is it just my computer?
/ is it just my computer? #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
when i sign out of TBN, a lot of time i end up having to do a ctrl/alt/delete to get to the
task thingie, to end the program: for some reason it locks up or at least won't budge till i go thru these steps. anyone have any suggestions? if i don't sign out and just select another address, it goes straight there with no problem.
heehaw
/ is it just my computer? #2
I usually never log out, but after seeing your post, I logged out, went to another website, came back, and logged in again. And everything worked normally for me.
/ is it just my computer? #4
I always try to sign out of anything on the computer. Good practice to have in todays world. Never experienced the problem on TBN or other sites. Does it do the same thing when you log out elsewhere?
so far just TBN: an not all the time: i have learned to deal with it: if theres no response after about 20 seconds, i go ahead and do ctrl/alt/delete and get the process of stopping it started.
heehaw
problems solved: received an offer to upgrade to Internet Explorer 8: an so far no lock ups.
heehaw
/ is it just my computer? #9
+1 Mozilla Firefox plus Ad Block Plus = smooth internet browsing with no pop-ups. Add AVG anti-virus for extra protection. All Free!
Sometimes one has to look beyond the obvious. I'm running Vista / Firefox and recently downloaded a MS Visual C+++ upgrade. Computer stopped booting and had to do a restore every third or fourth boot. Deleted the C+ and prevented it from downloading and has been smooth sailing since.
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A68183)
2017 Ford F-250...
2019 Ford F-450 Ext. Cab Knapheide Service Truck with Liftgate (A66736)
2019 Ford F-450...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
