Buying Mahindra 5525
/ Buying Mahindra 5525 #1
WHW2821
Central LA
Balarus 250as + John deere 990 w/t FEL
I will be purchasing a new Mahindra 5525 for a small hay operation and wanted to know if the FEL will handle a 850 pound bale grab + 600 pounds of square bales in it. I know the loader capacity is there but will the tractor have enough mass and weight to handle a object as large and cumbersome as this.
YouTube - WRLongInc's Channel
Will i need wheel weights or loaded tires?
/ Buying Mahindra 5525 #2
On any tractor rear ballast weight is a good idea if lifting with a loader, as it just makes the whole thing more stable.
/ Buying Mahindra 5525 #3
I like that Long grapplator. Neat, but probably expensive
My 2008 Mahindra 5525 has loaded rears and I carry my double bottom plow on the 3pt hitch for ballast when I tote heavy loads on the ML250 FEL. Haven't had a problem yet.
I'm doing oat hay on 6 of my 10 acres and baling with an MF124 small square baler (14x18x35-45"L, 40-50 lb bales). So I couldn't justify the cost of a store-bought bale accumulator/grapple like that Long thingy since my operation is so small. So I built my own combo bale accumulator/bale squeeze
The accumulator rides on the bale squeeze arms and handles 8 bales. Whole thing weighs about 650 lb.
I can stack and move 16 bales with the squeeze. Cost about $1600 for steel and hydraulics. Ran many pounds of 7014 and 7024 weld rod through my stick welder for this project.
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
Challenger MT400 and MT600 series tractor parts manuals (A63117)
Challenger MT400...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2016 Ford Transit 250 Cargo Van (A61573)
2016 Ford Transit...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
