Help-BX 1500 three point hyd problem
/ Help-BX 1500 three point hyd problem #1
GSmith4965
Hi:
I have a 2006 BX 1500 with 190 hours. Today I lost the ability to raise the three point hitch and mmm. I had just attached my fel. When I went to raise the mower deck, nothing..... I checked the linkage, hyd oil level and bled the hyd system. Nothing seems to work. Can someone please help??
Thank you
Greg
/ Help-BX 1500 three point hyd problem #2
I only had a problem like that when one of the front hydro lines were not attached properly.. it had a little stone in the quick release fitting
/ Help-BX 1500 three point hyd problem #3
That's my guess, too. I would relieve the hyd pressure (tractor off and move the loader lever), disconnect the hoses, and try to reconnect them. There may be pressure still in the line that didn't connect properly so reconnecting them might be tough.
/ Help-BX 1500 three point hyd problem #4
were you able to resolve your lift issue yet? most of the time its just the control knob under the seat turned all the way to slow or no lift. Just turn the know the other way and it should function fine.
Thanks guys!! I had a couple lines crossed on the loader. That explains everything.
Thanks again
speed limit sign (A61572)
speed limit sign...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2006 Reefer Trailer (A64194)
2006 Reefer...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
