Installing Power Beyond on 955
/ Installing Power Beyond on 955 #1
Acehardly
Amissville, Va
L & G 345, X595, 2305, 955 W/FEL
Has anyone installed a PB on a 955? It looks like it is quite a job.
Thanks...
Tony
I got my PB today, I'll let you know how bad it was.
Thanks...
tony
/ Installing Power Beyond on 955 #3
I can't speak to installing the PB on a 955; but I did install a PB along with the 3rd, 4th, 5th SCV kits on my 4200.
Just take your time, get plenty of crowfoot wrenches for the fittings and torque them to specification.
Also, if you don't have a 3rd SCV kit installed; but you do have a loader, take a look and see if the loader SCV has a third spool. If so the the third SCV kit will use that spool.
In my case I installed the PB and 3rd SCV at the same time since the PB tied into the loader's PB port as I recall.
/ Installing Power Beyond on 955 #4
Sorry I missed your first post Tony:eek:
I looked in JDParts and could not even find the PB kit! I hope it goes well for you...
JDParts has it listed as Auxiliary Hydraulic Kit PN:BM16763.
Here is a pic:
/ Installing Power Beyond on 955 #6
I have done 3 955s. It is totally different from the 4200/4300/4400. The
only part I bought was the hex plug (#15 in your dwg). I prefer hoses
to the hard lines. The hardest part of the install is the fact that you have
to remove so much stuff (fender, seat support, controls, etc.).
There are some postings on TBN about this.....do a search.
/ Installing Power Beyond on 955 #7
Here is a pic:
That's the same operational concept as my 4200's PB kit; but simpler. I like the hard lines as they take up less space compared to hoses. I doubt it will take you long to install the kit, especially if you don't have to remove a wheel and a fender.
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
PORTA POTTY (A67714)
Kioti KL4030 Loader (A64912)
Kioti KL4030...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
(3) 20.8 R42 & (2) 420/90R30 Tires (A64912)
(3) 20.8 R42 & (2)...
2023 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2023 WEILER K560...
