99% finished on the 3000
/ 99% finished on the 3000 #21
. Meanwhile, paint removal work (really boring).
Good Evenin Ray,
Its all worth it the day you fire her off and park her out in the field under that late afternoon sun light ! :)
I know it was for me ! ;)
You gotta keep that vision in the back of your mind ! :rolleyes:
/ 99% finished on the 3000 #22
Good Evenin Ray,
Hi Scott
I hear ya. I'm working through a pile of BF parts in my shop getting them ready for primer and paint. Figure another 2 weeks to finish the cleaning job.
I have to finish restoring that BF. If I don't, I can't justify buying a one-ton flatbed truck and gooseneck trailer to haul it to the club's parades. And I really, really want that truck and trailer.
Looks great. You're one quick puppy when it comes to getting your old iron painted and the tractor back in the field.
Seems like it takes me forever to make progress on my restoration projects. Last week the engine for my 1951 Minneapolis Moline BF went to the machine shop (cylinder honing, 0.020" oversize pistons/rings, 0.010" off the crankshaft, 0.010" undersize main and rod bearings, exhaust valves, valve seats for unleaded gas; flywheel, head, block ground flat). Ordered the parts today. Crankshaft machining this week. Hope to have the engine back together late next week. Meanwhile, paint removal work (really boring).
Once I get the mechanicals going.. I try to do the body work and paint fast.. lotsa rain here and exposed metal rusts fast.. thus i tend to work on a part and prime it and sometimes hang and paint it in the barn, then fit it up later.
soundguy
/ 99% finished on the 3000 #25
soundguy
Makes sense to me. Rain and rust are no problems here in the North Sacramento Valley from June to October. Bone dry and hot.
rain near everyday here...
soundguy
/ 99% finished on the 3000 #28
Hey Soundguy,That's an excellent job you've done there!
Maybe you could help me with my 2600 gasser,with a Holley carb.I'm looking for and exploded view of the carb.I installed a rebuild kit and it runs better than before but, I think the float spring is on backwards.
Do you know of any good resources on the web?
The cnh website has exploded diagrams of just about every part or assembly from all ford/fordsons from 39+
here's the parts list.. took me 2 seconds to find it and the pic...:
2600 3 CYL AG TRACTO / 09G01 CARBURETOR ASSEMBLY, HOLLEY
Key Qty Part Number Part Name Description
1 1 D8NN9510AA CARBURETOR Carburetor Assy. 2600, 231, Start Year: 01/01/1975
1 1 D8NN9510BA CARBURETOR Carburetor Assy., 3600-335-420, 3500, Start Year: 01/01/1975
1 1 D8NN9510CA CARBURETOR Carburetor Assy., 4600, 4600SU, 515, 531, 535, Start Year: 01/01/1975
1 1 D5NN9510A CARBURETOR Carburetor Assy., 6600,6600C, Includes: Ref. 1 thru 46, Start Year: 01/01/1975
1A 2 88382S8 STUD Stud, 3/8"-16-24 x 1.38, Start Year: 01/01/1975
2 1 C9NN9581A LEVER Lever & Shaft Assy., Throttle, Except 6600, Start Year: 01/01/1975
2 1 C9NN9581B LEVER Lever & Shaft Assy., Throttle, 6600, Start Year: 01/01/1975
3 1 C5NE9589A SPRING Spring, Lever Adjusting Screw, Start Year: 01/01/1975
4 1 352986S8 SCREW Screw, Lever Adjusting, Start Year: 01/01/1975
5 1 C5NE9622A SEAL Seal, Lever & Shaft, Start Year: 01/01/1975
6 1 C5NE9C501A RETAINER Retainer, Seal, Lever & Shaft, Start Year: 01/01/1975
7 1 74109S PLUG Plug, Expansion, 1/2", Throttle Shaft, Start Year: 01/01/1975
8 1 86514364 PLATE Plate, Throttle, Start Year: 01/01/1975
9 2 353851S36 SCREW Screw & Washer Assy., Start Year: 01/01/1975
10 1 D0NN9541A NEEDLE Needle, Idle Adjusting, Start Year: 01/01/1975
11 1 409578 SPRING Spring, Idle Adjusting Needle, Start Year: 01/01/1975
12 1 E1NN9E588AA CONNECTOR, HYD. Fitting Assy., Fuel Inlet, Except 6600, Start Year: 01/01/1975
12 1 C5NN9E588B CONNECTOR, HYD. Fitting Assy., Fuel Inlet, 6600, Years: 01/01/1975-12/31/1976
13 1 C5NN9B544B PISTON Piston Assy., Accelerator Pump, 2600, 3600, 231, 335, 420, Start Year: 01/01/1975
13 1 C5NN9B544C PUMP, HYDRAULIC Piston Assy., Accelerator Pump, 4600, 515, 531, 535, Start Year: 01/01/1975
13 1 NSS NOT SERVICED SEPARATELY Piston Assy., Accelerator Pump, 6600, 6600C, Includes Ref 14 & 15, Years: 01/01/1975-12/31/1976
14 1 C5NN9B564B SPRING Spring, Accelerator Pump Piston, 4600, 515, 531, 535, Start Year: 01/01/1975
14 1 C5NN9B564A SPRING Spring, Accelerator Pump Piston, 2600, 3600, 6600, 231, 333, 335, 420, Start Year: 01/01/1975
15 1 C5NE9688A RETAINER Retainer, Accelerator Pump Spring, Start Year: 01/01/1975
16 1 E1NN9510DA BODY Body & Plugs Assy., Metering, 2600, 231, Start Year: 01/01/1975
16 1 D8NN9A511AA BODY Body & Plugs Assy., Metering, 3600, 4600, 335, 420, 545, 515, 531, 535, 4600SU, Start Year: 01/01/1975
16 1 C5NN9A511D BODY Body & Plugs Assy., Metering, 6600,6600C, Includes: Ref. 17 & 18, Years: 01/01/1975-12/31/1976
17 1 C5NN9N521A VALVE, HYDRAULIC Valve Assy., Accelerator Pump Discharge, Start Year: 01/01/1975
18 1 C5NN9N522A GASKET Gasket, Valve, Start Year: 01/01/1975
19 1 D0NN9G551A VALVE, HYDRAULIC Valve Assy., Pump Power, 6600,6600C, Includes: Valve & Ref. 20 & 21, Years: 01/01/1975-12/31/1976
20 1 C5NN9N523A GASKET Gasket, Power Valve, Rubber, 6600, Years: 01/01/1975-12/31/1976
21 1 NSS NOT SERVICED SEPARATELY Gasket, Power Valve, 6600, Years: 01/01/1975-12/31/1976
22 3 NS NOT SERVICED Screw & Lockwasher Assy., #10-32 x 5/8" Fillister Hd., Start Year: 01/01/1975
23 1 D6NN9533A JET Jet, Main, Stamped #512, 2600, 231, Start Year: 01/01/1975
23 1 D3NN9533A JET Jet, Main, Stamped #53, 3600, 335, 420, Start Year: 01/01/1975
23 1 D3NN9533B JET Jet, Main, Stamped #61, 4600, 515, 531, 535, Start Year: 01/01/1975
23 1 789533F JET Jet, Main, Stamped #58, 6600, Years: 01/01/1975-12/31/1976
24 1 C5NE9550A LEVER Float & Lever Assy., Carburetor, Start Year: 01/01/1975
25 1 C5NN9A519A SPRING Spring, Float, Start Year: 01/01/1975
26 1 D8NN9566AA NEEDLE Needle, Fuel Inlet, Start Year: 01/01/1975
27 1 C5NE9558A SHAFT Shaft, Float Lever, Start Year: 01/01/1975
28 1 C5NN9561B GASKET Gasket, Float Bowl, Start Year: 01/01/1975
29 1 C5NE9B573A BOWL Bowl, Float, Start Year: 01/01/1975
30 5 43401S36 SCREW Screw, Fillister Hd, W/Washer, #10-32 x 7/8", Start Year: 01/01/1975
31 1 88071 PLUG Plug, Pipe, 1/8"-27, Drain, Start Year: 01/01/1975
32 1 C5NN9C279A PLUG Plug Assy., Air Horn Includes: Plug & Ref. 33, Start Year: 01/01/1975
33 1 C5NE9H519A GASKET Gasket, Plug, Air Horn, Start Year: 01/01/1975
34 1 C5NE9H518A SPRING Spring, Horn Plug, Start Year: 01/01/1975
35 1 80684 WASHER, LOCK Washer, Lock, #10, Start Year: 01/01/1975
36 1 NS NOT SERVICED Screw, Tap, Pan Hd., #10-16 x 3/8", Start Year: 01/01/1975
37 1 C5NN9546B SHAFT Shaft & Lever Assy., Choke, Except 6600, Start Year: 01/01/1975
37 1 C5NN9546A SHAFT Shaft & Lever Assy., Choke, 6600, Years: 01/01/1975-12/31/1976
38 1 NS NOT SERVICED Screw, Fillister Hd., #8-32 x 1/4", Start Year: 01/01/1975
39 1 C5NE9587A SPRING Spring, Plunger, Choke Lever, Except 6600, Start Year: 01/01/1975
39 1 C5NN9587A SPRING Spring, Plunger, Choke Lever, 6600, Years: 01/01/1975-12/31/1976
40 1 C5NE9D538A SEAL PROTECTION Packing, Choke Shaft, Start Year: 01/01/1975
41 1 C7NN9H516A BRACKET Bracket Assy., Choke Control Wire, Except 6600, Start Year: 01/01/1975
41 1 NSS NOT SERVICED SEPARATELY Bracket Assy., Choke Control Wire, 6600,6600C, Includes: Bracket, Clamp & Ref. 42 & 43, Years: 01/01/1975-12/31/1976
1 E7NN9D270AA CLAMP Clamp, Start Year: 01/01/1975
42 1 34126S8 NUT Nut, Square, #8-32, Start Year: 01/01/1975
43 1 88985 SCREW Screw, Fillister Hd, #8-32 x 1/2", Start Year: 01/01/1975
44 1 50517S36 SCREW Screw, Pan Hd, 1/4"-20 x 1/2", Start Year: 01/01/1975
45 1 D8NN9549AA PLATE Plate Assy., Choke, Start Year: 01/01/1975
46 2 42790S8 SCREW Screw, Pan Hd, W/Washer, #6-32 x 1/2", Start Year: 01/01/1975
47 1 82845220 GASKET Gasket, Carburetor to Intake Manifold, Start Year: 01/01/1975
48 AR CKPN9590B KIT, REPAIR Kit - Major Overhaul, 2600, 3600, 231, 335, 420, Start Year: 01/01/1975
49 AR CKPN9590C KIT, REPAIR Kit - Major Overhaul, 4600, 515, 531, 535, Includes: Ref. 7,9,10,13,26,32,46 & 50, Start Year: 01/01/1975
50 AR CKPN9591B KIT, GASKET Kit, Gasket, Carburetor Repair, Includes: Ref. 5,6,18,20,21,28,40 &47, Items 20 & 21 are for 6600 only., Start Year: 01/01/1975
/ 99% finished on the 3000 #30
Soundguy,that's exactly what I needed!
My tractor only has 865 hrs. and has been barn kept most of it's life.
The only issue I have now is that it slightly smokes (black) at idle.
Maybe it's running a little rich?
Thanks for the great help.
black smoke is usually rich... those holley carbs can be cantankerous.. usually they get replaced with a 300$ zenith and then you get to work with your tractor.. not on it.
soundguy
KMC Strip Till Rig & Planters (A64126)
KMC Strip Till Rig...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
