How many projects do you have going?
/ How many projects do you have going? #1
tessiers
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I never seam to get ahead, I finished 1 project this evening and started two more. Actually I finished one of the two I started as well. It would be quite discouraging to list all the projects I have going but I just keep bulling ahead.
I finished turning some new pins for my backhoe bucket, I ordered the stock 2weeks ago and I am just getting to it.
While getting to the bucket I brushed a chain off the top of my winch which reminded me I have a tough time moving it unless its on the tractor, so I made a fork pocket on top so I can pick it up with 1 fork and move it without a chain.
While I was doing that my father came in and was complaining about moving trailers around the yard and wanted a trailer ball on the bucket, after a little discussion he decided he wanted a reciever hitch that slips over the forks for better visability and the fact that we have trailers with 4 different hitch's. Got that one about 1/2 finished, hitch is done and 1 fork pocket is done.
It just never ends for me, how about you guys (and gals)?
/ How many projects do you have going? #2
i complain about watching the kids all the time and not being able to get things done.......then, i get a break and someone babysits (rarely!).....i have so many things to do i don't even know where to start!!!! you feel like your stuck in a hole and the water is coming in faster than you can get it out
sometimes i think the guys at work that live in the city, watch sports on tv and golf all the time might have it right:rolleyes:
well, i'd better get back to work;):D
/ How many projects do you have going? #4
Restoring a 1951 Minneapolis Moline BF tractor--engine gets pulled this week
Calibrating the old Minneapolis Moline P3-6 grain drill for oats
Hydro-inflate the rears on the Mahindra 5525 tractor
Repair the main slip clutch on the MF-124 baler
Find an affordable 20x30x8ft H detached metal carport.
Fix oil leaks on the 1964 MF-135 diesel
Fix tranny on the 1951 Farmall Super A (won't shift into 1st)
Bolens G1453 garden tractor-- the 14hp Tecumseh engine needs rings and valve job
Move an MF-44 self propelled windrower from my neighbor's place to my shop area (4-cyl flathead Continental engine needs a rebuild).
Move my neighbor's flail mower to my place and replace one of the seals
Mow the 6-acre hayfield with the flail mower as soon as it's safe to do so (grass fire hazard--3rd year of drought around here)
Order fertilizer for the hayfield
Order oat seed
Go used truck shopping--looking for a 1990-99 1-ton flatbed truck with gooseneck hitch and a decent towing setup
Makes my head swim and my back ache.
/ How many projects do you have going? #5
-building my backhoe
-finsh welding lift arm of my loader
-snow plow for my john deere gator
/ How many projects do you have going? #6
The Honey Do list never ends...
When I finish a project, she has 4 more.
/ How many projects do you have going? #7
pick up 20' X 10' cattle guard found on CL
install cattle guard
fix electric fence
clean out 3500 gallon fiberglass water tank
build pad for water tank
install tank and plumb to run water to house and ranch in case of power out or water shortage (in BIG drought right now)
unload brush from flatbed into gully for erosion control
weld up quick attach for FEL forks I already have
connect water to work shop
connect electricity to work shop
paint 3 above ground fuel tanks with reflective paint
install radiant barrier inside cab roof, reinstall cab roof (AC just got fixed)
fix and repair and improve and store everything I use or break doing the above and all other ... makes me tired just thinking about it...better go rest now:rolleyes:
/ How many projects do you have going? #8
150 year old home.
50 year old groundhog infested barn
'97 Dodge Neon that needs frnt/rr susp and rotors
10 cords of wood to lay in for the winter
barn to reside before the snow
house roof to repair before the snow
oh yeah...the regulars of
grass to mow, oils to change, weeds to whip
Star Trek and Eureka to watch
/ How many projects do you have going? #9
Hmmm... too many to list. My problem is that I start on a project, and in the midst of project 1, find that I need a new tool to finish, so begins project 2, which needs some jig made, so there's project 3, etc. By the time I get the sub-projects done, project 1 is no longer needed, or I've forgotten what it was, or another project has taken its place atop the list of things to do. Anyway, it's an endless cycle. I guess it keeps me out of trouble.
... most of the time.
Dave
/ How many projects do you have going? #11
Small jobs that need to be done so i can throw away some junk thats left over:
- transplant the aluminium sideboards of the truck bed i bought last week, to my 2.5 ton deck-over tandem trailer
- make fork pockets under the big 2x3 meter steel bin i have around, so i can use it as a scrapbin
- turn the C-channel and leaf springs of a wrecked mobile home, into a single axle 3x1.3 meter 1.5 ton car trailer
Small jobs that need to get done, just to be done with them:
- finish the quick attach of my front loader (since 2005 i work with loose pins)
- lengthen the dump cylinders of my front loader to achieve 90 degree tip angle at ground - level (parts pre-welded, will do this week)
Maintenance jobs that just need to be done this summer:
- fix the left brakes of the 5245 (did the right brakes last winter) when its open anyways, combine this with:
- put new copper washers in the diff of the 5245 (it has ran without oil)
- change the cracking 40x5mm support tubes of my front loader brackets, to solid 40mm St.60 rod
Summer projects:
- finish my newly purchased 4 ton muck spreader, blast & paint it
- blast & paint my bale clamp
less important things, will do when i feel like it, or dont want to plan a big project:
- put the new gas struts, mirrors and lights on the 5245
- paint the spare front grille of the 5245 and replace the busted one on the 5245 (i made the bullbar to protect the hood, but damage had already been done)
this winter's jobs:
- respray my 3011
- rebuild the engine of the 3011
long term projects:
- make a boom pole for my front loader
- finish my pull type grader (i finished the blade, then threw it behind the shop)
- make a brush grab for the frontloader
- build the bale processor (chopper and hopper already bought 3 years ago
- finish the dirt buggy thats sitting in the workshop since 2007..
/ How many projects do you have going? #12
I could probably list about 20 projects, which are usually the most important to me at the current time. There are most likely another 50 or so that are kicking around in the back of my mind.
/ How many projects do you have going? #13
I really have too many to list. :rolleyes:
From welding projects, to wood projects.... I did get one woodshed finished yesterday, and started on it Friday.... It's 16x16 and 10ft. high, and I have one more to build along with other wood projects.... I'm adding this wood stove this year. United States Stove Co. 1557M Add-on Furnace - 5095270 | Tractor Supply Company... I have to set it up and run all my pipe to connect it to my ductwork, but TSC can't get them in until September or October, :confused:... and bow season starts the first of September.
I have 5 trees that are already cut up and split and I have to stack all that, and I also have 11 more trees on the ground that needs split.... We have had a lot of rain this year, and it has been hard trying to get everything done. (I have a guy that I hired coming tomorrow to help with the trees. :D)
I got one of the welding projects finished last week... I built a trailer two years ago to pull behind my ATV and with my tractor, But I built it too wide for some of the places that I need to go on my hunting property. :rolleyes:... I had to cut it down on both sides so the tongue would come out right.. I had to cut the axle off and shorten it, and then weld the trailer and axle back together. (I have pics.).. I still have a lot of welding projects to go.
Its hard to get my other projects done when I have garden work to do.. And trying to keep over 6-acres of grass mowed with all the rain we have been having, and I have places on my hunting property where I have to use the bush-hog.
Here is my partial list for today
24x110 equipment shed under way, 24' of roof sheets left to do and 50' of wall sheets.
sugar shack expansion under way, I stood outside to load the wood into the evaporator last year. The foundation is done, just need to build the **** thing.
Finishing feed lot needs some pavement of some sort. Steers have ground 18" of gravel into soupie muck. I'm planning concrete, if it ever stops raining.
Manure spreader needs new beater bars, this will get done when I need to spread manure for sure but it would be nice if it were all ready when I needed it.
Fill the Hay Shed
Cut, Split and Stack 4 or 5 more cords of firewood, I only have 7 in so far.
Build new Rabbittry, I have them stuck in every croock and cranny around here.
Buy or Build snow plow for tractor, I sold the old plow truck so this will get important in November.
Buy, build or fix a woodstove. The one we currently use is just plain used up and needs to be replaced. Would like a wood fired boiler but that isn't likely this year.
Finish greenhouse I have started, or tear down the part I have already done.
Put new roof and wall sheets on my camper building. I have all the sheets just need time.
This is just the stuff I need to do not including everyday chores and the few things I would like to do. I too do not really get to stressed over the whole thing I just do what I can.
/ How many projects do you have going? #15
Tear down the house and rebuild it while finishing the garage, the landscaping and the road. So that's one.
Maintain my vehicles while restoring a 1949 Ford pickup, fixing a couple boats and building a new ice fishing shack. So that's two.
Good thing I'm away from home most of the summer and fall because I'm just two projects away from getting bored.:rolleyes:
/ How many projects do you have going? #16
There is some comfort knowing that while I am waist deep in my own gator pond and watching the dorsel fins there are many others out there in the same place. I would not have it any other way, I hate to be idle.
/ How many projects do you have going? #17
Ive got several of mine Im trying to finish a little each week. Im rebuilding a bushog, refurbishing cone spreader, painting a drop spreader I bought to spread lime., Need to tear down the old house across the road and buil my bigger green house over there. Plumb my skid steer splitter, and get to work on my outside wood furnace Im building.
/ How many projects do you have going? #18
I'm also in one of those deep holes that fill with water faster than I can get out.:eek: My main project right now is a hydraulic auger that attaches to a skidsteer. I will finish the paint today and it will need one hyd. hose to be complete.;)
/ How many projects do you have going? #19
Guess it all depends on how you catagorize things! I figure Ya got your 'Honey-Do', your "Stuff That Has To Get Done", Your "***** That Happens", and your "Projects"! An example: HD-List "help me transplant the bushes", Can we rearrange the furniture" etc. The STHTGD List 'Cut the grass', 'trim the bushes', 'write the checks', 'go grocery shopping' The STH's list is "The kitchen sink's plugged!" (Last week's STH'd!). And THEN, there's the "Projects"! I try to accomplish the STHTGD during the week. Then I devote Saturday AM+ to the HD, and get done what I can! Then Sat PM , and Sunday I get to "Projects"! A defined goal, and purpose! The Stump Grinder, The Will Da Beast, The (current) 'Garden Cart', The Bandsaw Mill Design..........But then out of the blue comes the STH's! Awe geez! ~Scotty
/ How many projects do you have going? #20
I'm not getting any of my outside projects done today, because of more heavy rain.
We have had a lot of rain this year, and right now on the weather channel their showing that Louisville got 6-inches in an hour.... With more to come.
This year is going by so fast.
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
