PTO Stuck
/ PTO Stuck #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
I did a little Brush Hogging today with my Woods Dixie Cutter, When I was finished, I pushed the Yellow Handled Lever down on my TA 247 to disengage the PTO. It went down but the PTO kept turning. I tried to shift out of PTO speed 2 and it was locked. Did not help to put everything in Neutral or to push in the clutch. Now, My PTO is running all the time. I hope there is an easy soulution to this new problem. Any Ideas? Or do I Now have full time PTO>? confused:
Thanks.,Gents.
/ PTO Stuck #2
Sounds like a linkage type problem yomax4 , But without looking I honestlly cant tell You how its hooked up . I have a 247 also , I,ll look afterwhile & see if I can see anything that might be causing your problem on Mine . Bob
/ PTO Stuck #3
Ok I went out & looked . I,m sorry I had sold the 247 . & now just have the 240 & 255 , Which are diffent from each other. But I would guess My 240 would be closer to yours then the other.
That being said is Your PTO controls on the right side or the left side . My 240 is on the right side. I took a few pics. & If You can locate where it hooks in after the linkages to at least eliminate a linkage problem will help. Unless You,ve allready done that.
The first pic is the PTO lever itself . Its hooked to a swing arm that goes to another lever that goes to the PTO control on the gear box itself which is in pic 3.
I would check all of those linkages & make sure everything is hooked up & not slipping on the shafts . Then if the lever going into the gear box is moving & Doesn,t have a clickish feel to it Then its inside the gearbox where the Problem is . Which is another story .
So if You can do some checking & let Me know , I,ll do some more checking & see what else I can find out. Sorry about the dirty tractor but I just got in from mowing. Hope this helps a little bit. Bob
/ PTO Stuck
I most definately appreciate the help. On my 247 there is a yellow handled pull straight up lever right in front of the Diff lock on the right side rear of the floor boards. That I am told engages and disengages the PTO. On the other side there is a 4 speed PTO shifter in the H pattern. The Yellow handled push pull lever seems to go in and out but the 4 speed shifter is stuck in 2nd. I am affraid its internal and I dont know why. This Tractor has never used the PTO since it was new. Anyone want to buy it> HAHAH.:confused:
Thanks.
/ PTO Stuck #5
Ok, sounds more like My 255 , But I dont recall using a lever on the right side though , Which doesn,t mean anything as I run them so much I can run it blindfolded .
So I,ll have to look when it gets light. But it does have the 4 speed pto shift lever on the left like You say. The pics above is the 240 & the controls are all on the right side so I,m sure they wont help .
I still think it could be something else other then internal , But thats just Me always wishing for a simple fix :D .
Anytime I ever have any kind of problems , the first thing I do is look for mudobers nests , Darn near burnt My big one up because They had built a nest in the steering column & shorted out the ignition switch :eek: . But they seem to like the linkages as well .
Anyway I,ll look afterwhile & take some pics if it looks like it Might help . Untill then best of luck. I,d be interested in buying it if You were closer :D . Bob
/ PTO Stuck #6
OK, On mine there is no pto lever just the H pattern shifter & when in the nuetral position the PTO is off . There apears to be some type of linkage but its where I cant see it or take pics, without removing the rear tire . So once again I,m no help . :eek: .
So unless someone can add that has a similiar setup only thing I can do is wish You luck . Unless it would be helpfull for me to remove the rear tire on Mine & look at it a little closer. Just not sure it would help your situation though. Let Me know if you think it would. Bob
/ PTO Stuck
No Sir,, I will look closer. I can pull my tire off and remove the cover and see what makes her tick. Thanks for the reply.
MM.
/ PTO Stuck #8
Best of luck MM & dont forget to take pics & let Us know what You find out. :D . Bob
/ PTO Stuck #9
Hey Bob, being as how you are such a generous person, could you take the cylinder head off your tractor and let me know if the cylinders are sleeved or not? JUST KIDDING BOB!!! Knowing you you probably would, haha. Thanks for all your input Bob. I'm pretty limited with my smaller older model Iseki, but try to help when I can....except for removing the head that is! :D
/ PTO Stuck #10
Thanks for the laugh larso1 , I didn,t see that one coming :D . I sure hope I never have to pull the head off though :eek: . I cant remember what size tractor You have , but Speaking of small . I bought the wife a little baby Yanmar that makes Mine look huge , I cant even hardly get on the darn thing but it fits Her perfectlly . :D . Bob
/ PTO Stuck
Hey Larso1 do you still have the pic of that Iseki Tracked Vehicle? I believe I got it from you a while back. I miss placed it and would like to have it again.
Thanks.
/ PTO Stuck #12
Thanks.
yomax, yes but it's on my work computer. I'll try to remember to send it tomorrow.
/ PTO Stuck
Nothing like helping yourself. I removed the rear tire and access plate so I could better see the linkage for the PTO. After a minute of flashlight work I saw a small rock wedged in there. I cant imagine how it got in there judging by how hard it was to remove. It turned out to be a piece of Marble. We dont have Marble here. Maybe its Granite. Anyway. The linkage is free and I will try to control the frustrated and dumb questions. Thanks for the help.
MM.:eek:
/ PTO Stuck #14
Howdy yomax4. I've been through all 41 pages of Iseki posts, and yours seem to be the only ones on TA247F. I just bought one while home on leave from Iraq. Can't wait to get home to MN and put her to work. Hope to pick your brain since you have had a couple years to familiarize yourself with yours. Mine came with what appears to be an unused Koyker 125 FEL, Rhino 148 mower, and I just picked up a Leinbach disc cheap. Do you still think the Massey 1240 manual is the best resource, or have you found something better? Thanks in advance. Drew
/ PTO Stuck #15
Hi maybe i can throw some light on the problem, in as much that my pto would engage in the 1000 but not the 540, i decided to look inside the PTO & after checking all the linkages, it meant a complete strip down of the rear end to gain access, what i found inside would make you cry, the main gearing was completely stripped, the problem was caused by the inner shift arm , this keeps it in one of the three positions by a ball bearing under preasure by a spring, which slides up and down the selector rod, this had got stuck by some debri from the gears keeping the pto from selecting the 540, the problem with yours will be the opposite, in that the selector rod within has locked in to the shaft thus keeping it in drive, after the initial strip down getting at the pto was a walk in the park,. i hope this may help in a small way ..
/ PTO Stuck #16
Hi isekitract , You might have Missed post # 13 . Where He had found it was a rock wedged in the linkage . It sounds like Yours was much more serious , Glad You got it figured out . Bob
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
2008 R&R FLATBED WINCH TRAILER (A63569)
2008 R&R FLATBED...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2008 Ford E350 Armored Car (A64047)
2008 Ford E350...
