BX23 Loader
   / BX23 Loader #11
I'd say the backhoe and end loader got sold, stolen, etc at some point in the machines past. I agree, call Kubota and find out, but I bet you can still get a loader for it.
   / BX23 Loader #12
I'm not quite sure what to think here... The sticker on the loader subframe says LA210, but yet the control valve is mounted to the tractor. On a LA210, the control valve was bolted to the loader.. The LA211 left the valve attached to the tractor.
But I guess the actual hitch points may be the same from LA210 to LA211, so maybe the dealer just peiced the thing together to get the front blade on it.
Just curious, is there a sticker on the valve side hitch point? Can you get a picture of the valve side hitch point?
Jeff
   / BX23 Loader #13
Bimmer,
You wouldn't want to get rid of that blade and quick hitch, would you?
   / BX23 Loader
Called and yes, LA211 is availabe as a unit or in parts. $$$ either way :)
Jeff
Kubota says LA211 will fit onto a LA210 bracket
Bimmer,
No :)
   / BX23 Loader #15
or mabe the tractor is stolen and the other parts ar at the oners place?
tom
   / BX23 Loader
tom
I wouldn't think a Kubota dealer would be selling stolen equipment.
jason
   / BX23 Loader #17
Jeff
My LA211 has the valve attached to the loader. Valve goes with loader when detached from tractor.
   / BX23 Loader #18
Hi and Welcome to TBN.
LB59 and Escavader both have BX23s and I'm sure they will be happy to help you out. Good luck with your new machine.
The BX23 came standard with both the BH and the FEl.
If the tractor don't have both attachments it's not really a true BX23.
I'd be leary of dealing on this unit as something don't appear right.
Thanks for the replies. This is what the tractor looks like and it looks like the FEL attachment bracket is there, just needs the actual loader bucket, arms and hydraulics?
Where is the BH?
No BH and No FEL = No BX23.
The Bx23 did come with a loader and backhoe, if it is a BX2230 then it can be without the loader, the valve is part of the kit. The Bx2230 uses a LA211 loader and their may be a Woods and other ones that may fit also. David Kb7uns
No BH and No FEL points to a suspicious or questionable past.
welcome to the forum
1*I think all the BX23's had loader and backhoe was the only way they came.
2*Well at least mine is a TLB.tom
1*&2*The only way you could get them.
1*Kind of a red herring there.
2*A BX23 with no hoe or loader,
3* but a rear bagger with no MMM,
4*You may want to check the actual serial to be sure you actually is a BX23 and not a hood/side panel replacement installation from a BX23.
5*The foldable rops says BX23, but I'm not sure as I think it was optional on early BX's.
1*I stay away from red herrings as they scare me.
2*It's not a BX23 without them.
3*Why a bagger when there is nothing to mow with. This looks really way out of place?
4*A hood/side panel replacement installation from a BX23 would be my guess.
5*The BX23 came standard with the folding ROPS but was optional on others such as the BX2230 I think.
1*I find it odd that the loader and BH is missing as that is how the bx23 is configured.
Yes that is the loader brackets on your BX23.
2*I can't fathom people buying BX23's without loader/BH when a BX1500 or simalar would suffice as the same thing.
3*I am thinking that you got a repo'd unit and they forgot to grab the BH and loader.
4*A BX23 without loader is useless IMHO.
1*That's real strange.
2*Rite on.
3*Something's fishey.
4*To many oddities makes this worthless in my book.
My BX23, purchaced spring of 2004, came standard equiped with the LA210 loader, as well as the BT600 backhoe. The mount in your picture is the same as the FEL mount on mine.
jason
   / BX23 Loader #19
bimmer- I hate to say it but I think you got taken or something like that. Are you sure it's a acutal kubota dealer that sold you the unit ?:( Please record the serial number and model that is onm the frame near engine and call kubota directly and see what they have to say. Don't call back your dealer until you got more info. You also might want to inform the local police the serail number to see if anything shows up on thier record as well. There are too many odd things for this BX. You also might want to take a pic of the alternator and post here to see which one it got the dynamo or the upgraded unit. I am guessing that if it a BX23 with standard alternator, we would know its a BX23 or not.
   / BX23 Loader #20
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
