TC33D Won't start
   / TC33D Won't start #11
gildebbiz,
glad you found the problem.
Still curious why the safety switch fuse blew.
   / TC33D Won't start #14
Low voltage = high current draw.
I'm sure this rule applies in some way to the starting circuit, however what's really happening is a little more complex. While a low battery can make the problem worse you can also blow the starting circuit fuse with a fully charged battery. The combination of safety interlock switches and starter solenoid in the same circuit seems to be a bad idea in this case.
   / TC33D Won't start #15
I know it's been a while since this thread. But for anyone that is researching start problems, here is what I found on my TC45D.
Intermittent start problems. Had to wiggle shifter past "N" several times to start. Sometimes start relay would click, sometimes not. Traced it to the "transmission range switch" on driver's side of transmission case. This switch is part of the safety interlock system for starting. I removed the switch. (unplug 2 bullet connections) use 3/4" open end, unscrew from transmission. I hooked meter on the leads, pushed the spring loaded button, and found sometimes it made contact, sometimes not. So, I chucked the little "nipple" or button in my cordless drill, and slowly turned it several times. Seems to have cleared some sort of debris or oxidation inside the switch body, as now it makes and breaks contact as it should. Replacement is about $46. Hope this works.
   / TC33D Won't start #16
I have to thank you guys for the fuse discussion. This morning we're deep in heavy snow. Snowblower clogs, I bring it home to clean it and when I hop off the tractor, it dies. I think maybe the emergency brake didn't catch but when I'm all ready to go, it cranks but won't start. Mind you, it's 4:30 am, snowing hard and I'm in the driveway. I tinker with every safety switch and connection and nothing. Then I log in here, get the fuse discussion in my head, confirm that #5 has blown and now I'm good to go. Saved my life. I'm grateful.
What's with the fuse thing? Anybody got a clue? Fuse failure is not common nor should it be. What gives?
   / TC33D Won't start #17
The problem, IMHO, comes from the circuits that route through many safety switches, etc. and this causes a voltage drop and as voltage drops, amps increase causing the fuse to blow. Combine this voltage drop from wiring and couple iot with a battery that is not completely charged and fuse blows. Replace fuse with a resettable circuit breaker; available at most automotive stores that replaces the fuse. I would increase amperes on circuit breaker slightly to help with this situation. ( 7.5 amp to a 10 amp)
Flatbed Truck (A55973)
Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
Caterpillar 262C...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2011 GMC DENALI HD PICKUP TRUCK (A59575)
2011 GMC DENALI HD...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2018 John Deere TX (A53317)
2018 John Deere TX...
