UTV vs boxblade and mower
/ UTV vs boxblade and mower #1
Box5
Member
Bellingham, Wa
1980's Kubota B7001
Hi, we have a 10 acre lot that has car sized trails wrapping around the hills, along with a washboard gravel driveway. I recently had a small b7100 tractor with a boxblade, and it did a nice job grading it smooth, but wasn't stable enough on the trails. The tractor had no rops, so it wasn't ideal for the type of trails and work needed to be done.
I have a couple UTV's in mind after doing some research. The Ranger Xp, RTV, or Mule. The Ranger is top on my list since it seems to be the best all around work/play utv.
My question is:
1. Can a utv like the ranger pull a 4' box blade of some kind without over stressing it?
2. Can you go at a slow and steady enough pace to run a boxblade, like you can with a tractor where you just sit in a gear and idle away.
I'll probably have more question's the closer we get to purchasing one, but thats all for now. Thanks
/ UTV vs boxblade and mower #2
How would you hook a true 3PT boxblade to a UTV? I know they make straight blades for plowing that can be attached, but I've never heard of a box blade. Lots of force involved in dragging a box.....I don't think a UTV is up to the task.
/ UTV vs boxblade and mower #3
I agree with rdam, I can't imagine a box blade on a utility vehicle. Maybe you could rig up a mount for a landscape rake (especially with guage wheels on it) that might do the job. But remember that with neither a box blade or a landscape rake will you be able to back up unless you have some way of lifting it.
In what was was the tractor "not stable enough" on the trails?
Ken
It wanted to wheelie back on some of the hills. And on the off camber turns it felt like it would roll over. And with no Rops I wasn't enjoying that.
I really think a UTV is going to be the best choice since it can haul firewood with ease, and is very mobile. And I can atleast tow a self propelled mower behind it to keep the trails clear. Then i'll just use my excavator to plow the driveway from time to time.
/ UTV vs boxblade and mower #5
That sounds like it needed front weights. Did it have any front weights? That would make a big difference in stability.
Ken
Its really turning into a tough decision. I've had a small tractor and saw what it can do. My mini excavator is with me forever, its invaluable. But its not something to clear trails with, and haul firewood or dirt in the bed etc. And with a Ranger for example, once work is done, you can go bash around on trails with it for fun. Im really just looking for the best all around piece of equipment to keep this place trim, and why not get some fun out of it to if you can.
/ UTV vs boxblade and mower #7
Get a pull type box blade with either electric or hydraulic lift (depending on how the UTV is equipped). I think you will be fine pulling it with something like the Kubotra RTV and I know the RTV has the hydraulic option so it would be good for fixing up trails. I also think the hydro on it would give you good control over your ground speed while working with the box blade.
Or if you really want the best of both worlds get a Bobcat Toolcat. I know they cost a fortune but they look like fun and would meet your needs perfectly.
Hmm, Even has a 3pt, and option for a fel. Depends how capable they are offroad, because our trails have some steep inclines where it would need power and traction. Thats why I had the ranger high on the list.
/ UTV vs boxblade and mower #9
I don't recall anyone complaining about the Toolcat lacking power or traction. If anything is is more utility then the RTV is but lacking in the sport when compared to the ranger. There are guys on here with Toolcats and I am sure they will jump in eventually and be able to answer any questions you have about the Toolcat.
Are there any front mount mowers that can be mounted to a ranger?
I have some idea's to fabricate a mount system if there aren't any available.
Aside from this guy being way to cool wearing a helmet mowing the lawn, I like this setup, but on a utv.
/ UTV vs boxblade and mower #11
Bobcat has their small utv that has the front hitch system. It is also available on the ClubCar version and maybe on the Husqvarna version also since they are all basically the same machine. I think there was a mower option for that UTV and it was priced close to the Ranger.
/ UTV vs boxblade and mower #12
Get your wallet out for that toolcat,maybe $30,000.LOL
/ UTV vs boxblade and mower #13
Robert, you are right, they do have mowers for the Bobcat/Club Cars. The UTVs aren't too much more that another big brand, but I'd assume the mowers and such cost a fortune. But they are up front like the OP wanted.
Box5, Just the opposite, comes with an FEL with an option for the 3pt. There are two different models-5600, with loader and large bed-and-5610 with loader and 3pt.
I think a UTV like a Mule or RTV or XUV diesel or a Ranger would do what you need to do fine.
My 2 cents.;)
Kyle
Yea, the Toolcat is out of the question, way to pricey.
Ranger and the XUV are my two top choices so far. The ranger is so appealing because it has the added fun factor (50mph) but still work ready. I guess its just a matter of finding what mower/mount to use. I can probably fabricate a floating mount for a front mower.
Anyone have any recommendations on self propelled mowers? I hear DR tow behind mowers aren't even close to there walk behind brush mowers as far as quality goes.
/ UTV vs boxblade and mower #15
The Bobcat 2300 has a front lift like you want as well as a mower already available for it. Bobcat has the Toolcat and then smaller less expensive UTV's that are comparable to the XUV, RTV and Ranger. Here is the Bobcat 2300 with front mower.
getImage.do
/ UTV vs boxblade and mower #16
Its really turning into a tough decision. I've had a small tractor and saw what it can do. My mini excavator is with me forever, its invaluable. But its not something to clear trails with, and haul firewood or dirt in the bed etc. And with a Ranger for example, once work is done, you can go bash around on trails with it for fun. Im really just looking for the best all around piece of equipment to keep this place trim, and *why not get some fun out of it to if you can.
I didn't not know a tractor wasn't not fun.
Dont get me wrong, the tractor was a blast, but try flying down a logging road on one ;).
Ideally i'll get another small tractor to go along side the utv. But my needs right now, a UTV seems to be able to do much more effective (mowing trails and hauling firewood up from them).
/ UTV vs boxblade and mower #18
That Bobcat front mount looks more like a finish mower than a trail mower.
/ UTV vs boxblade and mower #19
Couple points that I'd like to throw out there...
1. No UTV, IMO, will have the low-end torque/traction combination needed to use a 48" boxblade effectively. They my drag the box around, but certainly not with the rippers down, so consequently your grading ability will be sorely limited...
2. Rangers and MOST UTVs have lousy engine braking for going down those steep hills because of their belt-driven CVT transmission designs --Yamaha being an exception.
I don't have any hands-on experience, but IMO, the only UTV/RUV type of machines that might come close to doing what you're asking are those with hydrostatic transmisions, such as the Kubota RTV or Honda Big Red. Not sure if the Honda is a two speed-range drive system, though. The hydrostaice should provide more low end torque and better engine braking...
Rangers, Mules, and Rhinos certainly wouldn't be a good fit, IMO...
Thanks for the input, thats why I made this thread. I dont want to purchase the wrong piece of equipment again. I might have to drop the fun factor for more work capability.
I wanted a actual bobcat for so long, but the attachments cost so much, and your gonna end up with a older used piece for >$10k. Theres some nice compact tractors in that price range, new. But it would be so nice to have a dump bed right there for hauling firewood, weeds, etc, thats why I started looking at UTV's.
So now im back to square one :p
2019 CATERPILLAR 279D SKID STEER (A64279)
2019 CATERPILLAR...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2008 Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2008 Bush Hog 3715...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
