x 304 aws question
/ x 304 aws question #1
Lone Oak Landscaping
Orange county N.Y.
NewHolland TC40DA
Bought a mulch kit for the deck from John deere,came with a mulch plug and two blades that bolth say RIGHT on each blade.
The owners manual says to make sure you put the mulch blades on LEFT and RIGHT sides correctly .
The instructions on the kit say nothing about LEFT or RIGHT hand blades.
Any one know if there should be two different blades ?
Thanks for any help.
/ x 304 aws question #3
Both blades turn in same direction I believe to help push grass out the chute.
/ x 304 aws question #4
no such thing as a left and right blade unless you're cutting hay. just make sure you put them on with the correct side facing up/down. happy mulching.
/ x 304 aws question #5
Actually, there are some two-blade decks that use different size blades. I remember Simplicity makes one, maybe for the Regent. Seems to me that Deere has (or had) a deck model that used two different size blades as well.
/ x 304 aws question #7
I would let my finger do the walking. Right to my local Deere dealer for a conclusive answer.
/ x 304 aws question #8
Had the blades off mine 2 weeks ago to sharpen them. They are both identical. Make sure they're right-side-up & you're good to go.
2021 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2021 WEILER K560...
John Deere 1026R (A64911)
John Deere 1026R...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2006 FORD E450 UTILITY TRUCK (A66091)
2006 FORD E450...
2016 CATERPILLAR 304E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
Frontier BB2048 (A64911)
Frontier BB2048...
