Backhoe new holland tz22 with backhoe
/ new holland tz22 with backhoe #1
expedoman55
I was wondering if anyone has used a NH tz22da or TZ series with a backhoe.
In the fall I want to do some light shallow trenching and wondered if it is a good investment for such a small tractor? Appreciate you experiences
/ new holland tz22 with backhoe #2
I am not familar with it so discount my comment by about 99.99%!!
That said, I'm a fan of bigger is better. If you come across a root or rock, you will appreciate extra oomph.
If it's a one time project, could you rent? (as much as I abhor that idea!!)
/ new holland tz22 with backhoe #3
Does CNH offer the backhoe as an option on this unit? Seems it may be alittle light to handle a BH
/ new holland tz22 with backhoe #5
My brother has a Kubota BX24 which I believe is the same size as your New Holland.
It is a small machine and will do the work of a small machine.
Being small means that it is very easy on the turf, and also very easily transported.
I have used the backhoe several times, and it is nice to use, but rocks and roots can be a challenge.
You will find if you purchase one that it will really come in handy. One the other hand, to buy it for one project seams a bit of overkill.
There is nothing wrong with renting equipment. Most smaller construction companies own their equipment that will be used all the time. When a project calls for a specialized piece of equipment, it will almost always be rented.
