Oil & Fuel 2554 oil drain leaking
/ 2554 oil drain leaking #1
diesel_nut
Gold Member
Tennessee
~'88 1872(sold); '08 GT2554
Changed the oil 2 weeks ago and I have noticed a leak under the tractor. Initially I thought it was residual oil dripping off frame rail. But it's the oil drain leaking(the twist and turn drain). Dealer said to bring it in and they have a new updated plug for that. Will let you know what that is when it gets done.
/ 2554 oil drain leaking #2
Same thing happened on my 2542, I removed the twist and turn drain and replaced it with a drain hose that I had made up at NAPA. I didn't like the idea of having a plastic drain plug, I guess I was afraid of something getting in there and breaking it.
/ 2554 oil drain leaking #3
On my GT3100 I noticed a puddle of oil on my barn floor. I drained the oil out and measured it. It was slightly less than a pint.
Mine had the elbow so I put a nipple and plug on like I have seen in previous posts on this form.
That plastic valve is a piece of junk. I could not tell when it was locked shut, or else it opened up by itself.
John
/ 2554 oil drain leaking #4
I purchased my 2550 in 07. It had nipple and elbow. Did they come like that
or did dealer add it? Dealer is top notch!
NO they do not come like that. Mine is an '08 model.
/ 2554 oil drain leaking #6
I think they done something like that in later years.:)
/ 2554 oil drain leaking #7
All the 2007's I've seen had a nipple, elbow and then the plastic quick drain fitting. My 2005 model year had only a short, hexed nipple and then the (garbage) plastic fitting, which required me to lift the engine to remove/replace with standard pipe fittings. Diesel_nut, a master wrencher like yourself sent it do a dealer for that?!? Say it ain't so!
Joel
/ 2554 oil drain leaking #8
Took me less time to R/R the oil plug than to do this 1st paint job with the red arrow...
...I opted for the quick fix with a simple stopper cause I didn't want to jack up any farther to accommodate an elbow. For a less messy oil change I slightly jack up the R side of the front end and all the oil drops from the frame to a oil bucket.
I can't tell you how happy I am that I don't have to constantly top of oil anymore either.
/ 2554 oil drain leaking #9
Savage, the only thing I'd worry about with your setup is, being pipe threads, you could eventually bugger up the threads in the engine block to the point of persistent leakage. If you throw a nipple in there (or the likes), it only goes in once and stays. Any thread issues would happen well downstream, leaving the block intact.
Joel
/ 2554 oil drain leaking #10
Well JT I'll keep an eye on it for sure...I got it at the dealers when I asked for an 'all metal oil plug'. Seems to me that's what oil plugs were ages ago...just stopper plugs. Pretty sure I have 3 similar ones on other engines 2 push mowers and a splitter and they haven't leaked yet.
EDIT
You know I just reread your post and now I fully understand what your saying. I'll look that over in the morning and think about that some more.
/ 2554 oil drain leaking #11
I would replace the plug with a hose at the next oil change. Get one long enough to make oil changes less messy. Put your choice of stopper in the end. Have the hose made at NAPA for cheap...
/ 2554 oil drain leaking #12
That's the way Simplicity did it on some of their machines (maybe still do). Makes for a nice mess free oil change. You could probably tuck the hose nicely along the frame rail when not needed.
Joel
/ 2554 oil drain leaking #13
I finally got REAL sick of that stupid plastic valve and having to try and bend that vinyl tubing CC supplied onto the end of it. This spring I installed a Fumoto drain valve at the end of a nipple/elbow/nipple setup so I can attach a tube to the end of the valve and route the oil into a container, no muss, no fuss. I forget who showed the idea here - I can't take credit - but it's the way it should have been done to begin with. CC would never have sprung for a Fumoto valve, but Jeezuz, at least the elbow and pipe and just cap the end. Whazzat, maybe $1.50 in Chinese pipe and fittings from Home Despot?
Loosening up the engine (I just removed all 4 bolts after scribing location lines around the "feet") to get the elbow installed was simple enough with my Bosch 18V 1/2" impact driver and once back together, shows no ill effects from the process.
Chris
/ 2554 oil drain leaking #14
A Fumoto is definitely the deluxe package Chris. My John Deere drain valve has a tiny T-stem that has to be threaded out like a hose bib. It's a pain, but still easier, less messy and leak free than the ridiculous OEM setup I had.
Joel
/ 2554 oil drain leaking #15
Joel
Well, whaddya know - that looks just like mine!!! :))
/ 2554 oil drain leaking #16
Yeah, I did it after the 2nd oil change a few years back. I had the JD drain vlv on hand still new in the bag we bought many years ago (for a JD 110) and never used. The quarter turn Fumoto will be much easier than my threaded stem valve for sure.
Joel
/ 2554 oil drain leaking #17
I've got a 2005 CC 2554 along with all the oil drain issues posted here. I would very much like to install the oil drain set up you guys are describing, especially since my tractor is at 300 hrs and time for the dreaded and very much despised oil change. My practice has been to let the oil run out on the frame, drip down into a large catch basin and then clean up. I'm trying to work up enough courage to do what some of you more experienced mechanics have done...loosen up the four bolts holding the engine, raise the engine, install the new drain set up and be done with it. Sounds easy enough. I consider myself an average wrencher but a job of this nature would take me out of my comfort zone as I would be concerned about messing something up and then having to engage a dealer to fix what I messed up. I may just bite the bullet and make the attempt. Any thoughts, suggestions, encouragement or otherwise...would be very much appreciated.
/ 2554 oil drain leaking #18
I offered this at another forum. Use a die grinder with a small cutoff wheel and cut the nipple just behind the elbow. Remove the remainder and then put a hose on it. No need to lift the engine.
About a ten minute job. I have all the equipment to do the job but mine isn't leaking enough to do it yet. I'm lazy...:)
They replaced it with a new twist and turn drain. Looks just the same. We'll see if this one starts leaking also. If It does I'm goin' to the plumbing store :)
/ 2554 oil drain leaking #20
I replace the twist pull oil drain oil drain on my Cub Cadet 2554GT.
It had 3/8"-18 NPTF straight pipe threads, so I bought a 1 FT long hose for lubricated air from McMaster Carr
#5268K625 ($16.34) 3/8-18 NPTF - 1FT Long hose for lubricated air
Then capped the hose on one end with a Pipe Cap
#48805K24 ($11.91) [Cheaper caps are available for under a $1, I'm fancy!]
Works great, original Quick Drain was crap. Grit in the oil keeps it open. Plastic gets brittle with heat.
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2019 Chevrolet Express Box Van, VIN # 1GB0GRFP7K1370206 (A61165)
2019 Chevrolet...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
HYSTER H30XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H30XL...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63118)
2023 Kubota...
