SC 2400
/ SC 2400 #21
I wont say stay off
just be careful
any tractor or other powered equipment can be dangerous even when perfectly balanced if you are not using common sense
just remember carry things low and watch the turning radius with a load
/ SC 2400 #22
Bought my SC 2400 yesterday July 23. I have mowed 2 acres with it this afternoon and I mean a very steep 2 acres........It handled great........Easy to clean afterwards........Looking forward to tomorrow when I have to go mow a 3 acre yard at my father inlaws....
/ SC 2400 #23
congrats tractordude
It is an awesome mowing machine isnt it
you have to put a lil more info up now and some pics
/ SC 2400 #24
Question for you fellas. I was our cutting the field with the brush hog. Some of the brush on the edge of the field too :) . When I got done, I went to put it into high and it slips right back to low. I looked underneath at the lever and it looks like there is supposed to be a spring that holds the actuator down. I couldn't find any pictures of it in the manual to confirm that. Does anyone know??
/ SC 2400 #25
Beardley did you find out?
if your still looking pm me I have a parts and service manual on disc and can look for you
/ SC 2400 #26
here is a pic of the range shifter
the spring is part number
CY-1A7880-27580 SPRING
/ SC 2400 #27
That would be the one!! Is there somewhere I can order that parts manual? I'm sure that will come in handy.
Thanks again
John
/ SC 2400 #28
I am trying to think of where I got it
has the service manual, parts manual, yanmar engine service manual all on one disc
If I remember right I got it thru ebay some company that has cd manuals on just about any tractor I can try and find out where might take a day or so as I am going to be spending a little Grampa time in the next couple days
/ SC 2400 #29
Easy enough. It looks like this guy keeps them on here regularly. I know what I'll be ordering. :D
Cub Cadet Yanmar SC Series SC2400 Manuals COMBO Package - eBay (item 130291419206 end time Aug-30-09 18:24:09 PDT)
/ SC 2400 #30
thats the one
its in acrobat form and helpful as can be
/ SC 2400 #31
If you go to the Cub parts page and use "sc2400" with no spacing as the model number, you will get a complete parts listing.
Hope this helps.
Alan
/ SC 2400 #32
At some point I downloaded a parts list for the sc2400. The manual contains the tractor and engine. It is in pdf format and I would be willing to email it to you if you pm me that you want it. It is form #769-03821 and is dated 08/08. I am not sure how this differs from the service manual.
Alan
/ SC 2400 #33
Can anyone tell me about the lower links on the sc2400? It seems they will only spread about 22 inches apart. most 3 point equipment use more like 26 inches. Am I doing something wrong? I want to get a 4 foot rotary cutter for it.
/ SC 2400 #35
Thanks for the quick reply. That wouldn't work on the 5' woods cutter I have on my 8n. I see several sc2400's listed here with a 4' rotary cutter, but the sales people around here seem clueless about the compatability. What model rotary cutters are being used on the sc2400?
/ SC 2400 #36
The "chains" are adjustable bolts that alow you to adjust the spread on the lower arms. Check your owners manual.
I have a generic full size 4' brush hog that works fine. Also use a full size 5' box scraper. By full size, I mean an attachment that is not scaled down for the sub-compact.
Alan
/ SC 2400 #37
Since no one posted any pics, here you go. I found a dealer during my trip, unfortunately they were closed. Looks like a nice unit. I too was considering one but local dealer had a falling out with Cub and dropped them and the only other dealers around here are also New Holland dealers and they don't seem to want any new customers.
/ SC 2400 #38
Alan
The chains are loose. Are you telling me that your lift arms spread far enough that you didn't have to turn your pins around?
/ SC 2400 #39
Just because the "chains" are lose, does not mean that they are lose enough. I can spread the lower lift links over 30" apart. After attaching your implement, be sure to retighten the "chains".
Hope this helps.
Alan
/ SC 2400 #40
HMMMN. Even with the turnbucles removed from the chains I can't get the lift arms more than 22 1/2 inches apart. I don't thin my 8N can go 30 inches!
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61567)
2023 John Deere...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK52CJ75416 (A61165)
2002 Freightliner...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
