If you're not sure what you're doing (and if you don't own an ohm/volt meter...... you don't), tap the battery.
Be careful.
/ Best 12V tap-off where ? #4
If you want to have switched 12v from the keyswitch...then what I would do is get a 30A Bosch relay and run a 12ga wire from the pos battery terminal through a 30A ATO fuse to terminal 87 on the relay. Terminal 30 will go to power post which you will mount somewhere in the engine compartment which is where you can hook up anything you want (up to 30A) to receive switched power. To trigger the relay, you will hook up terminal 86 to ground and then terminal 85 will go to the "run" position of your keyswitch. Now anytime you need to add an accessory which needs power you can get it off the power post you installed without disturbing any of the original wiring. If you need constant 12v then just go directly to the battery post and use an appropriate fuse. If you want to have quick disconnects for your accessories then go to a marine hardware store and they have all sorts of weatherproof connectors.
Thanks to all for taking the time to provide some really helpful input. I'm an EE and have a VOM but diddle with auto wiring just enough to be dangerous. Thanks again fellas.
Bob
/ Best 12V tap-off where ? #6
Apologies for lecturing you on voltmeters, how to determine fuse capacity, etc. :eek:
For the wench I occasionally connect to the tractor, I ran a BIG hot wire from the terminal back to a manually switched 30A fuse in the cab with terminal block. I couldn't believe the fuse cost $40 or so...
/ Best 12V tap-off where ? #7
I realize this is an old thread, but I'd like to do similar to my B7610, probably a cig lighter to power two LED floodlights at first.
But I'm confused -
How often does one hook up a wench to a tractor?:)
/ Best 12V tap-off where ? #8
Just after posting the above I found:
Hey Phil,
Try this:
http://www.tractorbynet.com/forums/...-removeable-lights.html?highlight=rops+lights
I bought a two pack of the lights at Harbor Freight for $7.99 along with the two magnets for $5.99 each. I had three 20% off coupons so the girl at the counter did three separate purchases. I would say for under $20 it solved my problem. Only thing I see as an issue is that if you're not careful the magnets will mark up the paint on the tractor. My solution? I don't mount them to anything I don't want marked up. :)
Here's a link to the lights:
On a B7610 there is a wire under the seat to connect the lights. From what I've heard the BX models have a similar connector. The nice part about the magnetic lights is that you can mount them just about anywhere. I have yet to have one fall off while working. I plan on using them for snowblowing. They definitely light up the night! And the price is right.
Good luck!
Keith
Kubota B7610
However I've seen discussion about NOT using that because it prevents fuel solenoid shutoff.
Any ideas?
/ Best 12V tap-off where ? #9
When doing auto/tractor wiring, you're almost always better off running your own stuff, except for signal wires. In other words, if it has any load (lights, etc), go to the battery, add a fused circuit. If there's any real load that needs switching, also use a relay. Make sure both the signal wires used from the switch and the power wire to the relay is fused. If your signal wire is from an existing switch, it's already fused.
Auto parts stores carry 30-amp relays that work just fine.
Since you'll be using a relay, you can use any switch you want to.
By doing it this way, you don't have to worry about how much amperage is already on a circuit. The only thing to worry about is total amperage and whether your alternator can keep up (and if you care).
It's a little more work, but it will just work.
Also, if something goes wrong with your accessory, you know which wiring it's in, and it won't disable your tractor.
When I wired up my work lights and strobe, I used the existing switches, but added my own fused, relayed circuit. That way, I didn't have to add any switches. When I turn on the headlamps, the work lights come on, too. And, when I turn on the flashers, the strobe comes on, too. Saved the trouble of finding a place to add switches, drill holes, etc.
/ Best 12V tap-off where ? #10
...hook up a wench to a tractor?
A wench...she'd appreciate you using the seatbelt.
A WINCH...I'd probably make my own connection to the battery (using an in-line fuse, of course) and whatever switches were necessary.
I used my BX for a hay ride last Halloween and installed a cigarette lighter to the battery. It just dangles behind the removable panel at my feet since I use it so seldom. This was easier than tracking down another wire that was hot at the right times, making sure what fuse was on it so it wouldn't blow, etc.
I'd keep it simple.
/ Best 12V tap-off where ? #11
/ Best 12V tap-off where ? #12
Not sure about the other accessories, but for the drink mixer you don't really need an electrical outlet. They appear to be available for nearly every brand of tractor. :)
/ Best 12V tap-off where ? #13
I've added heated seat to my truck and to do that I bought an adapter that plugs into the mini bayonet fuze block. You simply identify a fuze that's on a switched circuit, remove that fuze and slip the adapter in. You reinstall the previous fuze in one slot of the adapter and the fuze for the new circuit in the other slot. Each fuze can be a different amperage.
I'm now looking at adding a radio to my B26 and I'll probably go that route when looking for a 12v source.
/ Best 12V tap-off where ? #15
Cars and trucks have a ancillary switch position for powering such devices. On the ignition switch on my kubota, the pre-position is reserved for the injector heaters, after that the switch rotates to a springloaded crank-on. I don't want the injector heaters going while I'm running power off the 12V outlet.
On my JD 425, I wired it in as BXRICK suggested, right off the battery with a fused line. This has helped me on numerious times as I don't need the key or to position the key to get power. I've often pulled over some inflatable toy to the mower, plugged in the electric 12V air compressor and let fly.
I plan on doing the same to my Kubota B2920.
/ Best 12V tap-off where ? #19
Looks like you already have enough advice....but I'll throw in my half ddollars worth (inflation).
On the BX Series the factory left a couple of wires open at the left of the tractors top link that serve me well for attachments such as electric pump sprayer. If you want to be more neat and more permanent...I would pull a wire from the fuse box (use a fuse in box or add one)...or tie in from an existing hot wire. When I use this methos I always Tie in to wire(s) that are hot only when the switch is turned on.
Or, run direct from battery to a new fuse block. This way you can add as many circuits as you want. The only limit is the Block size. The Fuse Blocks can be bought at most any Automotive Parts House. I did this on my Ford 3000 and the Cub 3186 as well. The pull a wire from the new fuse block to whatever I want.
The Bosch Relay method is a very good idea if I want something totally seperate from everything else. Again, it can be run from the fuse block.
Good Luck!!
I almost forgot...some Kubots models had a "Cigarette Lighter" type plug in located directly under the seat to the right...My BX 1860 has this.
