Installing Power Beyond on 955
/ Installing Power Beyond on 955 #1
Acehardly
Amissville, Va
L & G 345, X595, 2305, 955 W/FEL
Has anyone installed a PB on a 955? It looks like it is quite a job.
Thanks...
Tony
I got my PB today, I'll let you know how bad it was.
Thanks...
tony
/ Installing Power Beyond on 955 #3
I can't speak to installing the PB on a 955; but I did install a PB along with the 3rd, 4th, 5th SCV kits on my 4200.
Just take your time, get plenty of crowfoot wrenches for the fittings and torque them to specification.
Also, if you don't have a 3rd SCV kit installed; but you do have a loader, take a look and see if the loader SCV has a third spool. If so the the third SCV kit will use that spool.
In my case I installed the PB and 3rd SCV at the same time since the PB tied into the loader's PB port as I recall.
/ Installing Power Beyond on 955 #4
Sorry I missed your first post Tony:eek:
I looked in JDParts and could not even find the PB kit! I hope it goes well for you...
JDParts has it listed as Auxiliary Hydraulic Kit PN:BM16763.
Here is a pic:
/ Installing Power Beyond on 955 #6
I have done 3 955s. It is totally different from the 4200/4300/4400. The
only part I bought was the hex plug (#15 in your dwg). I prefer hoses
to the hard lines. The hardest part of the install is the fact that you have
to remove so much stuff (fender, seat support, controls, etc.).
There are some postings on TBN about this.....do a search.
/ Installing Power Beyond on 955 #7
Here is a pic:
That's the same operational concept as my 4200's PB kit; but simpler. I like the hard lines as they take up less space compared to hoses. I doubt it will take you long to install the kit, especially if you don't have to remove a wheel and a fender.
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
2017 Ford F-350 Knapheide Service Truck (A66736)
2017 Ford F-350...
2019 Ford Escape AWD SUV (A66738)
2019 Ford Escape...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
2012 FREIGHTLINER M2 6X4 T/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
