Compact tractor and hay grapple
/ Compact tractor and hay grapple #1
BryanM
Gold Member
Northwest Ohio
John deere 2155, ford 1600
Just curious, has anyone used or built a hay grapple to fit on their compact tractor? I am thinking some compacts may be able too handle a small 8 bale grapple but cannot find anywhere on the net about the grapples size or weight. I also thought I may be able too build one too fit but cannot find any good pics . I know if its been done its probably been done or attempted by someone on here. thanks for your time
Bryan
/ Compact tractor and hay grapple #2
I use a haymaster grapple on a NH tc 35. I use a counter weight and have had no problems although the manufacturer recommends a bigger tractor. When stacking hay where I can't use the grapple function, I pile the hay on top and use it as use it as a lift. Saves a lot of lifting.
Anone else? Does anyone here use a grapple or made one? What size tractor do you use? thanks:D
/ Compact tractor and hay grapple #4
Haven't made a grapple. But I've made an 8-bale combo bale accumulator/bale squeeze for small square bales (14"x18"x45"L).
It attaches to the skid steer plate on my Mahindra 5525.
It's nearly finished. I'll post construction details one of these days.
/ Compact tractor and hay grapple #6
I run a Hoelscher accumulator/grapple. It's a 10 bale and the grapple weighs 580#. Even with a big tractor I use a counterweight because it sticks so far out. The issue is not the weight, but where the weight is. You can probably counterbalance to handle a 8-bale grapple.
The Hoelscher site has the manual/parts list for the grapple on-line:
http://www.hoelscherinc.com/pdf/forkmanual.pdf
That will show you how they are put together. I know that Kuhns Mfg makes a 8-bale model but I couldn't find an online manual. Check some of the other manufacturer sites and you can probably find a manual....probably cheaper in the long run to buy one though. They're all pretty much the same except for Steffen.....I think theirs is gold plated. Good luck!
John Deere 1025R (A62177)
John Deere 1025R...
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A61567)
2019 Caterpillar...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN#7FWBE1629T1037830 (A61166)
2026 Steel Pines...
2000 Nissan Sentra Sedan (A61569)
2000 Nissan Sentra...
