pond weed removal
/ pond weed removal #1
R W Mowry
I have a 1 acre pond that gets what is called Sago pond weed growing from the bottom. Any ideas on a home built drag to remove?
/ pond weed removal #2
You can modify a gate to make a drag, it will rake up the water weed... and then you will have a tremendous crop of weeds. Each time you rake it it will more than double the number of plants that grow.
You do not indicate what state you are in, the BEST control is with white amur (Ctenopharyngodon idellus)...
Depending where you are located stock a couple dozen in your 1 acre pond and your weed problem will be gone.
/ pond weed removal #3
Welcome to the forum. You may want to have a look a Pond Boss Magazine Home Page! there are a lot of knowledgeable pond management professionals on their forum that are willing to offer advice.
MarkV
/ pond weed removal #4
There is a company called Aquacide that makes a lot of weed control products for ponds. I have used them and they work very well.
/ pond weed removal #5
What are you stocking the pond with?
2003 Ford F-350 Flatbed Chemical Sprayer Truck (A61573)
2003 Ford F-350...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2023 Case TV450B (A62177)
2023 Case TV450B...
