Pat's Easy Change Pat's Easy Change System - Order Online!
/ Pat's Easy Change System - Order Online! #282
Northern's is Pats. I just got mine and put it on. Easy on, and now EVERYTHING will be easy on!
/ Pat's Easy Change System - Order Online! #283
I think I remember that Pat posted the one's at Agri-Supply are a different version. They are made different.
Thanks for that. I didn't know they had different versions. Would anyone happen to know how many versions there are and what to look out for?
/ Pat's Easy Change System - Order Online! #284
PATG said:
Agri-Supply sells another version of Pat's Easy Change. They are mine. I make them. They do have a different look than the gray ones. We came up a design that takes less machine time to try and lower the price. That was what I kept hearing on this board and several others. We worked on this for a long time and had them certified as to weight capacity. Several neighbors have been using them for a year now and have not had any problems with them. Agri-Supply has priced them to sell when you consider that they have the sta-bar included.
Here is Pat's description of them
/ Pat's Easy Change System - Order Online! #285
/ Pat's Easy Change System - Order Online! #286
They sure look the same, and considering it includes the stabilizer bar, it's a good deal.
/ Pat's Easy Change System - Order Online! #287
Thanks for that. I wonder how much real difference there is between the two. Which ones do you have?
I have the original ones, the gray colored ones. I've had them for 4-5 years and have never taken them off yet.
/ Pat's Easy Change System - Order Online! #288
I just compared the photos. The ones at Agri Supply don't appear to be as "Heavy Duty" as the ones posted on this site. I'm not sure which version Norther Tools sells.
/ Pat's Easy Change System - Order Online! #289
You were a big help. I'm glad I caught your message before I placed the order.
/ Pat's Easy Change System - Order Online! #291
Just remember, ordering through TBN helps support this free forum.
Looks like the ones on this site are the better ones too. Do you use the stabilizer bar?
I was not aware that Northern Tool was selling the "original" Pat's Easy Change for $159... on their website it's $179.99 plus shipping, not including the stabilizer bar.
As others have mentioned, the $159 model isn't the same as the one we sell. I suppose we could sell the cheaper version just to show people that there is a difference.
We only sell the "original" Pat's Easy Change. It seems that some folks might be buying the cheaper version elsewhere and don't understand the difference.
/ Pat's Easy Change System - Order Online! #293
I have used the stabilizer bar a few times. Usually it seems that the arms are just sort of spaced just right. I'll bet I'd have to go hunt for it right now, I haven't used it in so long.
/ Pat's Easy Change System - Order Online! #294
Thanks Inspector507!
/ Pat's Easy Change System - Order Online! #295
Looks like the price just went up at Northern from $159. Muhammad, have you considered advertising the stabilizer bar on this site?
We offer it with the Category 1 or 2 Pat's Easy Change System for an additional $20...
Perhaps we should offer it as a standalone item?
/ Pat's Easy Change System - Order Online! #297
I must have missed it when I was looking. Your idea sounds like a good one.
/ Pat's Easy Change System - Order Online! #298
Hi Guys,
Been Lurking here for quite awhile. I'm really interested in getting Pat's system. But I'm a little concerned, Some of the earlier posts stated after installing that guys were having trobule with attaching their PTO shafts due to the added length of Pat's hitch.
I'm pretty new to all this so, Is this really a problem or do the PTO Shafts have enough play to compensate for the extra 3 inches.
I'd be installing these on a Kubota B7800
I hoping this would make switching my Bushhog and other attachments easier but don't want to create another problem by solving one. I read thru the entire post and didn't see where anyone solved the issue other than to spend even more money getting an extension for their shaft, which to me dosen't seem like it solves the problem.
Thanks,
TJB
/ Pat's Easy Change System - Order Online! #299
TJB63,
I've had Pat's Easy Change system on my B7800 for two years. I use a Woods Brush Hog and a Landpride rear finish mower. I've not had a problem with the PTO shafts on either of these attachments, but the Pat's system does extend the arms. If you still have the original turnbuckle type "check chains" on your lower lift arms you will find the Pat's system with a stabilizer bar to be especially helpful as you won't have to keep adjusting the chains. The folks at Pats are also super to deal with if you have any questions.
Hi Guys,
Thanks,
TJB
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
SET OF (3) BOX MOUNTS (A63569)
SET OF (3) BOX...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
Wolverine 72†Skid Steer Screening Bucket (A64047)
Wolverine 72â€...
