W R Long valve ?
/ W R Long valve ? #1
MrZukerman
Northern Ark.
Kubota L3410
I have one question that I've searched for and can't find a good answer. On a WR Long full function third valve, do you Tee into the power beyond hose coming from the loader valve going back to the tractor, into the WR Long, or do you remove the hose from the tractor and go into the valve and then run a new hose from the WR Long valve back to where you removed it from the tractor?
/ W R Long valve ? #4
Aha!
I finally caught you guys talking about just what I am doing. I have a B1700 with a LA301 Loader I want to install rear remotes. I need help with the plumbing. Can I put a valve inline from the line that goes from the loader to the 3pt hitch...at least I think thats where it goes. I have a open center valve and can have the lines made in short order.
Thanks
Jamie
/ W R Long valve ? #5
Aha!
Thanks
Jamie
Short answer is YES.
/ W R Long valve ? #6
Aha!
Thanks
Jamie
Is this line marked OUT or PB on your loader valve? How many hoses are connected to the loader valve?
/ W R Long valve ? #7
Not 100 percent sure if the ports reads out or PB. I am at work right now. I do know for sure it goes back and into the side of the tractor. I was conerned about feedback to the valve from the 3PH. I read that in a post somewhere. I cant keep up with all the information whizzing around in my skull right now.:)
/ W R Long valve ? #8
There are 5 hoses connected to the valve 4 QD for the loader and the one going to the rear.
/ W R Long valve ? #9
I need to take some pictures
/ W R Long valve ?
Thanks Kennyd, now once I get a finally price for a valve kit I'll have to decide if that is the route I want to go or buy the valve and supply the rest myself.
Jamtuc, I think if your loader valve is plumbed with a power beyond, it will have 7 hoses total connected to the valve. someone with a little more knowledge should chime in soon.
4- cylinder hoses
1- high pressure in
1- high pressure out (power beyond )
1- low pressure tank return
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
JCT 72" VIBRATORY ROLLER (A64281)
JCT 72" VIBRATORY...
2008 Volkswagen Eos Convertible (A61574)
2008 Volkswagen...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64280)
KNOW BEFORE YOU...
Roll of Barbed Wire (A64119)
Roll of Barbed...
