backhoe joystick
/ backhoe joystick #1
welderboy14
Surrey, BC
John Deere 325
hi
i'am trying to find the best joysticks for operating a backhoe. the ones i was
going to use are no longer available now heres a link to them it is just picther now (it was only the joystick on the end of the block)
Item# 314356 Sold Out | Northern Tool + Equipment
but thay did cost $89.99
i hope someone knows of a place
i was hoping only to spend max $200 on each joystick
note i live in B.C canada
thanks very much
welderboy14
p.s i know i should of posted this in the hydraulics fourm but it would not let me post for some reson i will post it in the hydraulic fourm when it works
/ backhoe joystick
/ backhoe joystick #6
Don't most of the excavators use pilot controls (either hydraulic or electrical) which is one reason why mounting the controls is not a big deal. The control pattern should not be an issue, it's just up to how you plumb it.
Andy
/ backhoe joystick #7
Yes, that is correct.
/ backhoe joystick
Andy
yes that is correct
the joystick runs a smaller system at about 500psi and that in retern runs the main system that moves the parts of excavator
Metal Peacock (A65583)
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
