ADD LOADER OR REPLACE TRACTOR
   / ADD LOADER OR REPLACE TRACTOR #1
deere5105
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I have a 2WD 5105 John Deere with approximately 250 hrs. Unit has 14.9-28 rear tires loaded with water and two remotes at the rear of the tractor. I use this tractor for basic gardening/farming. I got a really good deal on the tractor and have been contemplating adding a FEL. I have a neighbor that has a 2WD 5205 with 16.9-28 rear tires also loaded with water. I have used this combination multiple times and the only thing I have noticed is that with a bucket full of material you can lose traction. I added a box blade to the rear and it helped significantly. The area I operate in is basically flat with well drained soil. I am trying to decide if it is a good idea to add the loader to the tractor I have or look for a different unit with the loader already on it. I realize the benefits of a 4WD unit, especially with the loader, but my main use for the FEL would be to maintain roads primarily by pushing limbs out of the way when mowing. I am curious if anyone is running a FEL on a comparable 2WD machine with good results or has done what I am considering and wound up swapping machines. Any advice or recommendations?
   / ADD LOADER OR REPLACE TRACTOR #2
Hello,
I have a 2WD JD 5205 with a 512 FEL. When first using the FEL for moving some heavy fill dirt, it did the same thing you were talking about, the back tires would spin and it was a pain to use. I had calcium added to the rear tires, which added alot more weight and made a huge difference while using the loader and even pulling plows, discs, etc. I know it will eventually rust out the wheels in 20-30 years but I can deal with that then.
This tractor is primarily used for bushogging, hay operations, moving bales, discing, plowing, box blading, and occasional FEL work. A 4WD tractor would be nice, but as infrequent as we use our FEL it wouldn't justify the increased price. Don't think i would ever swap out machines, if anything i would just keep the 5205 and save up to buy another tractor, cause it's too good of a tractor to sell or swap, especially if you got a good deal on it.
Would go for the 522 loader instead of the 512 loader, its easier to remove the entire thing from the tractor when neccessary, the 512 is designed to stay on tractor.
   / ADD LOADER OR REPLACE TRACTOR #3
I would just off to be prepared for sticker shock when looking at loaders. On my Kubota, I got it without a loader and used it that way for a couple of years. I added an aftermarket loader; $3100 !!! And that is for a smaller tractortor(Kubota B series).
Note also, even with a 4wd tractor, it is nice to have ballast on the back for loader work.
   / ADD LOADER OR REPLACE TRACTOR #4
2 or 4 wheel drive has nothing to do with maintaining the proper ballast to prevent the loader from causing the tractor to tip.
I am not too concerned about the tipping possiblities as I will primarily be pushing limbs and bushes back that are along the roads. I realize that proper ballasting makes a world of difference. The tires were not loaded when I purchased the tractor and it made using a box blade difficult because it would spin the tires quickly in soft terrain. I have the weight bracket and four weights on the front. I never have any issues with implements causing the tractor to become light in the front end, but also wonder if that is reducing some of my traction due to the weight balance. It sounds like the work Creekside is doing is very comparable to what I do. I prefer to go with the John Deere 522 loader for the ability to easily remove and to keep with the same brand product. I have compared prices to the Bush Hog brand and there did not seem to be much difference in price or performance. Since I do not have mid-mount hydraulics I will have to use the two remotes in back. I would still prefer to use a joy stick though and don't think that will be a problem. Creekside, what size rear tires are you running and is the calcium the only ballasting you use or do you have wheel weights too. I have gotten stuck, but each time I was working in a creek bed moving sand and if I had a loader I would have been able to push myself out.
   / ADD LOADER OR REPLACE TRACTOR #6
If your 5105 works for you and gets the job done in the majority of your chores then by all means buy a loader for it. It has low hours so this would be much cheaper route to go than buying another tractor.
As with any loader you should have proper rear ballast to offset the weight of what is in the bucket, especially with 2WD. Rear ballast can be loaded tires, an attachment, ballast box, etc. I have a smaller 26HP tractor with 4WD and use an 800LB ballast barrell I made when doing loader work. Without it the rear gets light.
   / ADD LOADER OR REPLACE TRACTOR #7
The rear tires on our 5205 are 14.9-28. That is the only ballasting that i use on it unless the rear blade or bushog just happen to be on. I priced out wheel weights originally from Deere but after i got the price back, and each 110 lb weight costed $147.00 each, not including hardware. So to outfit the tractor with 4 weights (2 each wheel) was almost $600. And even then, putting them on would require another loader or taken to the shop because it may be a little hard to put the weights on.
The calcium was much cheaper, costed around $150.00 and they came out to the farm to do it. And not to mention it added about 600 lbs to each tire. Tires held about 53 gallons of fluid/calcium mix and weighs 11.5 lb per gallon. So it was cheaper than wheel weights and gave more ballast. But on other hand it will damage wheels over time. You may want to check out this stuff called RimGuard, it's another typ of ballast that's not supposed to mess up your wheels. Rim Guard - Liquid Tire Ballast
Noticed a big difference in pulling and ballast support once they were done. Pull a 12' tandem disc with it and before it would spin on top of loose ground, now it digs down and pulls better. Only thing though if ground conditions are wet or soft, the added weight may only lead to you getting stuck faster.
See this link on liquid ballast types: Comparing Types of Liquid Tire Ballast | OrangeTractorTalks
   / ADD LOADER OR REPLACE TRACTOR #8
Most likely your 5105 has power steering. If it doesn't, then the loader would make it hard to manual steer with a bucket full of material. Just one thing to keep in mind.....
It does have power steering. It is a 2004 model. It had 94 hours when I bought it last year. We also have a mid 70's Ford 4000 and a 50's model Ferguson 40 gas burner. I believe the 5105 will last me a life time. I keep up the maintenance and try not to abuse it. The other tractors have over 5000 hrs and 8000 hrs respectively and are in good working order. I am just trying to make sure I cover everything before investing several thousand dollars into something when I should just save up and buy a different model with a loader on it. To date I am very pleased with the performance of the 5105. Just checking to see if others have added the loader or have the loader with the same set up I have and had any problems or sold to buy another or wished they had.
   / ADD LOADER OR REPLACE TRACTOR #10
My 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering, partial constant mesh tranny, 5370 lb without FEL) has the ML250 FEL (6-ft wide bucket, 10.5-ft lift height, 2980 lb lift capacity at the bucket pins). It's comparable to your 5105, but is about 1000 lb heavier (without the FEL). No problem so far using this rig. I have the skid steer quick attach option on the FEL (which I like and strongly recommend). My rears aren't loaded, but I'll fill them next month in preparation for hayfield plowing.
Koyker makes a model 220 FEL that fits your JD
Koyker Manufacturing - Loaders
Haven't priced that unit, but my guess is $4-5K.
   / ADD LOADER OR REPLACE TRACTOR #11
I worked for years on the dairy farm with 2wd tractors and loaders, only time we had real trouble was with baleage on Ice conditions. Set of tire chains and a ton of concrete all but cured that problem, We still have trouble with the 4x4 at times, I would get a heavy ballast for anytime you are doing heavy loader work but for general use you should be fine with just the mower on back. I'm guessing you don't have much ice trouble in Mississippi.
You are correct on comparison of our tractors. Last time I checked the loader price should also be very close to that amount. I was satisfied with the performance of the 5205 I used. The machines are the same frame size and weight. The 5205 has six more engine horsepower and the neighbor's I used had the larger 16.9 rear tires. I guess I am mainly curious if I would experience a noticable difference in traction with my 14.9's compared to the 16.9's. I had considered trading my tires in on the larger ones since they were in like new condition, but decided against it due to issues with the wheel size. What size rear tires are you running?
You are correct on the ice. We did get a rare snow last year, but it wasn't a lot. I work for a local electric company and ice wreaks havoc on power lines. If we get a lot of ice the amount of traction my tractor gets will be the least of my problems! I wouldn't be home to be able to know! Checked out your website...pretty neat operation you got.
   / ADD LOADER OR REPLACE TRACTOR #14
14.9x28
   / ADD LOADER OR REPLACE TRACTOR #15
Here's my advice: It would be better and not much more expensive in the long run to just buy another tractor like this. Why spend 4-5 grand on a loader when you could have a good 64HP 4x4 tractor and loader together for 7 grand? I think this is a great deal:
Got a deal yesterday where someone gave us several shooting houses used for deer hunting. Had to borrow the neighbors tractor to lower them onto the trailer. Used my tractor with a lift pole to pick them up to get them off the trailer when back home. One more unexpected use of the FEL. This is the decision I am torn over. I would like to add the Deere loader if I go that route and I expect the cost to be ATLEAST five grand and probably higher. That is around half of what I gave for the tractor. I feel like I would be happy with the FEL on the 5105 and I know the mechanical condition of the tractor. Just not sure it is the best financial decision. I like the extendable draft links and the convenience of the Power Reverser transmission of the 5105. The guy I bought it from had to sale it for financial reasons and the only thing he had ever done was cut a pasture with a 6' rotary mower. I am a little concerned about buying something someone got rid of possibly for mechanical reasons.
   / ADD LOADER OR REPLACE TRACTOR #17
With a tractor with that few hours Definatelly put a loader on it. Also go with the skid steer quick attach. its GREAT!. If your up to the challange put it on your self and save some more bucks. I have done 3 tractor loaders now, 1 deere, one on a Belarus 420 and a Mahindra which was the easiest yet. All KMW loaders, last one was 4 hours start to finish.
   / ADD LOADER OR REPLACE TRACTOR #18
Hard to believe a link to the sale of a tractor from a legitimate dealer on Ebay poses any harm to TBN, but anyway, the tractor was a Long 64HP American made 4x4 tractor with ag tires and a FEL for $6,990. That's one of the best deals I've ever seen. Tractor looked nice. If you want the link, I can send it to you by email.
I always liked owning 2 of everything so when one goes down, I have a backup. That's why if it were me, I'd buy another tractor with 4x4 and a loader if it only costs a little more than a loader attachment.
I completely understand why someone would only want one machine to keep costs lower, save storage space, less maintenance, etc.
Builder, I assume the link you had was removed. I viewed your response earlier today and was able to view the machine. I agree that looked like a good deal. Not sure what shipping cost would be to have something that size shipped from NY to MS. If I only had one tractor I would more likely be looking for a 4WD unit just for peace of mind. We have two other tractors on the place and for the past couple years have been storing a friend's S250 Bobcat machine with grapple and bucket. The Bobcat machine is very impressive for it's size and has been an invaluable tool for cleaning up and clearing roads. I have considered offering to purchase it from him since he doesn't use it often and not worry about an FEL, but after bushhogging with an FEL and bucket on front makes me want one even more. My thoughts are for around $15000 I can have a like new tractor with no mechanical problems and should last me a lifetime. If I look for the equivalent machine used with 4WD and FEL I am in the neighborhood of $20000 to $25000 and no history of use/mechanical issues. Hours are a good rule of thumb, but I have seen machines with low hours and no maintenace be in worse shape than high hour machines.
   / ADD LOADER OR REPLACE TRACTOR #20
Shipping would be ~$750-850
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
KUBOTA GR2100 RIDING LAWNMOWER (A60430)
KUBOTA GR2100...
2022 Ford F-150 Ext. Cab Pickup Truck (A59230)
2022 Ford F-150...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
