Warping Hood on 2320
/ Warping Hood on 2320 #1
tofriendscreek
Central Illinois
John Deere 2320
I'm curious if any other 2320 owners have this issue. I purchased a 2006 with 16 hours a month and a half ago. It has 39 hours on it now. It is in showroom condition ... except ... when I finished mowing last Sunday, I noticed that at the top of the bottom panel of the hood (where it attaches to the top piece) was warped, like it had gotten hot enough to "melt." This location is where the muffler is situated. Also, there was a place between the warped spot and the dash where the plastice looks like it has bubbled, again like it was hot enough to "melt." Don't have a clue as to whether it will get worse or not. Since I normally blow and clean my equipment after using it, I can say this warped area was not there a week earlier, which was the last time it had been used.
The engine was not overheated or anything out of the ordinary. There is no indication in the owners manuel that tells me whether a heat "shield" should be located on the inside of the hood to protect it from the heat of the muffler or not. The local dealer did not have a 2320 on the lot to check and the parts screen did not show one. I did inquire as to the cost of this piece of plastic and it's just a whopping $275. And It could just be a flaw in the manufacture of this piece.
Thanks for the replies.
/ Warping Hood on 2320 #2
I don't know anything about your tractor, so I'm of little help. But, I do know that it can't be any sort of flaw in the part itself. I design thermoformed polyethylene products, and I'm fairly familiar with other processes. Nothing could cause the bubbling that you see without excessive heat. Next time you run it, check how hot the area is when you're done. Seems like there should be a heat shield, but again, I wouldn't know.
/ Warping Hood on 2320 #3
Not sure if it's the same on the 2320, but my 2520 does have reflective heat shields stuck to the inside of the hood sides. I'm not near it right now, but I'm pretty sure it's on both sides.
/ Warping Hood on 2320 #4
is it warranty covered?
I don't know about the plastic process per se, but I find it very curious that the place where the lower piece has bowed or where it has a slight "run" like when you put too much spray paint on too quickly, there is NO corresponding bow or anything on the top section which is immediate and adjacent. If overheating were the problem, it wouldn't stop at a seem would it?
The alignment of the hood is fine. The motor mounts are tight. The engine was not overheated. I've checked with John Deere and there are no service bulletins, no technical memos, no one has heard of or at least reported this issue before. Again, I don't know plastic processing, but do feel that it is the part itself.
/ Warping Hood on 2320 #6
Maybe I completely misunderstood your description. Can you take a picture?
/ Warping Hood on 2320 #7
For what it's worth, on the 2320/2520, the top part of the hood is metal and the bottom (sides) is plastic.
/ Warping Hood on 2320 #8
Wouldn't this eliminate the possibility of it being from the manufacturing process?
Thanks to everyone who has read this thread and those that took the time to reply. There are still no answers. I took a few pictures this morning, but the internet was down so I couldn't upload them. I'll try again this evening.
First, I didn't realize the top section was metal. Didn't give it thought actually. All my "recent", previous Deere's have had plastic hoods.
Second, as mentioned in my original post, my 2320 is a 2006. It had 16 hours on it when purchased and was in showroom condition. But, it's out of the normal warranty period. I have been in contact with the dealer. They are attempting to talk Deere into sending me a replacement piece, based on the literal fact that this machine hasn't been used enough to even break it in. I will let them do their thing before I step into it and start talking to Deere myself. Thanks again all.
/ Warping Hood on 2320 #11
No:
He should be able to operate/use /run the tractor with out such activity melting the hood.
JD owes him a new hood under warranty.
I have no idea what you're talking about. I think you misunderstood what I was saying.
I hope you get your new hood.
As I mentioned in my original post, my 2320 is a 2006. It had 16 hours on it when purchased and was in showroom condition. But, it's out of the normal warranty period. I have been in contact with the dealer. They are talking to Deere about sending me a replacement piece, based on the literal fact that this machine hasn't been used enough to even break it in. I will let them do their thing before I step into it and start talking to Deere myself. I can't help but think that the issue is a part problem.
/ Warping Hood on 2320 #13
I would be fairly comfortable saying that heat caused that, but, somewhat indirectly. It appears that is some sort of union between two separate pieces, a glue joint perhaps? I would guess that the glue joint failed, for whatever reason, and at that point the heat caused the plastic piece to warp. Without the “structure” provided by joining the two pieces, the plastic would warp fairly easily from the heat of the exhaust
/ Warping Hood on 2320 #14
I just took delivery today of a brand new 2320. It better not start doing that or I'll go and get my 4110 back.
/ Warping Hood on 2320 #16
If it's like the 2520, the muffler is right behind that spot and there should be a heat shield stuck to the inside that looks like a piece of aluminum foil.
/ Warping Hood on 2320 #17
MMagis
I went out an popped the hood of my 06 2320 (more like almost 300 hours on mine though). On mine, there is no heat shield where your damage occurred. I do have a heat shield that runs vertically from where the exhaust pipe comes out of the front of the muffler down to where the exhaust exits at the front left bottom of the engine compartment.
Well guys, after 11 months, too many telephone calls, texts and emails to remember, the warped hood piece has been replaced. The warping was evidently a rare material defect in the plastic. Interestingly, it was not John Deere who came through with the replacement parts. Rather it was the dealer from whom I purchased it. This wasn't even a blip on JD's radar, it wasn't a "fatal" in any way, but it looked pretty bad.
I can't say enough wonderful things about the attention, concern and service provided by Bader & Sons in Central Michigan. Although i live in central Illinois, with 5 JD dealers within 40 miles, I bought my 2006 JD 2320 from Paul
Bader. It was exactly what I had been looking for for over a year.
Earlier in this thread is the history and pics
I just wanted to tell everyone how happy I am about getting the parts. I will put it on. The warped piece slowly got worse over time. The hotter the weather the more it would warp back and forth.
I did learn that there is supposed to be a shielded piece of insulation between the muffler and side hood piece.
My hat is off to Mr. Bader, Bob in service and everyone else who got the pieces replaced. They are great!
/ Warping Hood on 2320 #20
i went out and cheked my 2320 and noticed a little discoloration in the plastic 45hrs so to be safe i cut a piece of stovepipe duct and hosed clamped it to the muffler 4 a heat shield.
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2025 Grapple Rake Mini Excavator Attachment (A64553)
2025 Grapple Rake...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A64556)
2018 International...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
