deere5105
- Joined
- May 6, 2009
- Messages
- 1,097
- Location
- South Mississippi
- Tractor
- 2008 John Deere 5303 MFWD, 2004 John Deere 5205
I have a 2WD 5105 John Deere with approximately 250 hrs. Unit has 14.9-28 rear tires loaded with water and two remotes at the rear of the tractor. I use this tractor for basic gardening/farming. I got a really good deal on the tractor and have been contemplating adding a FEL. I have a neighbor that has a 2WD 5205 with 16.9-28 rear tires also loaded with water. I have used this combination multiple times and the only thing I have noticed is that with a bucket full of material you can lose traction. I added a box blade to the rear and it helped significantly. The area I operate in is basically flat with well drained soil. I am trying to decide if it is a good idea to add the loader to the tractor I have or look for a different unit with the loader already on it. I realize the benefits of a 4WD unit, especially with the loader, but my main use for the FEL would be to maintain roads primarily by pushing limbs out of the way when mowing. I am curious if anyone is running a FEL on a comparable 2WD machine with good results or has done what I am considering and wound up swapping machines. Any advice or recommendations?
