B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #1
jas67
Central PA
Kubota B7610 + Kubota G1800-S
I am adding rear remotes to my newly-purchased B7610. I am going to tee into the tank return connection for the FEL. It connects with a JIC-M8 fitting that threads into the side of the transmission. If this is an NPT fitting, it is likely either a 3/8, or 1/2, but I can't really see the threads, the hex is up against the transmission housing. So, this could be an ORB or a BSPP fitting as well. I didn't remove it yet to look, as that would require partially draining the HST. I am not quite ready to change the HST oil yet, and don't have a clean/new oil pan to drain it into, for re-use (esp. one that can hold several gallons, although, I could buy one).
Has anyone here had this fitting off, and know what it is?
Thanks,
Jay
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #2
Thanks,
Jay
Jay, when I did my 7510, I'm pretty sure it was 1/2" but don't completely remember but the nice thing is...you don't have to drain the HST. I just backed mine out and only a few drops of oil dripped. I'm pretty sure the return is above the oil level. if not...you can easily plug it with a rag while you confirm the threads...
I have the part manual and it only ID's it as part #
75582-66810 NO description of thread size....
Good luck
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #3
Also we require good pictures and step thru instructions so we can duplicate your work!
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #4
Oh sure, I do the hard work and you get step by step instructions.... I see how it is....
Seriuosly though.. Here are the thread links I posted..
I started with just a rear hydraulic loop for my splitter and then added the rear rear remotes with PB to keep the splitter loop...
All my pictures and descriptions are here . E mail me if you get stumped...
Splitter loop. Go to page 2
http://www.tractorbynet.com/forums/kubota-owning-operating/138537-log-splitter-connections.html
Rear remotes..
http://www.tractorbynet.com/forums/...ng/139050-rear-remotes-finally-installed.html
You can go with a smaller valve than I used. Let me know if you have questions...
Ordered everything from Burden Surplus Supply....
Good luck.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
CATERPILLAR 299D3 SKID STEER (A60429)
CATERPILLAR 299D3...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
