BX PTO rpms
/ BX PTO rpms #1
Chugbug
Central Ohio
BX25
Bought my first PTO toy...tool this past weekend:D for the BX25, a Fimco 50 gal, 3pt sprayer....now the questions :eek: From everything I read the rear PTO runs at max 540 rpms with the mid running 2200 / 2400 max rpms.....at what rpms do I need to run the engine to achieve specific rpms for the rear and mid pto's?? Is there a cheat sheet somewhere?? The 6 roller pto pump runs at 540 rpms, what is the minimum engine rpms that I need to be at to gain 540 rpms at the rear pto.....I'm sure these are pretty simple questions but you gotta figure where the simple questions come from:eek: Thanks all......I'll post photos as soon as I can figure it out !!
/ BX PTO rpms #2
The PTO engine speed will be in your tractor's manual. If I remember correctly it's 3200 engine rpm for the rated 540 pto speed.
/ BX PTO rpms #4
Dang near WOT.
certainly corrrect! However since its just a sprayer, you should test it out with just water in tank and drive around in your driveway experimenting with the engine speeds. Going slower then rated RPM should'nt hurt the roller pump. It just giving you a different amount of volume being pumped. However the caveat here is that most equipment runs/works better at the rated speed it was designed for.
Year: 2015 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82,002 (A64557)
Year: 2015 Make...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2020 Toro...
2022 EZ-GO ELITE...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
