B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #1
jas67
Central PA
Kubota B7610 + Kubota G1800-S
I am adding rear remotes to my newly-purchased B7610. I am going to tee into the tank return connection for the FEL. It connects with a JIC-M8 fitting that threads into the side of the transmission. If this is an NPT fitting, it is likely either a 3/8, or 1/2, but I can't really see the threads, the hex is up against the transmission housing. So, this could be an ORB or a BSPP fitting as well. I didn't remove it yet to look, as that would require partially draining the HST. I am not quite ready to change the HST oil yet, and don't have a clean/new oil pan to drain it into, for re-use (esp. one that can hold several gallons, although, I could buy one).
Has anyone here had this fitting off, and know what it is?
Thanks,
Jay
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #2
Thanks,
Jay
Jay, when I did my 7510, I'm pretty sure it was 1/2" but don't completely remember but the nice thing is...you don't have to drain the HST. I just backed mine out and only a few drops of oil dripped. I'm pretty sure the return is above the oil level. if not...you can easily plug it with a rag while you confirm the threads...
I have the part manual and it only ID's it as part #
75582-66810 NO description of thread size....
Good luck
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #3
Also we require good pictures and step thru instructions so we can duplicate your work!
   / B7610/B7510/B7410 (maybe B2410/B2710/B2910) remotes;tank connection fitting size/type #4
Oh sure, I do the hard work and you get step by step instructions.... I see how it is....
Seriuosly though.. Here are the thread links I posted..
I started with just a rear hydraulic loop for my splitter and then added the rear rear remotes with PB to keep the splitter loop...
All my pictures and descriptions are here . E mail me if you get stumped...
Splitter loop. Go to page 2
http://www.tractorbynet.com/forums/kubota-owning-operating/138537-log-splitter-connections.html
Rear remotes..
http://www.tractorbynet.com/forums/...ng/139050-rear-remotes-finally-installed.html
You can go with a smaller valve than I used. Let me know if you have questions...
Ordered everything from Burden Surplus Supply....
Good luck.
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
FORKLIFT (A56857)
FORKLIFT (A56857)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
