Lost Steering on my 1850
/ Lost Steering on my 1850 #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
I have been having problems with my steering - sometimes you can turn the wheel a few times before anything happens. But i was in the middle of abig job and i hoped to finish it first. However, now turning the wheel does nothing. Right before it died, I could turn right but not left then all of sudden left but not right.
My guess is the steering valve is shot or one or more of the cylinders is leaking internally. I will have to get some caps and plugs and see if isolating one cylinder lets it function. Can't remember if they are 3/8" or 1/4" JIC so i guess i will get both.
If I am missing something I should be looking into, please let me know.
Ken
/ Lost Steering on my 1850 #2
Unlike you I made my guess without attempting to diagnose the situation and guessed wrong :) It was a broken seal in a steering cylinder.
PT-1845 Repairing Loss of Steering Input
Anyone have a source of cylinder seals that bypasses Power-Trac's silly $50.00 minimum order policy?
Sedgewood
/ Lost Steering on my 1850 #3
I assume lift and tilt are working fine? If so, then I would do your cylinders first, then the steering control.
You might as well rebuild them if they have not been rebuilt. Considering what our tractors might have seen...
Terry had said that the steering control's issues are leaking, not loss of control.
Carl
/ Lost Steering on my 1850 #4
I once had a tractor or truck (can't remember what vehicle, it was so long ago) but I could sometimes steer and sometimes could not. Turned out the steering wheel had a pin that was missing. :p Check that first, then move on to the hydraulics. ;)
Hi Moss,
The first thing i did was check the pin - I believe Carl had that problem once.
Hi Carl,
I called Terry to order rebuild kits for the cylinders and to ask him about the steering valve. He thought it was not likely that it was the valve kit. And yes, lift and tilt work. I ordered some rebuild kits for the lift and tilt cylinders too.
Ken
/ Lost Steering on my 1850 #6
Ken,
If you turn the steering wheel to the limits, do you hear the relief valves? If the steering is to the limits, do you still have lift and tilt. Are you leaking any fluid. It is doubtful that two steering cylinder would go out. Can you turn the steering in a continuous circle.
Hi JJ,
I can turn the steering wheel repeatedly in a continuous circle with no effect on the cylinders. I have always had to turn it more than once. I still have lift and tilt enough to raise and tilt the 3 pt adapter and rear blade and i think the pt was turned all of the way at the time - i do not think the pressure reliefs are kicking in. Not sure if i would hear them or not. The tractor is turned all of the way to the left now which is going to make it harder to remove the left cylinder.
I have no major leaks and none that i can see in the steering circuit. I think if just one cylinder is leaking, you can lose steering? I looked at Sedgewood's page after he posted and it looks like that is what happened to his.
I hope it is just that i need to rebuild one of the cylinders. I am going to do both while i have it torn apart.
Ken
/ Lost Steering on my 1850 #8
Yes, at least in my experience when my cylinder failed i had to do Loop D loops across the front of the house trying to get back close to the garage... Once in a while the pressure built up enough to help straighten up a bit, but in the end I was crabbed over on one side and it was a PITA to get the cylinders off.
Speaking of which. Mine were screwed together by someone big and strong. I nearly had to order new ones as the machine shop I ultimately took them too could not get them off.
They ended torching it to get it to come apart (heating it up).
/ Lost Steering on my 1850 #9
Ken,
I think that before I took them apart, that I would test them, either at a hyd shop, or by using the aux circuit to test the cylinders. Perhaps you blew the piston off the rod, if that is the case, the fluid would just move back and forth in the cylinder and do nothing. . Did you happen to put a hyd gage in the cylinder circuit to see if you had any pressure. If you do not have pressure, back up to the input to the steering valve and put a gage there. Do you perhaps have another cylinder you could hook up to the circuit and test fluid integrity, otherwise, does it stop and go when and where it is supposed to.
So, if i disconnect one cylinder, plug the lines and cap the cylinder connections and try operating it, does that tell me anything? These cylinders are double acting, aren't they. So if the bad cylinder is capped and the lines plugged, the system should pressurize and the tractor turn. If the good cylinder is capped, the system should not work. If both are bad, nothing would happen. If both are good and the steering valve is bad, nothing would happen. Sound right?
I have Tees, caps, plugs, etc on order so that i can test my circuits in the future. I ordered running tees so i can test a live circuit and i will also build some quick disconnect gauge connections for pressure testing also. I was thinking I would attach a gauge to a 1/4" JIC hose and then use that with the various testing setups, always adapting down to a 1/4" JIC male connection. The test setup has always been on my list of things to do but reality has pushed it to the top of the list.
Ken
/ Lost Steering on my 1850 #11
Ken,
I believe you are correct on capping the steering lines, but I have never done that. but that cap should pressurize the other cylinder (one gets the pressure then the other gets the pressure, at least on mine)
But no guarantees. I still struggle with the flow direction on the steering system we have...
/ Lost Steering on my 1850 #12
I don't know what your first move is, but if the steering valve is bad and is just recirculating fluid back to tank, except when you lift or tilt, it will be difficult to test the steering. You need good pressure down to the steering cylinders, and you can get that using the aux circuit. I believe there is a priority valve in the steering circuit. If the steering wheel is not turning, the fluid is available to the lift and tilt circuits. Since you have lift and tilt, you can also use the lines from the lift valve to connect to the steering cyl, and if you tee in a gage in that circuit, you will know if you have a good cylinder, if you extend or retract the rod. It should read some pressure, but will only see relief pressure at the stops.
/ Lost Steering on my 1850 #13
So two cylinders for steering means half the reliability? Since if one fails, you loose steering?
Sort of like a twin engine plane, when one engine fails, the other just carrier you to the crash site? So you are twice as likely to crash.
Of course, you are less likely to rip a chunk of you frame out, like happens occasionally with the single piston PT422. That reminds me, time to lift the floorboard and inspect the pivot point on my steering for cracks... Someday, when I am better at welding and will do more good then bad, I will add some reinforcements and get rid of that poorly placed drain hole.
/ Lost Steering on my 1850 #14
Carl,
Both of the cylinders should get pressure at the same time. One cylinder is extending and the other is retracting. More fluid is going to the extending cylinder.
/ Lost Steering on my 1850 #15
On the airplane comment, not true. While in the Navy, flying in the Lockheed P3, with four engines, we regularly shut down one engine, and sometimes two to extend the range. I was told that plane could fly on just one engine, if it had to. We dumped fuel many times to lighten the load when we had to return home for some emergency.
I believe one cylinder could turn the PT, but the brackets would have to be reinforced. One of the smaller PT's only uses one cylinder.
/ Lost Steering on my 1850 #16
On the airplane comment, not true. While in the Navy, flying in the Lockheed P3, with four engines, we regularly shut down one engine, and sometimes two to extend the range. I was told that plane could fly on just one engine, if it had to. We dumped fuel many times to lighten the load when we had to return home for some emergency. .
The P3 is one of THE most overpowered monsters in the sky! :)
Now take the popular nicknames for the SWEARINGEN METROLINER on one engine: Death Pencil / Kerozen Crowbar / San Antonio Sewerpipe / Swetro / Terror Tube / Texas Lawn Dart / Texas Sewer Pipe / Window Maker
/ Lost Steering on my 1850 #17
They only have 4500 HP per engine. In that crash out in California, many years ago, the P3 was taking off, and a 727 landed on it as it went down the runway, and the P3 lifted the 727 for a short distance, but they both crashed and burned.
/ Lost Steering on my 1850 #18
True. But I was talking about loosing one of two (not four), leading to very assymmetric thrust. Did you ever shut down two engines on the same side, other then in a controlled training exercise?
But most light twins do not perform well under SE conditions, and have a very limited SE ceiling and minimal climb capability. As long as the pilot does what he is trained to do, loss of an engine shouldn't actually result in a crash... although it occasionally does.
avweb said:
http://www.avweb.com/news/usedacft/182809-1.html
The overall accident rates of high-performance singles (like Bonanzas or 210s or Mooneys) and light twins (like Aerostars or Barons or Commanders or Cessna 310s) are astonishingly close. Twins have a slightly higher accident rate per 100 aircraft and a slightly lower accident rate per 100,000 hours, but for all practical purposes the accident rates are the same.
A single is about two-and-a-half times more likely to have an accident due to engine/prop failure than a twin (8% versus 3%). And if we assume that a twin is twice as likely to have an engine/prop failure (since it has twice as many to fail), then we can conclude that an engine/prop failure in a single is five times more likely to result in an accident than an engine/prop failure in a twin.
But it makes for a funny application of probabilistic risk assessment...
/ Lost Steering on my 1850 #19
Sounds right. And you can steer with just one cylinder working to get you home.
Sedgewood
/ Lost Steering on my 1850 #20
Carl,
When I ripped the cylinder free the oddest thing happened. One cylinder would expand then the other one would contract (Not at the same time). Now, as I freaked out that my PT would be stuck in the woods forever, I never paid full amount of attention to the intricacies. But basically I would have to spin the wheel and get the rippedcylinder to its long or short position before the other piston would take over.... Maybe because there was no backpressure?
