Ford 2009 V-10
Status
Not open for further replies.
/ Ford 2009 V-10 #41
How do you justify that?
first off, if you are the drive it into the ground type, resale value is negligable.
if you hold on to it for several years, lets assume you get an extra $1000 for that $8000 option.
the only way higher resale value help the long term owner is if there is an insurace claim.
Ward's automotive did a study a few years back on resale value of full size diesel trucks versus full size gas trucks.
At 100K miles, they found that a diesel truck is worth $5,000 more than a comparable gas truck.
So if this guy "keeps his truck for a while" (100,000 miles is a while for a gas truck) he would probably get ~ $5,000 more for his truck, not $1,000.
/ Ford 2009 V-10 #42
Oh and every time you read about some report of a Cummins or Duramax, just open the door of that Ford and remind yourself, none of those Cummins or Duramaxes are installed in anything nearly as nice.
Opinions opinions!
I have had Fords in the past, still like them, but like my Dodge/Cummins just fine. Have friends with F250's that I like, but they aint no better than my Dodge.
/ Ford 2009 V-10 #43
Michelins LTX AT2 is the best all around tire out there right now ..... check it out .....
/ Ford 2009 V-10 #44
i also disagree with the dodge chassis not being as good as the ford. i have a 99 3500 ram 24 valve cummins. before this i owned a f-150 same year my dodge is much nicer indside. i bought the dodge used 3 years ago. i have heard reports that dodge has stepped up their interiors, my response is this is not a daily driver there is always somthing in the back or on the ball when it's running, why does it have to look like a cadillac indside. and i happen to have one of the diesel that gets great fuel economy i get 20 plus running down the highway with something in the back say a 600 pound snowmobile. last weekend i did some tilling it was a 100 mile round trip manually calculating i got 18.5 mpg towing a 16 tandem with my tractor and tiller on.
/ Ford 2009 V-10 #45
Chris:
I'd like to replace the Firestone Steeltex all-season tires on my F-250. I'd like something a little more aggressive for when the snow flies; but I don't want to go full bore off road tires because of the noise and mileage hit because of the tread pattern.
I'm partial to Michelin; but I'm open to suggestions.
Thanks,
Matt
Steeltex and the newer replacement Transforce tire come in 2 treads. HT and AT. Hts are highway while the ATs are a more aggresive tire. The ATs wore faster in the outer position on my 3500 dually.
/ Ford 2009 V-10 #46
So you pay $8000 to get $5000 more back. Loss of 3K on the option without maint/fuel cost figured in. As for the V-10, it used to have spark plug problems blowing out but they got that fixed.
In 2001 Truck Trend tested the V-10 of Dodge and Ford aginst the 8.1L V-8 of GM in 4X4 dually pickups. The Ford only beat the Chevy in the 1/4 mile by 0.10 second. In towing a 10K trailer, the Chevy was the only truck that didn't have to downshift on the test grade. All three were 250K mile rated engines.
My 2001 8.1L should hit 100K this year as it's at 86K now.
/ Ford 2009 V-10 #47
I didn't pay $8000 for my diesel option. I paid like $7,000.
and the V-10 is also an option. It costs at least $1,000 more than base gas price.
So with the $5,000 trade in advantage, we're down to a whopping $1,000 differential.
For $1000 over 100,000 miles, I get 25% more torque, better acceleration with trailer, no emissions inspections, no tune-ups, less stops at the gas station, dual batteries and the envy of all the gas truck guys. Not bad for 5 years of ownership. :)
/ Ford 2009 V-10 #48
99YV10, 6.8 Liter 498.00 600.00 (Increases GVWR) Includes 4.10 Axle Ratio w/Limited Slip.
/ Ford 2009 V-10 #49
If you lived in Taxorado, you would get to take your diesel in for emissions inspections every year I believe versus every two years for a gasser.
/ Ford 2009 V-10 #50
I tend to stay out of these "best truck" discussions. I have had a 1999 Ford F250 V10 and currently a 2008 F250 diesel. The V10 is simply a great engine. Change oil, add gas and drive. Still using the F250 gasser as a farm truck. It has spent 80% of its life pulling a trailer of some kind. Essentially zero repairs other than a few early recall issues and regular maintenance. There are no "tune ups" until 100,000 miles for the plugs to be changed. I probably would have purchased another gasser but was difficult to find one with the options I wanted. Decided to try the diesel. I like the diesel but not it is a clear overall winner IMHO. When I bought my diesel, the cost of fuel was about 40 cents higher. Now diesel is about 30-40 cents lower but takes a lot of fuel savings to make up the difference in cost of diesel engine a maintenance. My gasser made about 10 mpg pulling loads. My diesel makes about 12-13 with same pulling conditions. The diesel with 350 hp pulls better than the 1999 V10 which was about 275 hp. However, the transmission in the newer fords have more gears and shift better than the 1999 trans. The newer V10s are near 350 hp and the difference would not be as noticeable today. People brag about the torque of a diesel but I would not have any problems with a gasser of similar hp. Just need to rev the gasser into the power band and it will perform just fine. I think the diesel torque is more about bragging rights than the price may justify.
The V10 is not much more expensive than the base engine, around $600 list.
Because of the huge rebates from ford and poor dealer sales, the price of my 2008 diesel was about $2000 more than what I paid for my 1999 V10 gasser. Both were Lariat's and the diesel had a few more options than the gasser, better transmission, tires etc.
/ Ford 2009 V-10 #51
I too have both; a V10 and a diesel. I've owned a diesel truck of some sort for over 20 years. Clearly I haven't had a V10 that long. I do have to laugh at the comment that the guys with a V10 gas are envious of the diesel trucks. Needless to say, that's not the case. I like both engines personally. I can pull more with the diesel, but let's face it, not very many people are hauling at or above their absolute maximum load every time they hop in their truck.
/ Ford 2009 V-10 #52
Dargo, you and radman1 are right on the mark!;)
/ Ford 2009 V-10 #53
I finally had my first issue with my V-10, and no it wasn't the spark plugs blowing out of the heads. Something called a DPFE (Differential Pressure Feedback EGR) sensor went bad, and apparently sensors of the 1990's vintage Ford cars and trucks were prone to going bad due to the aluminum housing. Newer sensors use a plastic housing.
I wasn't pleased at the $300 parts & labor bill; but that still is cheaper than a new truck, especially since I'm still happy with my rig.
/ Ford 2009 V-10 #54
Its funny to read of the associations that some people have and the effect of marketing on their brains.....
I love diesels... But not when they are out of warranty.... I would gladly pay $300.00 for a fix out of warranty... Most gas engines are fairly simple to work on, and if I were looking for a high mileage vehicle, it would not be a 2004 or newer diesel.... Injectors and pumps are way too expensive.... And way to commonly replaced in the new diesels.
/ Ford 2009 V-10 #55
I have had both the Ford V10 and two PSD's one a 2002 and one a 2008. I now own a GMC 2500 diesel which has almost 6,000 miles on it (owned 7 weeks). Regarding the Ford V10, it is an excellent engine. The power has been upped for 2009 v. the one I had but my truck was quiet, durable and powerful. It did struggle to pull heavier loads on hilly terrain, but would get the job done. Interestingly, the modular Ford gas engines are very durable and will easily give greater than 200K service if well-maintained, even when worked hard. Ford has done a good job with the running gear on the truck. The axles, cooling system, frame, suspension, etc. are top notch. They do give away some drivability for heavy duty stability but I like the fact the new Fords drive the same with 100K on them as they do with 10. Even though I no longer own mine, I really liked the 6.4L diesel. The word of problems in them is much overrated. The radiator position was subject to damage and caused some problems but by and large they stayed out of the shop. Most folks, myself included, who had them were happy with them. I am sad to see its run so short as it had great potential as an engine. I have been very happy so far with my GMC. The fit and finish are great and although it is not as flashy as my Ford, it still looks good and drives like a 1/2 ton. The power cannot be beaten and it gets much better mileage than did my 6.4L, which really wasn't that bad. These things said, if I personally were to buy another 250 right now, I would strongly consider the V10 engine. My understanding is that it also might go away, replaced by the 6.2L hurricaine V8.
John M
/ Ford 2009 V-10 #56
I agree, JCM. If I had to buy gas, it would be a Ford V-10 as they have the best gas truck engine out there right now. With the 8.1 gone, GM & Dodge really don't have a truck-like engine. The way diesels are going, I'll probably go back to gas on my next new truck unless things improve with diesels. I'm holding out hope for 2 of the non-Ford brands to offer exhaust brakes on their pickups to decide. IMO, Dodge has the best chassis package right now, (Cummins/Ex Brake/Aisn/11.5" rear) but their future is so muddled right now that buying is out. Let's see what FIAT does with them for a few years. Besides, you can't get the Aisin in a pickup, must be chassis, but that works for me and my service body.
However, the V-10 is not a substitute for a diesel IF you're using a heavy duty pickup for its' intended purpose. The obvious fact is that the torque just isn't there. If it was, they'd be stickin V-10's or other gas variants in bigger trucks and they'd be outselling diesels, but they're not. It's not even close.
My FIL has a F-350 with a V-10 and it's a blast to drive empty, but when he hooked only an 8K trailer to it, you could really feel it back there. Not from a suspension standpoint, but when we hit the hills, it just downshifted & revved a lot and that's when they really gulp the fuel. If you had to tow heavy year round with the V-10, it would cost considerably more than a lower revving, higher MPG diesel, even if diesel costs 25 cents more/gallon. That's the beauty of torque down low in the RPM range-the fuel savings and longevity on the internals.
Glad to hear all is well with the GMC. The fit & finish, although thoroughly trashed by most, is just fine on my truck, too. I haven't had anything to complain about at almost 40,000 miles except my seat has a tiny squeak when you sit back a certain way. Have you had a chance to play with the Allison manual shift paddle? I use mine all the time and love it when towing. I can feather the gears with just a tap of the toggle switch, works like a dream for slowing the beast down!
/ Ford 2009 V-10 #57
That may be but it it cost at least $5000 more to begin with.
/ Ford 2009 V-10 #58
Duane,
Not to get away from the original discussion, but I have been very impressed with the workmanship on my GMC. It is tightly made and very solid in feel. I have had a couple small interior rattles which I called to the dealer. They hopped on it right away and fixed them. One thing I can say so far: the dealer with whom I am working is on the ball in service and sales. I have owned Ford products for my entire driving career and bought many of them from our local dealer with whom I have a friendship, Despite this, the Ford dealers--even this one-- with whom I have worked have fallen far short of this GMC dealer in service. I must say this is the tightest, best fabricated truck I have owned. Not to say it is the most-heavily made, but it has the best workmanship that I have seen. No wonder GM is in protection, they replaced two small interior panels for me to fix my small interior problem, even though I did not think they needed to. The SM said it was the right way to do it and they do things the right way. He is pretty sharp and I believe him.
John M
/ Ford 2009 V-10 #60
Duane,
John M
Sounds like you found a good dealer. I have noticed in the last month while having over $2000 of work done to my dads Corvette that the GM dealer was great. Not my experience in the past. I guess they are now taking things seriously.
Chris
Status
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2019 VOLVO VNL64T760 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 VOLVO...
Caterpillar Lift Truck Parts and Service Manuals (A63117)
Caterpillar Lift...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A64279)
2020 CATERPILLAR...
2012 Caterpillar CB54 Articulated Tandem Drum Vibratory Roller (A61572)
2012 Caterpillar...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
