Tiller PTO tiller and HP
/ PTO tiller and HP #1
Tractorguy1038
upstate NY
Cub Cadet Yanmar EX 3200
How critical is the HP rated for the tiller on the low side ? The 5' tiller I just bought says it needs 25 HP. Knowing the tractor ratings are a little flakey and my compact (Bolens G275) is 20+ years old, I figure I'm right around that. My plan would be to just not utilize the full depth of the tiller - especially on the first pass. This is existing garden areas that I have plowed and disced in past years. Any thoughts ?
/ PTO tiller and HP #2
I can tell you I have a JD 2320 which has a 24 HP motor with 18HP at the PTO. I run a JD 655 tiller (55 inch width) and I used it to break sod for a garden without any issues.
Bottom line, I don't think you will have any issues.
/ PTO tiller and HP #3
Well, seeing as you now own it, you do what you have to do in order to be able to use it. That may be shallow tills, more overlap per till etc. Might not have to do anything special, a lot depends on your ground. I think that the hp ratings are usually for worst case circumstances.
Good luck with your tiller.
John Deere 7330 Premium (A62180)
John Deere 7330...
2PC. 84" SHELL KIT FOR VOLVO ROLLER (A63290)
2PC. 84" SHELL KIT...
Polyethylene Board Road Bed Protection Pad (A62183)
Polyethylene Board...
LandHonor Mini Auger (A62183)
LandHonor Mini...
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
