B3200 QA on B2620
/ B3200 QA on B2620 #1
ChuckinNH
Elite Member, R.I.P.
NH
(B2620, had BX22) Simplicity Legacy w/48" mmm
For those that might be interested, I did purchase the B3200 loader QA, and install it on my B2620 with no problems. I bought the Kubota forks, and everything fits, and functions fine. The forks seem to be a very good size for the tractor though having the BB on back besides the loaded tires is a good plan. I moved a couple of logs, a couple of big stumps, and some brush with the forks just to try them out, and it sure was easier than trying to do that stuff with the loader bucket.
/ B3200 QA on B2620 #2
I'd be curious to see what the forks look like if you could post a couple pics.
/ B3200 QA on B2620 #3
I'm curious what the B3200 QA cost if you don't mind sharing?
Stu
/ B3200 QA on B2620 #4
Chuck,
What did you come up with for measurments on the quick hitch? I am going to the dealer to try out a new b3200 with quick hitch on Wed and would like to bring my pallet forks with me to see how well the tractor lifts stuff. Mine are set up for a 7510 now but are adjustable. The forks are made by horst mfg. The 7510 uses 3/4" pins and I am asuming the 3200 will be 7/8"
Thanks,
Rob
/ B3200 QA on B2620
Chuck,
Thanks,
Rob
Rob, the pins are 1" dia. (or maybe 25mm) they are 7" apart, and the distance between the arms is about 31 7/8".
/ B3200 QA on B2620
Stu
Stu, The forks were $940, and the QA was $270 though you probably can do better where you are.
/ B3200 QA on B2620
Here ya go:
They seem to be a really nice size for the B series tractors. I was surprised that I could lift a couple of stumps that I had been unable to lift with the loader. Even though the QA moves the pivot points ahead, you can get the weight back much closer to those points with the forks when it is something bulky like a root ball, or long like the old logs I moved. I'm glad I got the BB at the same time since that extra ballast is needed.
/ B3200 QA on B2620 #8
Thanks Chuck!
I appreciate the info and the pics!
Stu
/ B3200 QA on B2620 #9
Hi Chuck, I see your Box Blade in the back ground of one of your pictures. Looks like a King Kutter. What size is it? And would you go that size again? Thanks I'm trying to decide on one for my 2920.
/ B3200 QA on B2620 #10
I really like those forks. The assembly looks pretty light, compared to most. Some of the lighter forks I've seen have the tines made out of channel (which I wouldn't be interested in). I certainly don't have any need for 4000# forks on a tractor that lifts 1000#. Thanks for the pics !:)
/ B3200 QA on B2620
The box blade is a Woods 48". I got a pretty good deal on it since it had been sitting outside on the dealer's lot over the winter. It is the GB48 model, and I believe that Woods has stopped making that particular one. I debated getting a larger one, but after using this one some yesterday, I think I'm going to be pretty happy with the size, and weight of it. With the loaded R-4's I could make it work on a firm gravel base, and it seemed wide enough to cover my tracks on the swale I was working on. I have some tight places on some logging roads / trails I'm puttering with, and that was another reason to stay with the 48" width. This is the first time I've ever used one so I was winging it a bit too. They are getting more popular around here, but are still uncommon, and my neighbor (who has a tractor) still had to come over to see what it was..... :D
/ B3200 QA on B2620
Ductape, Yes, I was struck by the nice size when I saw these on the dealer's porch when I went to get some parts for my Simplicity. They are somewhat smaller than the common ones I've seen, and are still very rugged. That trip for my $5.00 part sure cost a little extra, but I do really like the forks so far.
/ B3200 QA on B2620 #13
chuck,
My 7510 is 7" as well can't remember the width. I am glad to here the pins are so big.
What is the length of the forks you have? mine are 42" and am glad they are.
You will love the hitch I swap attachments all the time.
Rob
/ B3200 QA on B2620
Hmm, can't tell you how long the forks are. I think they are over 36" so 42" might be about what these are. I doubt that they are longer than that. Raining here now, and it's time for some lunch, I'll check later sometime.
Edit: I did check Kubota's web site, and they say the forks are 36".
/ B3200 QA on B2620 #15
Did I miss seeing them or are there no grease zerks on the pins holding the QA bracket to the laoader arms/cylinders? :p
Troy
/ B3200 QA on B2620
Yes, strangely, there are no grease zerks in the pins that come with the QA for where it mounts to the loader arms. You do end up with a couple of extra pins from your existing bucket though, and I think I will install those, and perhaps get a couple more.
/ B3200 QA on B2620
Troy
:D :D Hmm, My son was visiting while we installed the QA, and it didn't occur to me that we needed to move the pins without the grease zerks to the bucket / forks side of the QA. We just installed them the way they came. There is no pivoting going on between the QA, and the attachment........ DUH :confused:
/ B3200 QA on B2620 #18
I'm thinking about this setup for my b2620. Pardon my stupidity but how does this QA work - you drive up, hook the top pins then manually insert bottom pins? I have just used the QA on my friends L35 with the levers. Also does moving the pivot point ahead have much effect on how much weight the bucket can pick up?
/ B3200 QA on B2620 #19
Chuck,
I like your fork setup pics and called local dealer on pricing for QA and forks for same setup on my B3200. I have a friend who has a set of forks from a forklift he used to have and said i could have them.I called another friend who works for a forklift company and he said that forks of this type come in two classes (2 or 3) difference in being 16" or 20"where the forks hook onto carriage. Dealer does not have one in stock to measure and would like to ask if you could measure your setup. If forks will work will save me around 400.00.
Measurement can be on the fork between where they hook on top and bottom or on carriage top to bottom.
Thanks Gene
