A simple convenience item.
/ A simple convenience item. #1
mjncad
Super Member
In the civilized First World
A couple
Since I have an adjustable top hook on my Land Pride quick-hitch, I made a hand written chart of what holes in the hitch and hook are used for each implement. The trouble is the chart was in the garage, and I wanted something on the tractor.
This link shows the hook. Picasa Web Albums - Matt - John Deere 42...
The following picture shows the 3" x 5" stickers I had www.cafepress.com make from a file I sent them. The blue lines are guide lines for future implements that I can add labels to that I make with my Brother P-touch label maker.
I have a sticker on each leg of the quick-hitch.
/ A simple convenience item. #2
How's that song go.........."Too much time on my hands, I've got too much time on my hands......." Good job! I guess when I get enough implements I might consider doing that as well. Thanks for the idea! :p
Troy
/ A simple convenience item. #3
I used white out and wrote on the top bar of my QH. Implement- hook or adapter- top link (in or out)-what holes the hook go in. Also numbered the holes for the hook. You are right about the convenience factor, until I did this I would go to change implements and not have a clue until I got to what I was going to hook up to.
/ A simple convenience item. #5
Looks like professional work. Also, hard to loose track of that.
I used an electric engraver to etch basic tune up info I need on a scrap piece of aluminum and keep it stored in the tool box on my machine.
/ A simple convenience item. #6
It's always good to write things down, I would need to put a note on the steering wheel to remind me of the note on the hitch.:)
Thanks all. I forgot to post the file I sent to Cafepress. After the stickers came back, the top line of text barely made it inside the sticker, so I moved the text and lines down should I need to have more made.
/ A simple convenience item. #8
I use a "Sharpie" fine point marker and the under side of the hood for notes. The trick is to pick a spot that won't sun fade and is semi hidden until you need the infor. The under side of my toolbox lid is another information storage cash. I also mark filters with service date information. Plus, alittle acetone/rag will erase the marker as information needs updated!
I use this trick on all my equipment,cars and trucks. ;)
2014 Dodge Ram 4500 Versalift Bucket Truck (A60352)
2014 Dodge Ram...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
159118 (A60430)
159118 (A60430)
TAG 18in Digging Tooth Bucket Excavator Attachment (A60352)
TAG 18in Digging...
