John Deere F935 engine trouble
/ John Deere F935 engine trouble #1
dlbcheckmate
Hello, great site ! I have a John Deere F935 with a Yanmar Diesel engine. I rebuilt the engine (new pistons, bearings, rings, injectors, glow plugs ect) after it started ok, I ran it about 1/2 hour ( mowing) or so and it quit under load. I was able to restart it after bleeding but it does not seem to have full power and really doesnt seem right. When I crank the engine over to bleed the fuel system it will actually slow down and almost stop cranking when you crack the #1 injector line when you tighten up the line it resumes cranking ? Any ideas ?
/ John Deere F935 engine trouble #2
Why did it need rebuilding in the 1st place?
Hope it's not overheating. Can't say for sure but is the injector timing good?
I bought it from a surplus dealer, it had sat for a long time. Found one rod bearing gone and the crank journal bad. Repaired the crank and installed the new parts in the engine. I did not check the injector timing after reassemble, but it seemed to run great on the initial startup?
/ John Deere F935 engine trouble #4
Did you replace the fuel filter? It has a water detector and may put a light on if it senses water. Mine acted just like yours until I replaced the fuel filter. Also, if yours has dual tanks, the fuel gage switch reads the tanks but the "other" lever actually switches the tank manifold. This can result in a great loss of scalp hair. Make sure your fuel pump is clicking while you are at it. This is a really nice lawn mower. I have the 72" deck and cut a couple of acres in 40 minutes (lots of trees to go around). I put Gator blades on it and some aggressive ATV tires for hill climbing. I even added headlights for night cutting... There's a few other things to check if this doesn't help. I'll have to have a Red Bull in order to remember what all I did. Seems there was an air intake full of a mouse nest or something similar.
Well, I checked the timing tonight and it is WAY OFF. I have a single shim .020" in as the manual describes but my timing mark is at least an inch off? I pulled the pump housing off and it looks normal no major wear or broken parts. Could I have misaligned the timing gears when I reassembled the engine? I checked the timing twice before pulling the top. I don't want to pull the engine out if I don't have too. Thanks
Dave
any ideas before I pull the motor again?
/ John Deere F935 engine trouble #7
Dave
Is it possible to be 180 degrees off?
/ John Deere F935 engine trouble #8
G'day sorry to hear your prob dave but it sounds to me like you have got the timing gears out :( i think i would be pulling the front cover and checking. Best of luck:)
Jon
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
John Deere 6000-Series Tractor Lift Arms (A65640)
John Deere...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2016 Husqvarna DRT 900H Tiller (A66408)
2016 Husqvarna DRT...
2014 Nissan Sentra Sedan (A64557)
2014 Nissan Sentra...
JOHN DEERE BD1108 GRAIN DRILL (A64277)
JOHN DEERE BD1108...
