I can't go Green, and this is why:
   / I can't go Green, and this is why: #21
Well the power was off at night so the PV's were not going to work. :D But the next morning they would have. Since watts is watts, why would the PV's not power the freezer? If there is 6,000 watts going into the house that is enough to power the fridge. We do have a grid disconnect already for the generator.
Later,
Dan
Because of the varying input from a solar panel, an inverter needs something to stabilize it's power source. In a competely disconnected off-grid system, this would be a battery to carry it over short duration light interruptions as clouds pass over(or the sun sets), and to absorb the excess energy when the load is less than the PV supply to provide power for the low/no sun situations.
In a grid tied system, the grid performs the duties that the battery normally would, particularly the absorbing the excess energy. No grid power available, the inverter purposely shuts down to:
1. Avoid the inevitable power fluxes caused by varying power from the PV panels. What this would seem like is standing at your main panel breaker and randomly flipping it on and off. Your equipment would love that, as would the inverter having to deal with repeated startup surge loads:)
2. To prevent the inverter from backfeeding the now dead grid while lineman are attempting to work on it...
Now if you disconnected the grid and substuted a generator to provide that input to the inverter, the inverter could probably be made to mix the two sources, as it does with grid power, and you could use some of that solar energy when available. But the grid tied inverter is designed to direct it's excess to the grid, and the generator might not take too kindly to that. Also running a generator lightly loaded is not very economical.
For purely backup power needs, a generator is the best bang for the buck IMO...
   / I can't go Green, and this is why: #22
Moss, it's not leaking....evaporating. It's in the middle of a 5ac pasture that is almost flat, so it gets no rainwater unless it's a frog choker. When I dug it I knew it would need help during the dry season.
I just got off the phone with Robinson Solar Systems in OK. They build their own brushless solar water pumps(YES, made in the USA), and have a complete system w/solar panel in the $1700 range that would do about 1100 gallons a day. This is more in line with the farm budget.
Here is their link:
Solar pump and solar pumps for solar water pumping from wells ponds and creeks
RD
Here is a link to some spiral pump info. I think it could be done for far less than $1700, and have $0 operating costs...
The Spiral Pump: A High Lift, Slow Turning Pump
   / I can't go Green, and this is why: #23
Here is their link:
RD
I've got a 24' swimming pool that is only 42" deep. It is 12,000 gallons. It would take that pump 10-11 days to fill that little pool provided there was no other losses. How big is your pond?
   / I can't go Green, and this is why: #24
Just to be clear, if you had a grid tied system with batteries, you could still use the power as the inverter wouldn't shut you off right?
   / I can't go Green, and this is why: #25
That would be correct. The inverter used in a grid tied system with batteries has different programmed operating modes to deal with backfeeding the grid, charging the batteries, feeding the load ect. It is set up for just that purpose. Unfortunatly, with the expense of the different inverter, additional wiring, setup and most especially batteries, not many people go this route just for backup power as the grid is typically pretty reliable...
   / I can't go Green, and this is why: #26
That makes sense. I had originally thought about, when I build, going with a grid tied plus batteries. But you bring up a good point. If the grid is 99%+ reliable, why not just go with the grid tied, with a generator backup.
Ron, very interesting pump, but it looks like it would take some time to build. Are there commercial ones available?
Moss, even if empty, once filled, a solar pump would keep it topped off indefinatly whenever the sun is out.
RD
   / I can't go Green, and this is why: #28
Over the last year or so the Wall Street Journal has had a couple of articles about the price of PV getting cheaper. One article quite a while ago said the some very big companies were getting into PVs and that the price per watt would bet $1. The $1 per watt would be some sort of Holy Grail price point.
A month or so ago there was another article that said the price was down to $2 per watt.
We had a storm about that time that left us without power for 6-8 hours. So I went out and started looking at the cost of a 6,000 watt system tied to the grid. Just enough power to keep the fridge and freezers cold. A few lights. An run the well.
Long story short turnkey systems were $8-9 per watt!:eek:
6,000 watts times $8 = $48,000
Hmmmmm.... I don't think so. :rolleyes:
There are a lot of hot air blowers in state capitals, Washington DC and Environmentalists Salons...
Later,
Dan
Your post has me thinking back to my twenty years in semi-conductor manufacturing, fourteen of which were in silicon materials, ie; crystal growth and wafer fab.
Having had an interest in alternate lifestyles and all that even before the seventies "fuel shortages", I somewhat followed the PV cells stories. As I understand it, the wafers are a major cost.
I can understand that as the infrastructure to build a production facility is not cheap. The supply of high purity silicon is quite finite.
Anyway, during that time, we used to dump wafers that fell out of spec into cardboard totes and they were sold off to someone perhaps to be used in steel making or something. I never thought to ask if those fallout wafers would be marketable to the PV industry.
   / I can't go Green, and this is why: #29
RD
I have never seen a commercial one.
   / I can't go Green, and this is why: #31
e?
RD
What I'm getting at is that pump may not be big enough to overcome the evaporation rate, depending on the size of your pond, of course. As I mentioned, we have a 24' pool. It's surface area is approximately 450 sq. ft. If I leave the cover off, I can lose 1/8 inch a day to evaporation. That's approximately 60 cubic feet of water, or about 450 gallons. An 1100 gallon per day pump would only be able to keep up an approximately 1100 sq. ft. pond at the evaporation rate I experience. That's about a 38' diameter pond. I just don't want to see you buy a pump that is undersized for your needs, that's all. :)
Best of luck with your project. ;)
   / I can't go Green, and this is why: #32
Moss, I think you're calculations are off a little. I have a similar sized pool (24' dia 48" deep) at 12000 for the total pool, it works out to about 250 gallons per inch of depth, (250 X 48" = 12,000) and I also lose 1/8 an inch a week for evaporation, and I usually need to run my hose (rated 4 gallons per minute) for about an hour a week to make up the loss. That works out to about 240 gallons a week. or around 34 gallons per day.
   / I can't go Green, and this is why: #33
Hmm... could be. I ain't so good in math. :p I just don't want to see the guy spend thousands of dollars on a solar pump that may not be big enough for the pond size. That's all.;)
   / I can't go Green, and this is why: #34
A 1/8" thick by 24' diameter circle contains 8143 CU/IN or about 35 1/4 gallons...
I hear ya Moss, and I have raised this question to the Robinson owner. He assures me that his system will be sufficient. It seems to be a very solid business that has been doing farm solar tank, pond & well pumping since the 80's. Their new brushless pump is rated for 20,000 hrs of use before re-build. As you can tell I am leaning in their (Robinsn)direction.
My permit to pump from the creek got lost:)>(, so I had to fill out a new one and drop off a drawing of the intended system. They(DNR) want a float switch to eliminate wasted water and/or overflow back to the creek. At least it's a cheap addition.
A gravity flow system would be the best way to go, but I calculate I would need 6' of grade upstream on the creek, and my guess is that would require well over 1500'(and across my neighbors pasture). I would have to put in a 1.5 inch pipe as opposed to a 1/2 inch for the solar which puts the cost somewhere in the $800 range for pipe alone....if gravity will work on my land.
I'll update when I pull the trigger.............
RD
   / I can't go Green, and this is why: #36
I was also considering getting wind turbine. I have the space to do it but not the money. I don't understand why the wind turbines are so expensive. They are simple machines with only few parts but they cost twice the cost of an average car that is composed of many complicated parts. I figured in my case it would take over 20 years to pay back the expense. I think if the cost of wind power would drop to half we would see thousands of them installed. I would need about 20 to 25 kW machine because my house is 100% electric except propane backup heating.
   / I can't go Green, and this is why: #37
I had a friend here local that was going to start a business selling personal windmills. He sourced motors from China (ya, I know, but it was the only way to make it economical) He had it down to 4 to 5 thousand to power a home. I don't know all the details or how it worked but long story short....drove out of business before he got started by local utility provider. You know how they say if you generate more power than you use, well the utility company had it so it would cost a homeowner $10,000.00 to tie his system into your home panel. Long story short he gave up on the idea knowing not many wouls sell with those kind of costs involved. ROI would take forever.
I'm not a fan of all this "green" stuff. Just like my big trucks. $10,000.00 more purchase price for all this new exhaust emmissions crap that takes some particulate matter out of the exhaust. What's the trade off you ask? New big rigs went from 8 to 3 mpg. Burn twice the fuel with an unreliable turd for a couple less parts per million of soot in the exhaust. Right on. Would it have not been just as easy to clean up the off road fuel and furnance oil to close the the ppm level of on road fuel to get the same net result? What a joke.
The governments want you to go green but all this crap is twice as expensive and they offer no incentives to make your investment worth while.
   / I can't go Green, and this is why: #38
I agree, with the loss in efficiency that these new requirements cause, I can't possibly see how burning more of anything can be good for the environment...
   / I can't go Green, and this is why: #39
I am definitely not for meaningless government programs but it seems to me that the change in fuel consumption from 8 to 3 mpg is unreal. Speaking about soot and similar particulates. I used to live in Rome about 23 years back. The air pollution was so bad that the air was just blue haze, burning your eyes and lungs. It was clearly poisonous. There was also resistance to catalytic converters etc but when I visited Rome few years later the traffic was about the same but the haze and stink was gone. So removing particulates matter I suppose. In the same time fuel consumption of modern cars (per unit of mass) is better than ever before. Don't know about big rigs though.
SWICT 60" SKID STEER BUCKET (A60430)
SWICT 60" SKID...
Deere 335P (A53317)
Deere 335P (A53317)
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
