First Time CUT/sCUT Implement help? [For Landscaping]
   / First Time CUT/sCUT Implement help? [For Landscaping] #1
Bassicfun
Mid-Ohio
Kubota BX2660
FIRST POST ON TBN!!
Looking at a BX2660 (first tractor, minus the 1970s 18hp V-Twin Sears/Craftsman mower etc)...
Here is my thought for my use (and any economical suggestions are welcome!)... I have just over 5 acres, lots of rolling hills, all will be either mowed (probably ~3 acres) or brush hogged (back ~2 acres). This was old farm land (from years and years back). We just built a house and finished it in October, this winter nothing was done (minus 4' snowblower on the Sears tractor worked like a champ!) to the yard or ~400' curved/hilled gravel driveway...
Spring is here and what I have noticed is that the land is filled with large mounds of ant hills (haha) in the back few acres, the entire land has many small (6' tall, 2" around) saplings and similar sized thorn bushes that have grown over years and years. The front hill (that the house sits up on) is the home to our septic system, which is a step tile format down the front of the hill, as they ran the tiles and buried them, there was little/no thought into how much it would settle. Therefore, there are ruts for these tiles guessing about 6-8 of them, probably 150' each around the front of the hill. Also the ground around the house has settled, and has a bit of negative grade to the house (luckily up on the hill most of it still runs far away from the house). I do not know if we will EVER spend the money on grass seed, but I would like to be able to mow at least a smooth yard, clean up the front (old fence posts, small trees, ditch to lay tile & fill in), so we can mow to the road side w/o an exposed ditch.. I am unsure so far on snow removal, of using the FEL, or a blade (I do enjoy my snowblower now).. or getting a rear PTO driven snowblower for the BX.
Aside from that, here is my thoughts on what we will do, and please question/scrutinize as you see fit! BX2660 with FEL and (probably) 60" MMM... And to keep starting impliment costs in line, I'm thinking of a box scraper with scarifiers (to losen the decent top soil, some clay underneath), also use to do some basic smoothing, and then a landscape rake to remove the MULTITUDE of rocks throughout the yard. The driveway was very well done, with canvas underneath (to keep mud/dirt from seeping through the rocks) great base of 1s & 2s done 2x while the huge trucks were dropping off equipment and material, and 2 coatings of 304 w/ a good amount of limestone dust. The driveway has been great so far, no vegetation, most of it staying put, I could see a gentle 'leveling' now and then, or wait to do an actual top coat of smaller rock.
Can anyone share some thoughts on that? I do not want to end up with a ton of impliements (I guess I already neglected to mention a 42-48" used brush hog for the back few acres). I am trying to keep costs in line, as we are all aware of the economic issues (especially for myself in the middle of the finance world, and wife working for a real estate company) and a bleak outlook in the short term (~year or so).
Thanks for any comments/thoughts
   / First Time CUT/sCUT Implement help? [For Landscaping] #2
i think you have it all figured out, you seem to have done your homework. the boxscraper will turn out to be a very useful tool, pulling roots and such. does bota have front mount snowblowers? not sure if i'd be comfortable doing my drive by the time i was done i probably wouldnt be able to turn my head.
EVERYONE likes pictures right!?!
Here's a few...
Looking up the driveway (still under construction) the dirt on both sides wasn't smoothed out, pretty rough & rocky.
Here is the front hill, about 1.5 acres in front of the house.. with the septic tile field.. underneath the ACTUAL field (haha)... all the tiles have settled are pretty rough, and the soil is rocky, decent top soil, clay underneath.
These are the couple implements I'm considering as a good start for 80%+ of the work (forgive the TSC brand, just easy to find/copy/paste pictures!)
I'm picturing the box scraper also to use to get a bit of a swale around the house, as the back yard area flattens out behind the house and falls away on the treeline side. I've seen someone (I forget the posters) on here who angled the box scraper from left to right, as to cut a small ditch to help direct the water.
And a Landscape rake for rock removal, more smoothing, and perhaps once the driveway gets top coated again, to help maintain that as well.
And we all know what an old 42-48" brush hog looks like :p
   / First Time CUT/sCUT Implement help? [For Landscaping] #4
FIRST POST ON TBN!!
wow thats really detailed and well thought out, not sure how i can help you though
Not sure I'll go for the high priced front mount Kubota snowblower. Thanks!! I'll work on looking at the rear PTO options more than likely. ;)
   / First Time CUT/sCUT Implement help? [For Landscaping] #6
Does your septic installer have an opinion on running the small tractor over the septic & leaching lines??
No issue with the septic tiles, they are approx 10"+ deep.
Additional questions from my original post though: Planning on R4's... Since this will be used in snow removal, landscaping and mowing, but not a suburban-type lawn... A county type lawn... (largest school district in the state w/o a single traffic light.. You get the idea).
Also any thoughts on wheel weights? No desire for loaded tires.. But mechanically attached wheel weights.. Should they be considered? Thanks.
   / First Time CUT/sCUT Implement help? [For Landscaping] #8
I have a BX2660, also my first real tractor, and have similar uses to what you describe. For implements I have a BB1548 box scraper, RB1572 rear blade, RC1548 rotar cutter, and a split-fire splitter. FEL too of course.
It sounds like you have your implements figured out. I've only been through one winter, but I was able to use the blade/FEL with no real issues. I'm in Northern Canada, so we have REAL winters here and I fared well.
For tires, the turfs work great and you can to anywhere without any damage. DEFINITELY get your tires loaded. The best money spent and the best thing you can do for the BX. More stable, smoother, better traction...unbelievable difference. For winter, I added chains and it makes it pretty much unstoppable unless you get into really deep snow.
I'd try a winter without a snowblower and see how it goes. I can't imagine doing a long driveway with a rearmount, and a front mount here is $5K. The other downside of snowblowing is all the snow in your face. Blading leaves a very nice finish on the driveway and keeps the snow down.
Feel free to contact me if you want to discuss more.
   / First Time CUT/sCUT Implement help? [For Landscaping] #9
Ummm modern septics are designed to evaporate upwards.
I'm not a fan of R4's they squat low & hang up my TLB. R1's have better clearance and traction.
Your are paying for the tractor, fuel and most importantly time. Sitting there spinning is a waste of all three since your not **** about living in the middle of a golf course.
Don't short yourself on attachments. No need for store bought either. An old bedspring is a great levelling drag, so is an old RR tie. I put together an assortment of odds & ends on a 3pt configuration then welded a 2" receiver on top, scrounged one of those 20"x60" trailer hitch cargo trays. Made for an excellent trailer mover, mobile workbench, etc.
Weights can be had cheap. Oil distributor dented 55g barrel $ free. 1000 lb rear weight cost me $10 had it filled at the Redi Mix plant from a returning truck - he was going to wash it out anyway. A bush hog might tip the balance backward so add a front weight. Pix of mine found in a blacksmiths scrap pile 2 2x6 sticks of steel welded together with a piece of angle to hook on the front bumper cost $20 including Wal Mart $0.99 rattle can paint.
I would consider wheel weights, but I'm not into loading tires, heaven forbid there is a puncture or leak. Wheel weights that will outlast any tires sound more my speed!
Where did you get chains? or make your own?
Aside from that I appreciate the response and ideas, perhaps I will use/work with the FEL and box blade for a winter and see how it goes, and decide from there. Do you drive through it, pack it down then scrape with the box blade? or do you use the FEL for first pass? We may not get Canadian winters, but still feels pretty real ;)
BarryinMN - Thanks for the post, we have to mow over the septic, and I am more than aware and being careful as to the manner of breaking any ground, or pushing more ground on top of those tiles. (this isn't a mound septic).
Can you explain what you mean by R4's 'hang up' your tractor?
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
