Work Light - CT230
/ Work Light - CT230 #1
Canada_CT230
Nowhere
1878 Ford 65N
Here is my first work light. I found these rubber cased work lights at Princess Auto for $6. I bought 2 but I only have one installed right now as I still need to mount my SMV sign and I'm not sure if this one will stay in its current location.
Power is from the factory wire harness under the Remote Hydros. Power is only supplied with key ignition is on. So I installed a switch inside the rubber boot of the light. Simple setup but it works.
/ Work Light - CT230 #2
Very nice! Now we need a picture at night to see how well it works. :D
I need to install some rear work lights on my cab this year, hours of snowblowing after work in the short winter days means lots of night time work.
I have yet to see the headlights myself! I'm up too early for work to stay up that late. Will have to wait a month or so for less daylight hours.
/ Work Light - CT230 #4
Don't worry, the loader cross arm takes good care of blocking the headlights usefulness. :D
I'm putting lights on the front of the cab too!
/ Work Light - CT230 #5
You guys might already be aware of this, but the Kioti factory rear work light with the bracket (actually two, depending on how you want to mount it to the ROPS) is ~$20 from Michigan Iron & Equipment. Works quite well and includes a switch mounted to the light, and proper pigtail to match the factory wiring of course. I'll try to remember to snap a picture.
/ Work Light - CT230 #6
Any idea what the alternator output on CT230 is and the available wattage at idle rpm? I want to do the same and want to make sure there is enough watts avail for the extra lights, especially at idle rpm.
/ Work Light - CT230 #7
Thanks for that information, Josh. Didn't know that. I'll check them out. How long did it take you to install them?
/ Work Light - CT230 #8
The install is cake-at least for a CK20S (CT 122). Remove two bolts that attach the right side of the ROPS structure to the tractor, slip this bracket in place and reinstall the bolts. Add the light to the bracket (one more bolt) and connect the two slip-on electrical connectors.
A 10 minute, 1/2 beer job.
The alternator on my tractor says 50 amp, which seems to be stronger than other brands I researched (JD, Kubots). Should be plenty of output for just about all lights. I'm not sure what it can output at idle, though. 50 amps at 14 volts is 700 watts (wattage = voltage * amperage).
/ Work Light - CT230 #9
josh
i looked on the web site and they didn't list the work lights, do you have any info so that i can order a set
thanks
chuck
/ Work Light - CT230 #10
Me too :). I'd like more info on the worklights from Kioti. I need to add some to my CT230 before the winter.
Thanks,
Doug
/ Work Light - CT230 #11
I don't have the P/N but Bob @ Michigan Iron can get you setup 517-625-4590, just tell him which model equivalent Kioti tractor you have.
I finally snapped a couple of pictures, see attached. Couldn't get a picture of the wiring because the tractor was backed up to the wall and I was running late for work!
Josh
/ Work Light - CT230 #12
Josh
Josh it looks great. Does the light swivel from side to side?
/ Work Light - CT230 #13
It sure does. And the kit included another bracket which would mount on only the rear of the two bolts and would allow the bracked to swing as well as the light.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2013 Ford F-150 Pickup Truck, VIN # 1FTFX1CF8DFB41266 (A61165)
2013 Ford F-150...
2014 Nissan Altima Sedan (A61569)
2014 Nissan Altima...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
2010 Acura MDX AWD SUV (A61569)
2010 Acura MDX AWD...
(2) 11-22.5 Pivot Tires and Wheels (A62177)
(2) 11-22.5 Pivot...
