diesel oil - is it always dark?
   / diesel oil - is it always dark? #11
I have a bypass filter, the size of a spin-on, a little longer counting the mount. I haven't mounted it yet.
   / diesel oil - is it always dark? #12
I have a kubota I bought new in 06 and have about 160 hours on it - has been a wonderful machine. I changed the oil as recommended. But I notice when I check the oil level that it seems dark for being "new" oil - I fairly recently changed the oil.
My question: does oil in a diesel engine get dark quicker than in a gasoline engine? It looks like I should change the oil it is so dark but I know the tractor is not due for an oil change for a while. Since this is my only diesel I don't have the benefit of experience.
Yes, I owned many diesel vehicles before I got my 1st tractor. And the oil getting dark quickly was one of the 1st things I noticed when I started on diesels. My tractor and RTV are the same. Just a few hours of operation or miles and the oil is dark. Just change it at the recommended intervals (hours) and you will be ok.
   / diesel oil - is it always dark? #13
New oil put into my 26 year old Benz diesel ALWAYS turned black soon as I start it.
The oil in my 2004 JD with nearly 400 hours on it doesn't get quite as black right away, but it does get a black tinge right away on startup.
It doesn't take much oil left in crevices to blacken the new oil.
Ralph
   / diesel oil - is it always dark? #14
Good information, I too wondered on my Kubota that it did not take long for it to turn dark. I was worried I was getting other contamination in it. Now I won't worry too much about it.
   / diesel oil - is it always dark? #15
This brings up something that I've been wondering about.
Where I used to work, I went trough 2 Ford F-Super Duties that were meticulously serviced regularly at the Ford dealership. I was required to inspect the truck and check fluid levels every morning before work.
From the time they were new, the oil got black almost immediately after an oil change.
I bought an old Ford 3000 tractor 2 years ago, and was surprised that the oil looked clean. I figured it had just been changed before I looked at it. But it never did turn black, and I kept putting off changing the oil way past the point I should have. The oil just slowly turned dark, the way gasoline engines do over time.
I know there's differences between the old Ford tractor diesels, and the newer more efficient and cleaner diesels today. But do you think that the oil wasn't doing its job of cleaning the engine? That maybe the guy had a non-detergent oil in it. Or is that normal with the old Ford tractor diesels? I've thought too, that maybe the compression is a lot higher on newer diesels, causing the oil to get dark quicker.
I don't mean to sound dumb here, but I've only owned gas tractors before this one.
   / diesel oil - is it always dark? #16
same here. b7800 oil changes black and keeps getting darker. haven't found it to be a problem. if kabota thought it was an issue they would have put more filters in the system. as i see it adding another filter is another hose able to come loose or get punctured. plus the added cost of another filter.
   / diesel oil - is it always dark? #17
Hard to say what was in it before - some of the old-timers just grabbed whatever was lying around and dumped it in there.. :confused: You did put something diesel rated in, right? ;)
   / diesel oil - is it always dark? #18
Actually, I haven't changed it yet. :eek:
I started to a while back, but started reading about all this ULSD/CJ-4 controversy. Now I'm wondering what oil to use in these older tractor diesels to get the best protection, since oil now (CJ-4) has lower levels of protective zinc.
I may post on the bobistheoilguy.com website and ask the pro's what they think. :confused:
   / diesel oil - is it always dark? #19
The ULSD/CJ-4+ oil controversy is a valid concern and I would refrain from using it in anything that is of the "pre-emissions" variant. John Deere's "50" brand oil is a 15w-40 that is still rated at CI-4+. If your tractor has less than 100 hrs than I would use that, mainly because of break-in. If the tractor has over 100 hrs than I would look into Amsoil 15w-40 Heavy Duty Diesel and Marine Oil. It's a fully synthetic oil and it's still rated at CI-4+. I changed the oil at 50 hrs on my 3320 and replaced it with some left over Shell Rotella-T 15w-40 rated at CI-4+, mainly just to help the rings seat fully from a regular dino oil. At 100 hrs I'll change it to the Amsoil. I have already had great success with the Amsoil in a few personal vehicles.
   / diesel oil - is it always dark? #20
I wondered about the oil darkening situation right after we purchased our little dozer. The guy at the dealership said he had just changed the oil and it was already black as pitch.
Reading this thread I got to thinking about the soot issue and wondering if it might actually contribute some lubricating properties to the oil... After all, we put powdered graphite into locks to keep them operating smoothly. Seems to do a really good job. And all the diesel soot I've ever encountered had an almost soapy feel to it.
Is there any hard data out there that would maybe prove or disprove this theory?
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
